Like Tree219Likes
Old 09-21-2018, 06:37 PM   #2841 (permalink)
Hey, Iím changing out my power supplies in my charge case like the below. This time I CBF de-casing my supplies. Because they cases are isolated from each other, do I still need to float the earth in one of the cases? Cheers! 🍻
Sent from my iPhone using Tapatalk Pro
Sneeky_Pete is offline        Reply With Quote Quick reply to this message
Old 09-23-2018, 10:23 PM   #2842 (permalink)
The Hobbys first Casket Charge case. This was a freaking blast to build!!!!!
Casket Charge Case (7 min 6 sec)
I'll fly whatever the hell I want
Bladerunner81 is offline        Reply With Quote Quick reply to this message
Old 09-24-2018, 03:26 PM   #2843 (permalink)
Something a bit different.
ID:	756675   Click image for larger version
Marc
Hirobo Gigas 600E, Xnova/HW 130 V4 HV, CGY760R, MKS HBL950/980
Two Logo 550's, Xnova/HW 120 V4, iKon 2, Futaba S-HC500/BLS276SV/MKS HBL980
Robbe Futura Sport, YS61S/Hatori SB-10, fully functional shelf queen.
Family Guy is offline        Reply With Quote Quick reply to this message
Old 09-25-2018, 09:43 PM   #2844 (permalink)
I like it!
ben_beyer is offline        Reply With Quote Quick reply to this message
Old 09-27-2018, 10:32 AM   #2845 (permalink)
WOW, there are some nice looking charging stations here, My problem is I have enough trouble just wiring an outlet, let alone figure out all this kind of electronic stuff. I just take my I charger and clip on to the charging station at the flying field, turn it on and wait. Not bad, 6s is about the biggest batteries I use
rcinxs is offline        Reply With Quote Quick reply to this message
Old 09-27-2018, 12:14 PM   #2846 (permalink)
https://youtu.be/L_LQS9d7iuo
Whoa! Thatís a seriously spooky charging case. Youíre all set if/when they host a FunFly in Salem, MA.
Nice job.
Bladerunner81 likes this.
got2tinkr is offline        Reply With Quote Quick reply to this message
Old 10-15-2018, 12:37 PM   #2847 (permalink)
Is anyone offering custom decks for the Rigid cases now that BumpCharger.com is shut down?
- Dan G. -
Team Lynx Heli Innovations
darkfa8 is offline        Reply With Quote Quick reply to this message
Old 10-20-2018, 07:26 PM   #2848 (permalink)
Default New Bump controlled charging cases!
Here are some charging cases I made recently. Iíve started making these for others people too - as itís fun!
Malcolm
MMESSITER is offline        Reply With Quote Quick reply to this message
Old 10-30-2018, 03:52 PM   #2849 (permalink)
Default Post your charger case
Just finishing my latest project. This case is very small. Itíll pretty much stay in my work truck for when I travel, so I needed it to be compact, but be able to charge a couple logo 480 packs relatively quickly, running off my 2000W inverter. I can charge a 700 size pack with it if I ever need to. Just gotta tidy up the wires and screw the deck down at this point.
corrosionate is offline        Reply With Quote Quick reply to this message
Old 10-31-2018, 02:10 PM   #2850 (permalink)
Got some new cases. Very happy with the quality and how compact those are.
Name:	Charger Case - 1.jpg
ID:	759808   Click image for larger version
Name:	Charger Case - 2.jpg
ID:	759809   Click image for larger version
Name:	Charger Case - 3.jpg
ben_beyer likes this.
Kontronik, Switch Blades, Bavarian Demon, TDR, TDF, Diabolo, HeliBaby, Takumi and Banshee
im4711 is offline        Reply With Quote Quick reply to this message
Old 11-01-2018, 01:23 PM   #2851 (permalink)
Here is my case:
PSU: 100amp at 25V
built-in chargers: 2 x 25A at 6S
There are plugs for external chargers
Very very happy with how compact this setup is!
ID:	759858   Click image for larger version
ID:	759859   Click image for larger version
ID:	759860   Click image for larger version
terhoutd is offline        Reply With Quote Quick reply to this message
Old 11-28-2018, 02:31 PM   #2852 (permalink)
Has anyone built a case with a GT500?
Goblin Kraken / Protos Nitro / Logo 690 / Logo 480 / Logo 480 Nightship / Protos 380 / Oxy 215
Jeti DS-12 Carbon / Brain2 / Hobbywing v4
DIY Night Blade Tutorial
BuildFlyCrashRepeat is online now        Reply With Quote Quick reply to this message
Old 11-29-2018, 06:12 PM   #2853 (permalink)
Originally Posted by terhoutd View Post
Here is my case:
PSU: 100amp at 25V
How did you manage to mount those ISDT chargers?
reichly is offline        Reply With Quote Quick reply to this message
Old 11-29-2018, 07:40 PM   #2854 (permalink)
Looks like clear double sided tape if you zoom in close enough. The damn things are tricky to mount thatís for sure. Awkwardly shaped.
I mounted mine to the ABS panel with glue called E6000, and made an abs bracket to support it from the bottom. Not sure if itíll last long term or not but weíll see.
reichly likes this.
Old 11-30-2018, 07:10 PM   #2855 (permalink)
Just finished up mine that has the GT1000 Duo.
fastang is offline        Reply With Quote Quick reply to this message
Old 12-01-2018, 01:06 AM   #2856 (permalink)
Photos?!
Old 12-01-2018, 06:41 AM   #2857 (permalink)
Hi
Short answer is yes - the grounds still connect through the AC mains
Protos Evo 770 | X7 Tri | Black Thunder | G500 Tri | X4II stretch | X3 | Oxy3 TE - DS16 - Brain2 |
AUS_Gremlin is offline        Reply With Quote Quick reply to this message
Old 12-01-2018, 06:47 AM   #2858 (permalink)
Take 2
Yes, you still need to float one PSU - ground will connect through ac mains
Old 12-03-2018, 03:26 AM   #2859 (permalink)
Yes I just used some 3M double sided tape. This thing is super strong!
My case is clearly not the neatest, but I would bet it has the best power output to size ratio of any of the cases that have been posted here.
Old 12-03-2018, 06:12 AM   #2860 (permalink)
My charge case with pelican 1550 2no power paraboards .usb with voltage. 2no blue led 80mm fans .2no 750 watt pay. Icharger 406 duo sprayed black satin. Carbon wrapped deck and lid panel. Blue led to perimeter of lid .self made
ID:	763399   Click image for larger version
ID:	763401   Click image for larger version
ID:	763403   Click image for larger version
karl1081 is offline        Reply With Quote Quick reply to this message
