Like Tree219Likes
Old 11-15-2017, 04:48 AM   #2761 (permalink)
Here my Facebook page
https://www.facebook.com/JPChargers/
Verstuurd vanaf mijn SM-N950F met Tapatalk
Joeribar is offline        Reply With Quote Quick reply to this message
Old 11-19-2017, 04:50 PM   #2762 (permalink)
Almost done, just need to install the AC plug/switch, wire it up, and wire the charger out to the posts. I also need a cooling air intake somewhere, just need to think it out a bit more.
The design is based around a CellPro 10s with +24VDC input.
There's power out to support a secondary multi-chemistry charger (my current version supports +12VDC input) at 12 or 24VDC.
the entire package has a configuration for storage/travel where the components are held in place by velcro. Adapter storeage will go under the deck. I'm planning to cut and hinge the right side to allow easy access to storage.
jer
ID:	729344   Click image for larger version
ID:	729345   Click image for larger version
ID:	729346   Click image for larger version
ID:	729347   Click image for larger version
Jerry Moore, AMA #878954,TARANIS OpenTX- Pantera 600 FB - Pantera .60 FB - Takes a licking and keeps on kicking! KISSAM = Keep It Simple Stupid: Affordable, Maintainable -
Visit Early and often - http://open-txu.org
Jermo is offline        Reply With Quote Quick reply to this message
Old 11-21-2017, 05:43 PM   #2763 (permalink)
Default Epic charge case!!!!
Here is a epic pic of my new charge case.
higham83 likes this.
smcwilliams is offline        Reply With Quote Quick reply to this message
Old 11-23-2017, 03:27 PM   #2764 (permalink)
Dam, I thought my eyes exploded when I opened the attachment. Nice job
Paul
Agile 5.5 - Q 4125-1100, YEP 120, Brain2 HD FBL / Outrage 550 - HK4020-1390, Edge 120, Brain2 HD
Rave Ballistic FSO - Q 4530-500, Edge 160HV, Brain2 HD / Protos Max V2 - MSH 4530-500, Edge 160HV, Brain2 HD
pctomlin is offline        Reply With Quote Quick reply to this message
Old 11-23-2017, 10:34 PM   #2765 (permalink)
Default charge case
We wanted the most epic charge case ever.
Come to OHB and listen for your self.
Audio is second to non.
Even though this is a charge case it sounds better that most peoples home audio!!!!
Scott
Old 11-30-2017, 09:35 PM   #2766 (permalink)
Getting back to making mine and skimmed this thread for ideas. I've seen a few guys use a bus bar type deal for connecting numerous power supplies. What exactly is this called and where are they available? I have 2 IEC outlets with switches on the way. My plan is to connect all 4 supplies to the bus bar and then connect both IEC outlets to it as well. So for home charging I can power each from different circuits because I think they'll share the load. And at the field I can switch one off so the exposed leads aren't hot.
2slow2g is offline        Reply With Quote Quick reply to this message
Old 12-05-2017, 03:58 AM   #2767 (permalink)
Wow guys. Iím part way through my charging case now. How many of you got part way through and wished they hadnít started? 🤦🏻*♂️😩
Sent from my iPhone using Tapatalk Pro
HELI_FUN likes this.
Sneeky_Pete is offline        Reply With Quote Quick reply to this message
Old 12-05-2017, 04:36 AM   #2768 (permalink)
Originally Posted by Sneeky_Pete View Post
Wow guys. I’m part way through my charging case now. How many of you got part way through and wished they hadn’t started? ����*♂️��
I remember when I was half way through and wished I haven’t started at all but when I finished it I was so proud of my project.
If you're feeling somewhat burned out, just put the project aside for a while and then come back to continue with fresh minded.
Carlos
CZorzella is offline        Reply With Quote Quick reply to this message
Old 12-05-2017, 04:38 AM   #2769 (permalink)
Cheers Carlos. Unfortunately my power supplies are in such a state that I canít fly/charge until Iím done.
Old 12-05-2017, 08:10 AM   #2770 (permalink)
How do the cooling fins that people are adding in work?
Do you just hook them up to the power supply or what advice does everyone have for supplemental cooling?
ben_beyer is offline        Reply With Quote Quick reply to this message
Old 12-05-2017, 12:43 PM   #2771 (permalink)
What does that thing weigh!?!?!
Steve
ssmith512 is offline        Reply With Quote Quick reply to this message
Old 12-28-2017, 06:45 AM   #2772 (permalink)
I've been following this thread for a while and read and searched various topics related to charging cases.
I have 2 CellPro 10S chargers that I use. I have a PROTOS 500 currently and a 516 in the box so my charging needs are somewhat basic.
What would be a good case to look at for a 900 watt power supply and both of my chargers plus the charge cables?
Old 12-28-2017, 08:39 AM   #2773 (permalink)
Here is my new case, thank you to Rotor Craft RC for this work of art..
MariaFan likes this.
M3bluegsr is offline        Reply With Quote Quick reply to this message
Old 12-28-2017, 09:05 AM   #2774 (permalink)
Look at Seahorse cases, amazon has a good selection of them. Theyíre the same case that ProgressiveRC sells, only a little cheaper.
ben_beyer likes this.
CrashNburn420 is offline        Reply With Quote Quick reply to this message
Old 12-28-2017, 09:20 AM   #2775 (permalink)
I will do that, thanks!
Old 12-28-2017, 10:18 AM   #2776 (permalink)
home depot has a nice case for 30.00 , works great for mine , has 2 Align chargers , power supply and room for transmitter ..
Dennis Everett is offline        Reply With Quote Quick reply to this message
Old 12-28-2017, 11:44 AM   #2777 (permalink)
Got a link so I see the right one?
Old 12-28-2017, 04:25 PM   #2778 (permalink)
Pics are not visible...
Oxy 2X-VertWarp 360Blade 450XBlade 450X NightflyerGoblin 500 ♦ 2 X mCPX v2 ♦ night fly mQXLadyMQXnano QXnano QX FPVInductrixDX8 G1
Coco66 is offline        Reply With Quote Quick reply to this message
Old 12-30-2017, 06:26 AM   #2779 (permalink)
Thanks fixed pics.
Old 12-30-2017, 07:49 AM   #2780 (permalink)
Thanks fixed pics.
Not really, that's how it looks now:
Why don't you just upload them here in HF?
