Like Tree222Likes
Old 03-04-2021, 09:32 AM   #2981 (permalink)
Originally Posted by xoexoe View Post
Yeah I do suppose thatís the right question. Iíll find out next time I go flying.
Need to figure out a way to store some charging adapters i made (XT60 to XT90) and the power cord.
If you have the room, scroll up for some ideas on storing in the underside of your lid. That's where all mine go. Balance cable extenders help a lot also.
xoexoe likes this.
-Ben
Old 03-04-2021, 02:59 PM   #2982 (permalink)
Originally Posted by Hydros27 View Post
My charging case is very basic. Two thirds of it is storage, there is a 24 volt power supply and a fan under the shelf, and the chargers are attached to the shelf with magnets for easy removal.
The more I look at your charging case the more I like it. Where did that plastic shield over the PSUs come from?
ó XLP Specter V1, XLP 550, Oxy 4 Max, Oxy 2, OMP M1 ó
ó Spirit GT ó Egodrift & XNova, YGE & Scorpion, FrSky Horus OpenTX ó
ó WTB XLP Wraith for cheap ó
xoexoe is online now        Reply With Quote Quick reply to this message
Old 03-04-2021, 03:22 PM   #2983 (permalink)
Originally Posted by Konna View Post
Heres mine little case. Two HP 750w Power suply feeding 2 ISDT Q8 Max chargers. Nice and compact setup for me.
Kona, on the inner part of the top case you have that elastic material running around some plastic knobs that are attached to the case. Two questions, what are those knobs, are how are they attached?
Old 03-06-2021, 02:32 PM   #2984 (permalink)
Originally Posted by jrman83 View Post
Congrats and nice work! Big question is, how is it working for you? I built mine to just get the charging out of my house easily.
Itís perfect. All parts work as expected.
jrman83 likes this.
Old 03-06-2021, 06:02 PM   #2985 (permalink)
I see you solved your charge lead storage problem.
xoexoe likes this.
-Ben
Old 03-06-2021, 06:47 PM   #2986 (permalink)
I built it out of a piece of textured ABS from TAP Plastics. I clamped it to the metal table of my bandsaw, heated it with a propane torch, and bent it to 90 degrees with a 2x4. The Pelican case has built in supports for the shelf and magnets glued to the bottom of the plastic hold it to the power supply.
xoexoe likes this.
Hydros27 is online now        Reply With Quote Quick reply to this message
Old 03-06-2021, 11:15 PM   #2987 (permalink)
Why on earth(pun intended) do you have a portable generator grounded?
Goblin Kraken / Specter v2 / Protos Nitro / Logo 480 / Logo 480 Nightship / Protos 380 / Oxy 215
Jeti DS-12 Carbon / Brain2 / Hobbywing v4
DIY Night Blade Tutorial
BuildFlyCrashRepeat is offline        Reply With Quote Quick reply to this message
Old 03-06-2021, 11:37 PM   #2988 (permalink)
Default Post your charger case
Itís for grounding the equipment that the generator powers. Might as well make that third grounding wire useful.
Edit: looks like thereís quite a bit of info online as to whether grounding is needed. My instruction manual seemed to indicate it was. Got some reading to do I guess.
Old 03-10-2021, 09:04 AM   #2989 (permalink)
So this ones pretty crude, likely not what most people come to this thread to see, but Iím excited about it, after a little experimenting with other options. I do have a couple much more elaborate cases I made but I wanted the most compact yet versatile setup I could get, for charging Logo 200 packs when occasionally traveling. I think I achieved that.
My specific goals were:
-charge up to 6 Logo 200 packs in parallel at 1C or higher
-small enough I can throw it in a pocket or bag to carry hands-free into hotels and doesnít take up much truck space if I leave it in the truck
-cheap enough and low enough effort to build that I wonít be heartbroken if it gets stolen out of the truck at a hotel overnight (the heli and Transmitter go to the room with me)
-both AC and DC power source so I can use it in the truck or hotel/office, etc.
It works great for all those things. Fits in cargo pants pocket or laptop bag. can charge on my center console while driving. I can charge 6 logo 200 packs at greater than 1C, or a couple Gaui x3 or Goblin Buddy packs if I decide to haul a bigger heli around. Got less than $100 in the whole setup, if you figure the ISDT 608 charger that came with the power supply stays at home.
I keep being tempted to make it a more monolithic unit where I donít have little bits that could fall out and get lost, like everythingís mounted somehow but then it would quickly start to defeat the goal of being cheap and simple.
Thought Iíd share, it was tough for me, to piece something together with no fluff, from a specific goal-oriented standpoint and resist the urges to load it up with bells and whistles. I donít do moderation well, but Iím aware of that and try to strive for it ;-)Click image for larger version
xoexoe likes this.
corrosionate is offline        Reply With Quote Quick reply to this message
Old 03-10-2021, 09:53 AM   #2990 (permalink)
Perfect application for that tiny charger. Very nice.
Old 03-10-2021, 11:05 PM   #2991 (permalink)
Good stuff Nate. Glad to see you’re still flying
bgymr is offline        Reply With Quote Quick reply to this message
Old 04-10-2021, 02:07 PM   #2992 (permalink)
For the power ON switch, are you guys using a "straight" switch connection or a relay switch?
14S Tron 7/Protos 700X Evo/Kraken; 7S Kraken 580/Logo 550SX V2; 6S Buddy 380 KSE
VBC Touch & Neo Vlinks, YGE "T" ESCs; AGM Deep Cycle Batteries
Sims on Mac: Heli-X, neXt, AccuRC, RF9, Phoenix, AeroFly RC7 Ultimate
Amain Field Representative
jhamel is offline        Reply With Quote Quick reply to this message
Old 04-10-2021, 06:05 PM   #2993 (permalink)
Switch? My switch is plugging it in.
-Ben
Old 04-10-2021, 06:22 PM   #2994 (permalink)
No switch here, the power supply goes on when it's plugged in or the generator is started.
Number likes this.
Old 04-10-2021, 07:13 PM   #2995 (permalink)
Yeah, just unneeded point of failure IMO. I know some people prefer to have a switch, but for me, I don't mind just... unplugging it when I'm done.
Keith - XLPower | KST | Egodrift | KC3D
Protos 800X Evoluzione | Protos Nitro | Specter V2 | Protos 380 Evoluzione V2
Number is online now        Reply With Quote Quick reply to this message
Old 04-13-2021, 08:06 PM   #2996 (permalink)
I use relays as part of a custom designed protection circuit which is designed to safe guard my charger and the PSU against damage when any of the following events happens:
(a) High amp spike
(b) High inrush current
(c) Power outage causing unexpected PSU shut down
(d) Under voltage protection
(e) Over voltage protection
(f) Over temp shut down gauged by 7 probes
Basically you turn the power switch on and the protection circuit takes charge powering the fans; after 5 seconds the PSU is powered and then a few seconds later it powers both chargers.
The beauty part is that if the power goes off or any of the above mentioned incidents happens, the relays resets so when the power comes back on the PSU and charger don't automatically turn on which means I can disconnect the batteries if any are on, turn off the charger and restart everything afresh so I can make sure everything is ok first. The fans, however, are kept turned on so you still maintain cooling.
Carlos
CZorzella is offline        Reply With Quote Quick reply to this message
Old 04-13-2021, 08:25 PM   #2997 (permalink)
I gave it some thought. I opted for a simple "in-line" illuminated switch. It is a C20 size, so it should be able to withstand more current than the more common C14 size adapater used with most charging cases I've seen.
Name:	Screen Shot 2021-04-13 at 21.15.17.jpg
Old 04-13-2021, 08:52 PM   #2998 (permalink)
Does anyone use lipos as a imput as a feild charger?
Sent from my SM-G988U using Tapatalk
Jstncoffman1028 is offline        Reply With Quote Quick reply to this message
Old 04-14-2021, 07:57 AM   #2999 (permalink)
Yes I have one box with a 6S 10,000mAh LiPo
I used for a purpose other the heli Its for the Jets RX and ECU batteries, charge up its good for a at least a 3 days of recharging a jet or 2 ...
It also has a small power supply to used instead and to recharge the LiPo inside.
Name:	Small charger.JPG
ID:	913081   Click image for larger version
Name:	Small charger1.JPG
ID:	913083   Click image for larger version
Name:	Small charger2.JPG
ID:	913085   Click image for larger version
Name:	Small charger3.JPG
Daniel...many flying planks.....Goblin Urukay Red/White, Gaui R5,G380 KSE Yellow/Blue
G380 Stretched and G420 XNova
JETI DC-24, MKS Servos, Ikon2/Brain2, Axon, Kontronik, XNova
Revolectrix/MeanWell PS, DPL8, PL8, 2x XP10 and Bump Contr's.
Dansy is offline        Reply With Quote Quick reply to this message
Old 04-18-2021, 01:25 PM   #3000 (permalink)
My in progress case completely diy
