Go Back   HeliFreak > R/C Electronics Support > Futaba Radios and Electronics > Futaba CGY750 FBL System
Futaba CGY750 FBL System Futaba CGY750 Help and features Support Forum
Old 06-22-2011, 05:39 PM   #61 (permalink)
A question - I am new to fbl systems (cgy750 is my first besides mcpx), can someone briefly describe how "98% to 100% which increased the stability of my heli without compromising on my control feel/accuracy" would feel?
My AFRs are quite high (50-70 on 450 class heli12/8 pitch collective/cyclic), so I am going to play with AVCS damping, but I just don't know when the value would be too high.
Right now I have it setup at 99% both aileron/elev, flight mode 3 and -15% expo (rest stock) and heli feels quite a lot too soft/tame (or like too much expo). I am used to 250 size FB heli setup with almost no expo and about 8 degrees on cyclic - controls are immediate and very linear, which I like.
TDR/VBar
Logo 600SX 12s VBar
MSH MINI PROTOS/CGY750
AcidDrink is offline        Reply With Quote Quick reply to this message
Old 06-23-2011, 09:57 AM   #62 (permalink)
Thanks for the very useful info, joe1l!
AcidDrink, try changing your Flight Mode to 4 or even 5. This will liven the control feel up considerably.
T-Rex 450 S, T-Rex 500, Pantera 50, Turbulence D3 (one can dream)
benwhite22 is offline        Reply With Quote Quick reply to this message
Old 06-23-2011, 01:54 PM   #63 (permalink)
thanks guys! i'm glad the info is helping. Well i hope it is helping. A product can be the better than all of its competitors but if people don't understand how to use it then it might as well be the worst. im hoping now that people understand the Expert settings that more will tune and provide even more feedback. bbremer is the person everyone should be thanking considering he cleared up some of the most confusing settings. I'm still a new pilot but i know what i like and if a system doesnt inspire confidence then i'll have a hard time flying it. The CGY750 inspires confidence and thats what i like...but it needs some tuning to get it right for me.
Gaui X7 MSH Brain YGE160HV Xera4035-480 Gaui X475 FES MSH Brain YGE120 Xera4020 Gaui X5 MSH Brain YGE90HV Xera 4025
Gaui X6 vbar silver 5.3 YGE120HV 700mx
joe1l is offline        Reply With Quote Quick reply to this message
Old 06-25-2011, 12:53 PM   #64 (permalink)
Just came back from the field, did some tweaking based on info from this thread and it's fantastic.
Stayed with flt mode 3 for time being, but upped AVCS damp to 100, igain to 50% (both elev/aileron) and flew in 20 mph winds, heli didn't even feel it... (it's mini protos, 450 size).
After lowering in/out values a notch it feels just right now!
I have to adjust tail gain a bit, but that's it I think.
Thanks again!
TDR/VBar
Logo 600SX 12s VBar
Old 06-26-2011, 09:44 AM   #65 (permalink)
Default Rudder delay mode:Function / Constant
Rudder delay mode (Dly.Mode) from Function to Constant. (manual Page 92)
Defualt: Function.
Anybody tried the Constant mode?
Ill try on my next flight
PS: what a great Sticky
Name:	CGY page 92.jpg
ChopperKnud,
Team Heliwholesaler - Team Miniature Aircraft
ThePitchbrothers.com
Knud Pedersen DENMARK is offline        Reply With Quote Quick reply to this message
Old 06-26-2011, 10:46 AM   #66 (permalink)
With a 450 start at the default value of AVCS.dmp and increase 1 point on both ail and elev and test fly. You will see that heli would feel more solid but you may feel a slight decrease in accuracy or sensitivity. Now from what you are describing, AVCS.dmp will not help with, instead increasing flight mode will help. If you find that increasing your flight mode from 3 to 4 doesnt help then chances are your AFR's are too high then you may need to go out 1 position on your servo arms to get a little more throw. IF you are getting 8 degrees of Ailerion at 60% or more AFR then i would go and increase your throw and see if you can land at 50-60 range instead. Elevator on the other hand 60% AFR is norm. You should try increasing your cyclic gains in the TX as this will help with that feeling. A trex250 is a fast heli so the 450 will always feel slower compared to it, therefore increasing your cyclic to 8.5 or 9 degrees might be better.
Old 06-26-2011, 11:34 AM   #67 (permalink)
Thanks for that, very good explanation.
I have decreased my in/out values for aile/elev by 1 and it's all good now. My AVCS damp is set to 100% and I don't think I feel any decrease in accuracy or sensitivity - I asked an experienced pilot who flies a 700 FBL to test fly it and he said it was very sensitive . I'll try to lower it to 99% just to see how it feel and see what happens. All I know is that heli is very stable even in 20 mph gusty winds.
Thanks again!
TDR/VBar
Logo 600SX 12s VBar
Old 06-26-2011, 01:26 PM   #68 (permalink)
i guess the sensitive-ness could also be becuase of low Expo.
100 AVCS.damp is default in FM5
ChopperKnud,
Old 06-26-2011, 02:49 PM   #69 (permalink)
I like how it reacts now, very immediate (just a matter of preference - I am not big fan of expo).
Going to play round with AVCS damp just to feel how it changes heli's behaviour.
TDR/VBar
Logo 600SX 12s VBar
Old 06-28-2011, 05:15 AM   #70 (permalink)
me to
You could also try to play with the Igain
ChopperKnud,
Old 06-30-2011, 02:33 PM   #71 (permalink)
Most of my flying with the CGY750 has been in flight mode 3 as that seemed a good place to start. I've read this thread with interest, noting what's been said, but given the poor documentation, I've reckoned that once you get your AFRs setup for good resolution it was probably best to start by trying the other flight modes.
I've therefore given flight mode four a try. My immediate impression was that my 500ESP became very lively; more precise but rather more twitchy. To be honest, although impressed by the evident control being offered I liked the feel of flight mode 3.
Then I checked the table in the manual and saw that the AIL/ELE expo is -40% in FM3, but -30% in FM4. So this lunchtime at the park I set both to -40% in FM4. Wow, what a difference. Now I have all the control, but extra crisp and precise. It gave me the confidence to try inverted for the first time on the 500 and it was just like the sim!
Steve
Trex 450SEv2/HS65-MGs cyclic/Spartan Quark/DS520 tail
Trex 450ProV2 DFC/CGY750 FBL/DS410s cyclic/DS520 tail
Trex 500ESP DFC/CGY750 FBL/YGE-120LV ESC/DS510s cyclic/DS650 tail
Blackout 330/OpenPilot Revo with FatShark 600mW VTX, Futaba 8FG 2.4GHz
Steve Evans is offline        Reply With Quote Quick reply to this message
Old 07-01-2011, 03:31 AM   #72 (permalink)
Steve
This sounds interesting. I also fly my 500 in FM 3. But I have lowered my EXPO and lowered the ANG.Rate as well. That gave me a very comfortable feeling. Apart from the one or two problems I still encounter. FM 4 is to twichy for me. EXPO does not change that for me. Did you change the ANG.Rate as well?
T-Rex 500E - JIVE 80+ LV + MINIPYRO 20-08 / BLS153 / CGY750 / BLS251
T-Rex 550E DFC - JIVE 100+ LV + PYRO 600-12 / DS610 / V-Bar / BLS251
T-Rex 700E DFC - ICE2 HV 120 + 750MX / BL700H / CGY750 / BL750H
wbplomp is offline        Reply With Quote Quick reply to this message
Old 07-05-2011, 11:19 AM   #73 (permalink)
Steve
That is exactly what i encourage many people to do. The other big setting you can look at is Control delay in and Out. It is similar to expo and can help smooth out any twitchy behavior sometimes. There is a difference between the values for FM3 and 4 and you might want to right in the middle.
Old 07-05-2011, 03:32 PM   #74 (permalink)
With my T-Rex 500 I fly in FM2 and lowered the ANG.Rate to 90%. I want more stability and precision, but I don't want have a twitchy heli.
Is it worth to switch over to FM3 or FM4 and lower the ANG.Rate and maybe some other settings?
Old 07-09-2011, 03:35 AM   #75 (permalink)
http://www.facebook.com/notes/futaba...50225340356618
TDR/VBar
Logo 600SX 12s VBar
Old 07-10-2011, 06:02 AM   #76 (permalink)
I think I am going to try FM4 then. The only thing is, I don't like to tweak that much as described in the link. I also wonder the different effect between ANG.Rate (CGY750) and AFR/DR (Tx).
Old 07-10-2011, 07:04 AM   #77 (permalink)
See HERE for some relevent discussion of ANG.Base, ANG.Rate and AFRs.
Steve
Old 07-12-2011, 09:59 PM   #78 (permalink)
Many people have stated that the higher flight modes offer a more stable heli...the reason i see for this is because the higher the flight mode the higher the default value for AVCS.dmp. I suggest choosing a flight mode that feels closest to how you want your heli to feel. If you want quick cyclic then probably one of the higher flight modes but if you want something slower then go with lower ones. If you feel FM3 or 4 is twitchy then go start with 2 and make changes. Whatever flight mode you are in, i always suggest having optimal resolution so that you can increase your AVCS.dmp to 100% which increases the overall stability feeling of your heli without loss of feel.
Old 07-26-2011, 06:10 PM   #79 (permalink)
hi, just got my 750 3 days ago and i've been doing alot of reading trying to set this thing up. I got my swash going the right directions when i move the stick and I noticed that my PIT servo (channel 6) has less up throw than down throw. I would assume that i have to go to endpoint setting on the 750 and adjust from there, but i can't find it anywhere (basic or expert). Its a simple thing to do but can't find it for the life of me. I'm getting 7 degress right cyclic and 11 degrees left cyclic?
I even tried changing endpoint on my radio(T8FG) but all i got was more or less pitch. coming from the 7C radio, i would think it would adjust the servos individually but guess not, so i ditch that idea.
BladesOfFire is offline        Reply With Quote Quick reply to this message
Old 07-26-2011, 11:30 PM   #80 (permalink)
there isnt a menu on the CGY750 to adjust this . f you are getting more Right cyclic then left, you should be instead trying to adjust it via Ailerion endpoint (Ch1) for left and right. You should not adjust the pitch endpoint.
My only guess as to why it is so off is that you either acidently have subtrim programmed in your radio or it may be due to your neutral point set in the swash menu. Maybe you have it adjusted so high that it is hindering the movement. I would go take a look at your neutral values and see if you have any that are more than 90. If i find that i need more than 90 points of adjustment on any servo, i instead move the servo horn.
Human Verification
