Old 02-14-2012, 12:16 PM   #61 (permalink)
Smile
Originally Posted by The Dentman View Post
I would like to see this also as I have just built a 500 efl pro and need to set up my electronics.
Dentman, scroll down to page 3 #21 post Michael's 500 setting it should be very close to the DX8 settings
Sabre22 is offline        Reply With Quote Quick reply to this message
Old 02-18-2012, 11:35 AM   #62 (permalink)
Originally Posted by Ebartolome View Post
Here you go
Trex 600EFL PRO
Align DS 610's on cyclic
DS650 on the tail
Castle ICE2 HV120
Align 600m
Align FBL head
Spektrum AR8000 RX
Spektrum DX8 TX
Transmitter mode
20% expo on aileron and elevator
10% expo for the tail
100% ATV for aileron and elevator
100% ATV for the tail
40% transmitter gyro gain
Parameter menus
B Control behavior - Transmitter (Blue)
C Pitching up behavior - Medium (Red)
D Headlock gain - Low (Red Flashing)
E Stick deadband - 2 (Red Flashing)
F Torque Precomp - Off (Purple)
G Cyclic Response - Normal (Purple)
H Pitch Boost - Off (Purple)
wich led is lit when it is 40% transmitter gyro gain ?
i guess that it won't be 40% in my futaba 8fg?
simonarvestrand is offline        Reply With Quote Quick reply to this message
Old 03-09-2012, 11:17 PM   #63 (permalink)
Trex 600EFL PRO "Belted Trac-X"
Align DS 610
DS650 Tail
Castle HV80
Align 600 stock motor
Spektrum AR7010 RX
Spektrum DX8 TX
Transmitter mode
20% expo cyclics
15% expo for the tail
60.2% Tx Tail Gain
Still tweaking tail setup for now. Flies well enough..but not quite perfect.
Parameter menus
C Pitching up behavior - Mid (Red)
D Headlock gain - Mid (Red)
+-13 Collective
12.4~12.5 Cyclic
1850rpm general/mild 3d
2200~2250rpm smack
Still moves surprisingly quick at low headspeed with the amount of available pitch and BeastX. Blue light at 5.6~5.7* Step J Outer holes on servo arms.
Aile/Ele servo arms are 90* relative to links, NOT frame. Using 90* relative to mainshaft ends up causing binding in the negative pitch region with the amount of pitch I'm using.
Trac-X/Compass FBL head. Lowest mounting position. 550/600Pro Mainshaft.
"You need more rockets. Everything is better with rockets"
Mike Dipalo--Synergy RC, MKS Electronics
Commodore8888 is offline        Reply With Quote Quick reply to this message
Old 03-10-2012, 08:07 AM   #64 (permalink)
Good info, especially on the 90 degree setting.
90 deg to the link is correct in all cases rather than 90 to mainshaft/frame
-Michael
michael503 is offline        Reply With Quote Quick reply to this message
Old 03-10-2012, 10:24 AM   #65 (permalink)
Trex 600EFL PRO w/DFC
Align DS 610
DS650 Tail
Castle HV120 v2
Spektrum AR8000 RX
Spektrum DX8 TX
Transmitter mode
15% expo cyclics
105% ATV for aileron and elevator
38% Tx Tail Gain (LED is on F when BX is powered on)
Parameter menus
G Cyclic Response - Increased (Red)
H Pitch Boost - Medium (Red)
+-12.5 Collective
13 Degrees Cyclic
Gov'd: 2250 & 2350 HS
Red at 6 degrees Step J Outer holes on servo arms. using small balls on inner swash.
Flies damn good too!
Emurzion is offline        Reply With Quote Quick reply to this message
Old 03-16-2012, 04:23 AM   #66 (permalink)
Default Need Noob Setup beastx 600 efl pro
Hi
first 600 for me need ideas for a a nice docile setup??
also.. what best location for the Beastex rec. i didnt think next to the motor on the 600 efl .. i guess in back by tail sitting on top of tail boom mount???Thanks in advance
Always thanks for the help much appreciated makes the hobby alot easier and enjoyablesince i began flying in dec.2011
Indydrt is offline        Reply With Quote Quick reply to this message
Old 03-16-2012, 07:47 AM   #67 (permalink)
Originally Posted by Indydrt View Post
Hi
For a more docile setup, use transmitter mode, and set your D/R to 70-80% and use 30% expo. You can also set your channel endpoints for ail and elev to 70-80 to achieve the same result but D/R can be turned on and off in flight.
The MB, like most FBL units, controls the roll and pitch rate like a HH gyro. You tell it how fast you want it to roll and it does what it needs to to achieve the result. As with the HH tail, you command the rotation rate with the channel endpoints.
I have a 500, 600N and a 700E. I have them set up in TX [email protected]% D/R and all 3 of them roll and pitch at the same rate. I have normal and TH mode setup with 80% D/R for take off and landing.
-Michael
Old 03-26-2012, 02:34 PM   #68 (permalink)
Hi
I used the area up front where Align says to mount the 3gx. The out of box setup with the Control Behavior set to sport is very tame and easy to handle. I'd suggest giving that a try.
Mike A. is offline        Reply With Quote Quick reply to this message
Old 03-26-2012, 03:20 PM   #69 (permalink)
awesome thanks
Old 03-26-2012, 03:21 PM   #70 (permalink)
ok thanks mike wil give that a try
Old 03-26-2012, 05:44 PM   #71 (permalink)
Ry
Trex 600EFL PRO (BeastX, Rail 606 blades, Kontronik 80HV)
Trex 450 PRO FBL (BeastX, HS-5065/BLS257, CC ICE Lite 50,)
mCP x (KBDD blades and tail)
Roblucky13 is offline        Reply With Quote Quick reply to this message
Old 04-12-2012, 10:23 PM   #72 (permalink)
T-Rex 450 Sport, RJX head
cyclic - DS410M, inner hole on stock arms
tail - DS420
stock motor
stock Align ESC
Futaba 7C, R617FS
All parameters and settings default
pot 1 - 8 oclock(might go back as I play with head speed, see below)
pot 2 - 9 oclock(default)
pot 3 - 9 oclock(default)
BTW, this is my first and only heli. Flown for one year before taking the FBL plunge. Has anyone found that Beastx/RJX likes higher minimum head speed? I need to rethink my Normal Mode head speed, because it flies so much better in Idle Up 1. My FB logic was lower head speed in Normal Mode for nicer hovering. Of course, FBL changes that logic...
Anyway, now I think I understand what FBL fans mean when they say the 450 flies like it's bigger when converted to FBL. It even looks/presents differently(and better) in the air. Hard to describe, but simple maneuvers like stall turns just have a nice sense of inertia/stability. It doesn't 'flit around', which is why I took the plunge in the first place
And it's quieter in the air?!
ehernan3 is offline        Reply With Quote Quick reply to this message
Old 04-13-2012, 08:22 AM   #73 (permalink)
what does it do wrong at a lower HS, and what is the HS?
-Michael
Old 04-13-2012, 02:13 PM   #74 (permalink)
I don't recall my head speeds offhand, but at lower head speed, the heli makes a chattering/jittering noise, which it did not do when it was still FB. Sounds very similar to the sound the tail makes when the tail gyro gain is too high, as the tail oscillates rapidly. But in this case, the tail is fine. At lower head speeds, the heli also seems less stable and 'more nervous' with FBL compared to FB. In idle up 1, this mostly goes away.
Old 04-13-2012, 03:36 PM   #75 (permalink)
are you running in Align governor mode? If so, disable it and try curves.
the chattering can be governor, it can also be cyclic gain set too high. A lower HS means the servos have to move farther to achieve the commanded rate/correction. You may also notice more bogging in hard maneuvers
-Michael
Old 04-13-2012, 06:17 PM   #76 (permalink)
My understanding is that FBL helis generally can accommodate a lower headspeed than their FB counterparts. Sounds to me like there is something else going on here such as a governor issue as previously suggested.
Trex 800e, Trex 600n
Futaba 14SG / AMA# 959345 / IRCHA #3954
aramb is offline        Reply With Quote Quick reply to this message
Old 04-14-2012, 11:20 AM   #77 (permalink)
Michael503, I am running in governor mode. I do not wish to revert back to running curves, as I really prefer the feel and response in governor mode.
Aramb, the cyclic gain is set to default(see my settings post). When it was still FB, I selected my governed speeds to minimize(idle up 2) or eliminate(idle up 1) any bogging during hard maneuvers. These Idle Up speeds continue to work well now that it's FBL.
I think you're suggesting the ESC itself may be the issue, right? That's means what I'm hearing is not servos or associated linkage/blade noise, but the motor itself. If so, I'll take a look through other threads for the signs of a bad or failing ESC. This one's a year old, but I don't know what expected life spans are.
Old 04-14-2012, 08:15 PM   #78 (permalink)
I recently switched to Gov mode on my CC esc on my 700, and it chatters like a tail servo if the gain is to high and the tail gets unloaded, such as in a counterclockwise sliding turn.
Try disabling gov and see if it fixes it. At least you'll know where it is or isn't coming from.
-Michael
Old 04-28-2012, 12:57 AM   #79 (permalink)
Trex 700e V2
Align DS610 on cyclic
Align DS650 on the tail
Castle ICE2 80HV
Align 700MX 510kv motor
Align DFC head
72% transmitter gyro gain
Parameter menus
B control behavior - extreme
C pitching up behavior - very low (purple)
D headlock gain - low (red flashing)
E stick deadband - 1 (purple)
F torque precomp - low - rev (blue flashing)
G cyclic response - normal (purple)
H pitch boost - off (purple)
____
Trex 470LP / Beastx / Align BL50X / Align 470MX
Trex 500X / Beastx / Align RCE-BL80X / Align 520MX
smaze17 is offline        Reply With Quote Quick reply to this message
Old 04-28-2012, 09:49 AM   #80 (permalink)
Compass 3D Plus
OS .50 SX Hyper, GP Energy 57 Pipe
Futaba s9451 cyclic servos, JR 8900g tail servo
Hyperion 6.6v LiFe rx pack with a step down for the tail servo
No switch, three separate power leads direct from the battery, 2 to rx and 1 to BX
Parameter menus
B control behavior - Transmitter
C pitching up compensation - medium (red)
D tail heading lock gain - medium (red)
E stick deadband - 2 (red flashing)
F torque precomp - off (purple)
G cyclic response - slightly increased (red flashing)
Airtronics SD10G, SK540
Synergy N5c, Novarossi .57 3DS
MAAC #85462
Down Low is offline        Reply With Quote Quick reply to this message
