Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mCP X Brushless Mods
mCP X Brushless Mods Blade Micro CPx Brushless Mods and Conversions
Old 06-19-2011, 10:26 AM   #21 (permalink)
Does this method of wiring thesteve converter work with any ESC? I saw in the sticky by so-fly this is how he wired the converter also but was using the same esc motor combo. Seems like this method is so much easier than soldering to the board, are there any disadvantages?
khogan is offline        Reply With Quote Quick reply to this message
Old 06-19-2011, 12:00 PM   #22 (permalink)
Blade Forum Support
It will work with any esc :-)
Sent from my DROIDX
Jesus Rep Its all Good,Its all GOD
FPV Everything Now
GOD BLESS
tntburnett is offline        Reply With Quote Quick reply to this message
Old 06-19-2011, 02:05 PM   #23 (permalink)
Thanks for sharing, this mod just got a whole lot easier.
Old 06-19-2011, 02:56 PM   #24 (permalink)
You get the elusive SkrappaR seal of approval. Great job my friend. I may actually give this a go.
-Joe
"Helis - wallet weight reduction made easy"
HeliArt Jskrapper @ youtube
Jskrapper is offline        Reply With Quote Quick reply to this message
Old 06-19-2011, 03:10 PM   #25 (permalink)
Blade Forum Support
Thank you
Old 06-19-2011, 06:50 PM   #26 (permalink)
TNT do you know if that speed controller works OK with other motors?
I have the C05M Micro brushless outrunner 11000kv on the way from Hobby King but in Canda the post office went on strike so it may be a while. I was planning on ordering another speed controller but now with the strike I found they have the one you used at the LHS for $10
Old 06-19-2011, 06:52 PM   #27 (permalink)
TNT,
Thanks for keeping us abreast on your work, great job to you and the other brushless leaders
Great job, my friend
Trex 550e 3G stre....tched to a 600 Cam Ship hauling a GoPro, Sony sn777, or Nikon D3100 all downlinked / trex250 for backyard 3D (mild+)... Fun little bird / blade mcp x... You DON'T have one yet?????
Uncle Sir is offline        Reply With Quote Quick reply to this message
Old 06-19-2011, 07:33 PM   #28 (permalink)
Blade Forum Support
Yea it should work fine it is a 10 amp esc so yes it should be fine
Old 06-19-2011, 07:36 PM   #29 (permalink)
Blade Forum Support
Originally Posted by Uncle Sir View Post
TNT,
You are welcome. That's what we are for to help each other out
Old 06-20-2011, 05:07 PM   #30 (permalink)
Thanks for the link TNT. I'll try the conversion out.
swiftyflyer is offline        Reply With Quote Quick reply to this message
Old 06-20-2011, 07:36 PM   #31 (permalink)
Two of my Walkera 10A ESCs would not start the C05 motor but work fine with HP08-2 motors. The AeoRC 5A esc starts the C05 motor fine and works good. Amp is using this ESC also with good luck.
So I'd recommend the AeoRC 5A or the eBay 7A ESCs ( I haven't tried the eBay 7A ESC).
YMMV, Don
dbennettya is offline        Reply With Quote Quick reply to this message
Old 06-20-2011, 08:03 PM   #32 (permalink)
Blade Forum Support
YMMV, Don
Good catch buddy. I find it odd that a 10 amp esc wont start the motor a 5amp will very odd. Unless it need a resistor on it between the yellow and blue on the Steve converter Oh or on the converter you are running. Are you using the converter u had in the picture you showed me that converter may not be strong enough to run it.
Old 06-20-2011, 08:47 PM   #33 (permalink)
I'm sure Don can explain alot better than I but different motors need different timing. They also need different starting power and current supply. Inrunners are generally very easy for esc's to start. Outrunners are generally harder, and they can have a variety of magnet/stator teeth arrangements that also come into play.
Some esc's allow for this with programming paramiters for start power and pole count as well as other variables. High Kv 1s outrunners are some of the trickiest to start and run at the full rpm reliably.
Amp
Ampdraw is offline        Reply With Quote Quick reply to this message
Old 06-20-2011, 08:51 PM   #34 (permalink)
Blade Forum Support
Amp
Well put :-). I didn't think of that.
Sent from my DROIDX
FPV Everything Now
GOD BLESS
Old 06-20-2011, 09:59 PM   #35 (permalink)
Thanks guys, this is probably the exact same as the Walkera one so I am guessing it will behave the same.
Anyone know where can I buy the AeoRC 5A? (preferably with Canadian shipping that is not outrageous) If i can't find it I know I can get the ebay ESC at wowhobbies at least. Griff1 was using this so it should work fine.
Do I need any other devices to program the ESC or can I do that with my remote?
Now I just gotta find a pinion and I am all set (trying to avoid paying the $20 shipping to get the pinion from bphobbies)
Old 06-20-2011, 10:17 PM   #36 (permalink)
+1, good explaination Amp.
BTW, I did test the negative pitch thrust of the mCP X with C05 1mm shaft 8T stock pinion and got 95g but I don't know exactly what the pitch was as I was manually adjusting the servos and running the C05 motor and AeoRC 5A esc from my RX2609 Walkera receiver just testing. I'm waiting for my the Steve converter
Don
Amp
Old 06-20-2011, 10:24 PM   #37 (permalink)
Hi guys!
I just have a few questions..
I got the walkera (helimax) brushless conversion ordered (the one linked in the OP)
But wanted to know if this converter would work and how to hook up would be since theres jus 1 wire and a male futaba at the other end.
(I live close to the wowhobbies warehouse and could pick it up)
http://www.wowhobbies.com/thestevebl...nverter-1.aspx
Also I can't find the 9t pinion anywhere.. Anyone know where I could pick one up?
Would the stock 8 pinion work?
Thanks guys!!
Btw.. How long did shipping take everyone who got the steves converter from thesteve.ca to get the converter?
Souskei is offline        Reply With Quote Quick reply to this message
Old 06-21-2011, 02:34 AM   #38 (permalink)
Originally Posted by Souskei View Post
Hi guys!
Thanks guys!!
The three pin futaba style connector is going to be power + - and signal out while the wire by itself will be signal in.
However it may not work properly as it was programmed for walkera rx signal which is vastly different to the Mcpx.
Me, I wouldn't take the gamble. It'll be heavier too.
My converter was shipped the same day and got to Aus in ten...can't complain there.
The wk003 motor has a 1.5mm shaft so the stock 1mm bore pinion won't work and there's not enough meat to drill it out unless you are a pro on a mini lathe. I buggered up one trying to hand drill it super carefully!
Amp
Old 06-21-2011, 02:52 AM   #39 (permalink)
Amp
Thanks amp!
Yea I'm still trying to get the pinion somewhere or a least the part number for the gas pinion (I work at a Hobbytown so if onl I had the part number..)
I'm just gonna try to drill the stock one with a 1.5 bit if i can't find the 9t anywhere
And yeah I didn't risk getting the futaba plug converter from wowhobbies (wish they had the steve one in stock) so I just ordered one from thesteve.ca and hopefully it'll get here before 10 days since im in California.
Old 06-21-2011, 06:41 AM   #40 (permalink)
Blade Forum Support
Thanks amp!
Have you tried BPhobbies.com for the pinion and the mod is 0.3 for the pitch
Sent from my DROIDX
FPV Everything Now
GOD BLESS
