Go Back   HeliFreak > R/C Helicopter Support > KDE Direct Upgrades and Accessories
KDE Direct Upgrades and Accessories KDE Direct Upgrades and Accessories Factory Support Forum
Old 09-16-2011, 12:39 PM   #21 (permalink)
Patrick is right, I just installed the Align 700 V2 Tail Assembly.
1. This is on a wag free 700E with VBar that has the 600N Plastic Tail.
Removed Plastic Tail Assembly.
Installed Align V2 Tail - (Bought from Ebay seller in Taiwan)
1. First Flight fine
2. 2nd Flight WAG
Removed V2 Tail, refitted Plastic Tail, Wag gone.
Synergy N5C sitting in Box...
Mystic3D is offline        Reply With Quote Quick reply to this message
Old 09-17-2011, 09:34 AM   #22 (permalink)
Another freak in the 700E forum had the great idea and fitted 450 Pro main shaft shims between the radial and thrust. I tried it this AM and fits perfect. Now just need some testing.
Old 09-17-2011, 09:40 AM   #23 (permalink)
I thought I found where to buy just the shims but it looks like they were the wrong size. Only way to get the Align spacers is to buy the 450 pro main shafts it seems.
xStatiCa is offline        Reply With Quote Quick reply to this message
Old 09-17-2011, 11:00 AM   #24 (permalink)
https://www.helifreak.com/showthread.php?p=3252218
Old 09-17-2011, 09:02 PM   #25 (permalink)
Sorry guys I'm lost here. I just bought the V2 tail assembly for my V2 700. What is the mod I should be doing to eliminate wag? Can I simply buy a KDE upgrade to take care o the problem?
Thanks for helping this knucklehead
S
Trex 470LP / Beastx / Align BL50X / Align 470MX
Trex 500X / Beastx / Align RCE-BL80X / Align 520MX
smaze17 is offline        Reply With Quote Quick reply to this message
Old 09-17-2011, 09:05 PM   #26 (permalink)
S
Maze - No one really Knows Yet. We have theories about the shims, but untill we get a few positive reports back, pretty non conclusive.
The KDE Upgrade does not solve the problem.
Old 09-17-2011, 09:27 PM   #27 (permalink)
Team Taco VP
I cant believe Align messed this part up? Maybe they just forgot to package the shims in the V2 tail kits?
Bob
Old 09-17-2011, 09:57 PM   #28 (permalink)
Not to mention they put tail blade bolts in that are too short to go through the plastic of the lock nut. 2 problems with this product.
I had to order 2 18mm bolts because the 16mm that come with it are too short.
Old 09-18-2011, 03:58 PM   #29 (permalink)
Ok thanks man. Guess I will just take my time assembling the 700 and see what transpires
S
Old 12-09-2011, 09:08 AM   #30 (permalink)
any videos on installing the 450 tail upgrade ver on trex 450 helis?...
All begins (Jun 2011).......
Next project:
MSH Mini Protos, 450 Scale Airwolf, BAH Mini Quad
cpmboy is offline        Reply With Quote Quick reply to this message
Old 12-27-2011, 08:26 AM   #31 (permalink)
Nice series Bob! I did this conversion on my 700 a few months ago and have a couple of notes to add that I encountered in installing this mod.
I totally agree with you about having that spacer for the pitch slider assembly included in the kit. That can't be more than a 50 cent part and having to destroy your original to get it... I didn't use the heat method as you did - I just tapped one of the bearings out, which of course destroyed it - but you said that even using heat you ended up damaging yours also, so what's the point of doing that to retrieve that silly spacer? It should be included as part of the upgrade.
The one problem that I had that you didn't mention is that the mounting "Bolt", as they call it - the part that mounts to the side plate in place of the original. In my kit it had been machined too long in the vertical direction so it would not fit down into the recess in the side plate, causing it to rock to one side or the other when I would tighten the mounting bolt. I ended up having to file off about 1 mm of material to get it to seat properly in that recess.
The other difference I had was that the pitch fork was not nearly so tough to get off of mine. No heat, just a bit of elbow grease to break that red loctite loose and it came apart nicely.
I did the performance pitch upgrade on it as well (along with most of the other KDE upgrades and I have to say that I've been quite impressed with the quality of their products. I even did the performance pitch upgrade on my 450's and noticed a slight improvement in response, but what I think is more beneficial is that running in bearings rather than bushings, things should last much longer with less wear and fewer adjustments being necessary as a result.
Again, nice series and look forward to more!
ProtoDewd is offline        Reply With Quote Quick reply to this message
