Like Tree222Likes
Old 04-18-2021, 01:35 PM   #3001 (permalink)
For now it's does what I need and is both ac dc powered, only need to plug in the ac and the relay setup I have automatically turns off the dc lioo packs, but so far functional, have 4 more 6000mah batteries on the way along with a Para board and more textured plastic for the lid, my plan was to have a feild box and a charger at the same time , hate making numerous trips from the car, but I will post more updates,
Sent from my SM-G988U using Tapatalk
Jstncoffman1028 is offline        Reply With Quote Quick reply to this message
Old 04-19-2021, 08:48 PM   #3002 (permalink)
Originally Posted by curmudgeon View Post
For the power ON switch, are you guys using a "straight" switch connection or a relay switch?
Neither. My power supply has pins for a "soft" switch.
Jeti DS14us -- TT e700 -- 6s Logo600se UL -- Logo600-3d -- Logo500 UL -- Charge Case
prototype3a is offline        Reply With Quote Quick reply to this message
Old 04-19-2021, 10:54 PM   #3003 (permalink)
Use a 40 amp 24v relay
Old 04-19-2021, 10:55 PM   #3004 (permalink)
Or if it's on the ac side a potential relay can be used , they vary is size and load capability
Old 04-19-2021, 10:56 PM   #3005 (permalink)
I also use relays to control wich circuit I want "normaly open or "normaly closed, 1 relay can do both if wired correctly along with some diodes
Old 04-19-2021, 10:57 PM   #3006 (permalink)
Ops quoted myself lmfao
Old 04-20-2021, 11:41 AM   #3007 (permalink)
The power supplies I use are VERY clever with input and output sensing and micro-controllers inside running everything so a soft switch that interfaces with the microcontroller is just dead simple to add.
I do use some "locking" switches so you can't accidentally bump the switch and turn it on/off.
I'm honestly not sure if I ever posted here about them. Artesyn UFE1300-24. You can find them on ebay for less than $100 which is pretty good for a ~27v / 1500w industrial psu.
I also designed and had a pile of output PCBs made for them.
Old 05-29-2021, 11:49 PM   #3008 (permalink)
My newest build. Two ISDT P20s in a Nanuk 910. Totaling 1600/2000W maximum. Currently has HP power supplies but plan to swap with a Mean Well at some point.
ID:	919621   Click image for larger version
ID:	919623   Click image for larger version
ID:	919625   Click image for larger version
Keith - XLPower | KST | Egodrift | KC3D
Protos 800X Evoluzione | Protos Nitro | Specter V2 | Protos 380 Evoluzione V2
Number is online now        Reply With Quote Quick reply to this message
Old 05-29-2021, 11:58 PM   #3009 (permalink)
Great placement of charging ports. Well done Keith!
xoexoe is online now        Reply With Quote Quick reply to this message
Old 05-30-2021, 01:16 PM   #3010 (permalink)
Originally Posted by Number View Post
My newest build.
That 3dprinted riser is a nice solution.
Number likes this.
Old 07-16-2021, 07:10 PM   #3011 (permalink)
Default 1000W Nanuk 910 with Storage
Just finished this one. Nanuk 910, two ISDT Q8, Mean Well LRS-1000-24. 3D printed deck as per usual from me. Magnetic storage compartment included.
ID:	924465   Click image for larger version
ID:	924467   Click image for larger version
ID:	924469   Click image for larger version
Old 07-16-2021, 08:13 PM   #3012 (permalink)
Default Post your charger case
Looks great.
Old 07-17-2021, 11:19 AM   #3013 (permalink)
My charger storage case
Nanuk 918 case
This is how I generally transport it in the car
I keep two iCharger 380 Duo's and two S1500 Chargery 24V 1500Watts power supplies along with all needed wires.
When I get to the field, it takes me very little time to setup and charge.
ID:	924535   Click image for larger version
ID:	924537   Click image for larger version
ID:	924539   Click image for larger version
Tron 7 (14S), Protos 700X Evo (14S), Kraken (14S)/Kraken 580 (7S)/Buddy 380 KSE (6S), Logo 550SX V2 (7S); YGE "T" ESCs; VBC Touch & Neo Vlinks, AGM Deep Cycle Batteries
Sims on Mac: Heli-X, neXt, AccuRC, RF9, Phoenix, AeroFly RC7 Ultimate
jhamel is online now        Reply With Quote Quick reply to this message
Old 07-18-2021, 09:15 PM   #3014 (permalink)
I built this charging/storage case during our long covid lockdown this Spring. I was looking mainly for something to make it easier pack up and head to the field and came up with a variation on the charging case idea.......more of a field tote. But it does contain everything I need to charge, so I guess it belongs in this thread.
Two 40 Ah LiFeP04 batteries are on the bottom shelf to power an iCharger 106b. These batteries are 12 lbs each.
The bottom drawer contains charger and all charging accessories.
The top shelf has tools and such.
The top compartment hold the lipos.
There's a removable side compartment for the transmitter.
To start charging, open the drawer, drop the cables under an plug into the LiFeP04s. I usually do this the moment I arrive at the field so it's charing while I unpack.
Works well for my routine since I don't like to charge at home and I have no power at my field.
ID:	924759   Click image for larger version
ID:	924761   Click image for larger version
ID:	924763   Click image for larger version
ID:	924765   Click image for larger version
minicopter Diabolo, Spirit, AR8010T, Xnova, Castle
Logo 550SE, Castle, Xnova, Spartan VX1e
Oxy4 Max, Spartan VX1e
iCharger, deep cycles, DX8 G2, AccuRC
CFerry is online now        Reply With Quote Quick reply to this message
Old 07-22-2021, 09:34 AM   #3015 (permalink)
Figured this would be the best place to ask, as I'm looking to build a charger case.
Does anyone have a step file for the iCharger 4010 duo? Or know where I can find one?
Team Horizon
Team Amain
My YouTube Channel
MikelG is offline        Reply With Quote Quick reply to this message
Old 07-22-2021, 02:11 PM   #3016 (permalink)
Junsi will not provide CAD models. In fact, they act as if the molds for their charger cases were hand carved or something....
On the other hand, I have received full models for various Revo chargers.
Old 08-06-2021, 07:25 PM   #3017 (permalink)
I am curious how many guys using a Meanwell 24 volt supply are turning the voltage adjustment screw all the way up or just leaving it where it comes from the factory?
Align Trex 700 V3 DFC HV Vbar Pro - Vcontol Touch Mikado Logo 200 SAB Kraken 580 Vbar Neo Align Trex 500X Vbar Neo
Raydee is offline        Reply With Quote Quick reply to this message
Old 08-07-2021, 03:01 AM   #3018 (permalink)
CHC Benefactor
I have one as well as a 48V Meanwell. Not a bad idea. I was thinking of doing that originally but then got the 48V. If I remember correctly the adjustment has more latitude downward than up.
Old 08-07-2021, 04:53 AM   #3019 (permalink)
I think it will adjust maybe 10%
Old 08-07-2021, 09:10 AM   #3020 (permalink)
I did on my RSP-3000-24. It stops the PL8’s I use going into the buckboost bounce when charging 6s packs.
//Dennis.
Raptorapture likes this.
soXos Strike7 : soXos 600 : soXos 550 : soXos F3C 800
Protos 380 : soXos DB7 nightflyer : Jeti DS-16 & DS-12 : Mini Protos FBL Stretch : Logo 600
I am www.soxosaustralia.com.au | VTX blades | 1st-RC Products | EGODRIFT motors
Thunder Fighter is offline        Reply With Quote Quick reply to this message
