Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mCP X Brushless Mods
mCP X Brushless Mods Blade Micro CPx Brushless Mods and Conversions
Old 07-24-2011, 08:46 AM   #241 (permalink)
Almost have every thing for mine!
Blade MCP-X Brushless, 300CFX, , Trex 450 Pro v2, Trex 600 ESP 6s 3GX v.3.1 and KDE head, Trex 700 Nitro, E-Conversion, Futaba 12Z controle!!
Stevendavis is offline        Reply With Quote Quick reply to this message
Old 07-27-2011, 08:26 AM   #242 (permalink)
Any news on the WowHobbies BL kit?
I would be interested in an all in 1 solution
TheMaxx is offline        Reply With Quote Quick reply to this message
Old 07-27-2011, 09:54 AM   #243 (permalink)
Blade Forum Support
Haven't heard anything yet. They may post it up here when they get it
Sent from my DROIDX
Jesus Rep Its all Good,Its all GOD
FPV Everything Now
GOD BLESS
tntburnett is offline        Reply With Quote Quick reply to this message
Old 07-28-2011, 12:47 PM   #244 (permalink)
Got every stuf now. will start the conversion this day!!
Old 07-28-2011, 05:37 PM   #245 (permalink)
Got the frame modified and the motor mounted.
ID:	242959   Click image for larger version
Old 07-28-2011, 08:06 PM   #246 (permalink)
Just make sure you turn your skids around. Lol
Goatkeeper is offline        Reply With Quote Quick reply to this message
Old 07-28-2011, 08:59 PM   #247 (permalink)
Yep, caught that. Thanks for the heads up!!
Old 07-29-2011, 07:18 AM   #248 (permalink)
Blade Forum Support
I see you are getting it right :-). Have a blessed week.
Sent from my DROIDX
FPV Everything Now
GOD BLESS
Old 07-30-2011, 12:09 AM   #249 (permalink)
Got the mod done and every stuf is working great. I should have cleaned my servos while I had it all apart. I ended up taking the servos back off and cleaning them anyway.
ID:	243221   Click image for larger version
ID:	243222   Click image for larger version
ID:	243223   Click image for larger version
Old 07-30-2011, 12:47 AM   #250 (permalink)
Blade Forum Support
Yea it is toc clean them whlie u had them off ;-). Ready to see it fly :-).
Have a blessed week
Sent from my DROIDX
FPV Everything Now
GOD BLESS
Old 07-30-2011, 01:01 AM   #251 (permalink)
I did this mod a little while back With a walkera inrunner, 9 tooth pinion, and 7amp esc. The tail wasn't holding so I did the SR tail mod. I had a chat with a very experienced pilot and here's what i came away with.
Without adding ballast, I really don't think it's possible to get the CoG right with that big mother hanging off the end of the boom. The SR tail is too powerful even with the brushless mod. There's no reason to run the thing at 100% throttle.
I had great results with the following setup:
1. Stock tail motor on extended solid boom
2. Stock tail blades - still experimenting
3. 85% flat throttle curve
4. Pitch end points at 65 each way
Now your not going to get ballistic pitch pumps with set up but it's much mor flyable.
I'll put a 7 tooth pinion on it at some point and run 100% throttle. It's more efficient that way.
If your having trouble give it a try.
Ken
Lipper is offline        Reply With Quote Quick reply to this message
Old 07-30-2011, 07:31 AM   #252 (permalink)
Yes, using the 120SR motor does make it tail heavy, but unless you simply sit and hover all day, you wouldn’t notice a CG issue in flight....especially one so menial. If you have your lipo mounted as far front as possible along with your esc and BL converter it helps to greatly offset the heavier 120SR tail.
I have yet to hear of a successful BL conversion using a stock tail with success. IMO turning down the pitch travel to 65% is not considered success, its compromising so as to keep the stock tail. You basically are restricting the BL conversion potential b/c the stock tail is so weak.
TBS Discovery
Rave 450 FBL - miniVbar
Trex 500 ESP FBL - Beastx
Trex 600 ESP FBL - Beastx
adroc3905 is offline        Reply With Quote Quick reply to this message
Old 07-30-2011, 09:39 AM   #253 (permalink)
I am running the stock tail with the CO5M motor 8t pinion,I have pitch travel at + - 85%.I can blow the tail but only with the most extreme collective bungle.I am very happy with this setup.I can do repeated flips high speed funnels and full pitch punch outs and the tail holds fine..Just sayin..
700 class nitro,2X 600class electric,2X 450class,250 class,130 class,a few mcpx class().Dx-7.All helis fbl...If I had a dollar for every dollar I've spent on heli's ...I would break even.
.Who is John Galt?
755 robert is offline        Reply With Quote Quick reply to this message
Old 07-30-2011, 10:57 AM   #254 (permalink)
I had the same experience as adroc with my conversion. Had to turn the pitch travel down in the 60's or the stock tail would still blow out. I now use the sr120 tail motor and full blade with zero wag. It flies great I love it!
Nytflyer is offline        Reply With Quote Quick reply to this message
Old 07-30-2011, 12:42 PM   #255 (permalink)
I have the SR 120 tail assembly, but have not installed it yet. I want to see how the stock with extended boom holds up. Just put about 5 flights on and the tail is holding good for now. I'm also only running about 65% pitch though. Mine flips fine so far. I even messed one up by not using high rate elevator and had to go full up while it was rocketting twords the shed, and no tail issue. I also just installed the MH swash to see how that will work with the brushless, Had to re-do my pitch curve, but its working great for now as well.
Old 07-31-2011, 09:16 AM   #256 (permalink)
I just finished installing the helimax BL motor and speed control just like TNT's setup. I wired it to the small point on the back of the 3-1. Everything works great for the most part. Every once in a while the motor won't start but I think that was due to the gear mesh being too tight. It has loosened up now and seems fine. I haven't flown it yet other than test hovering in my driveway since it was dark out when I finished it but I can already tell that some Tx adjustments are in order. This thing has MAD power!
TNT (and anyone else that wnats to comment) - What are you running for throttle curve, pitch ATV, etc? What kind of headspeed/flighttime are you getting with those settings? Again, I have the Helimax Novus CP BL conversion w/ 9 tooth pinion and am using nano techs.
I would like to thanks everyone here that made this possible as well, you guys are great.
Align 450 Pro
Align 250 DFC
Blade 180CFX
learjet3 is offline        Reply With Quote Quick reply to this message
Old 07-31-2011, 02:09 PM   #257 (permalink)
Blade Forum Support
You are welcome glad toc share The info :-).
I am running a flat 100 for my throttle and my ATV is for pitch is 85 % my time is 6 1/2 mins but I am using The sr120 battery which is 500mah.
Hope this help
Have a blessed week
Isaac
Sent from my DROIDX
FPV Everything Now
GOD BLESS
Old 07-31-2011, 05:03 PM   #258 (permalink)
I am having problems getting the BL motor to start. When it does it flies great, but when it doesn't it don't fly at all. I powered thesteve off the ESC, blue-black, red-red, white-white, yellow to the small point on the back of the board. Powered the ESC right off the battery points on the board.
Align 450 Pro
Align 250 DFC
Blade 180CFX
Old 07-31-2011, 06:45 PM   #259 (permalink)
Try moving the red wire of the Steve to the large red wire going to the main board positive power connection. That should help.
Good Luck, Don
dbennettya is offline        Reply With Quote Quick reply to this message
Old 07-31-2011, 06:53 PM   #260 (permalink)
A stock tail setup should hold at lower BL HS rpms. In your case you run a lower HS than I do using a 8T pinion. I have the Helimax motor with a 9T pinion so the stock tail would not hold unless I reduced the pitch down to 65%. With the 120SR tail I can run at 95% pitch with no issues.
My point is that yes a stock tail would work on a BL setup but at what cost? If you have to tone the heli down to the point of greatly reducing pitch travel….what’s the point? You are not seeing the full BL potential b/c you are restricting it to compensate for the weak tail.
TBS Discovery
