Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 450
Blade 450 Blade 450 Helicopters Information and Help
Old 07-03-2011, 08:38 AM   #1 (permalink)
Default The Complete List of B400 & B450 Compatible Parts
Interchangeable parts include:
  • Fly bar weights [BLH1606]
  • Motor pinions (9T, 10T, 11T)
  • Bell Mixer Arm and Pushrod/Link Set [BLH1618]
  • Bell Mixer Pushrod/Link [BLH1619]
  • Main Grip Thrust Bearing [BLH1620]
  • Flybar Seesaw Holder Set [BLH1623]
  • Flybar, 220mm [BLH1625]
  • Flybar Paddles [BLH1628]
  • Washout Base [BLH1630]
  • Washout Control Arm and Linkage Set [BLH1631]
  • Anti-Rotation Bracket/Guide [BLH1634]
  • Control/Linkage Ball, Long [BLH1635]
  • Control/Linkage Ball, Short [BLH1636]
  • Ball Link Set [BLH1637]
  • Elevator Control Lever Set [BLH1640]
  • 5x8x2.5 Bearing elevator control arm [BLH1641]
  • 5x10x4 Bearing main shaft [BLH1642]
  • Aluminum Motor Mount Set [BLH1643]
  • Hook and Loop Battery Strap [BLH1644]
  • One-Way Bearing Shaft and Shim Set [BLH1649]
  • One-Way Bearing 6x10x12 [BLH1652]
  • Tail Drive Gear/Pulley Assembly [BLH1655]
  • Tail Drive Belt [BLH1656]
  • 2x5x2.5 Bearing: Paddle Control Frame [BLH1666]
  • Mounting Access. Screwdriver, & Wrench [BLH1674]
  • Servo Arm Set [BLH1676]
  • Brushless 420 Helicopter Motor, 3800Kv [EFLM1350H]
*B450 Canopies, blade holder, servos, gyro, ESC, and RX should also work on the Blade 400.
Blade 130X
Blade mCP X (Bl)
Blade Nano CP X
Prôtos 700
Xtreme-Production
SYMAWD is offline        Reply With Quote Quick reply to this message
Old 07-03-2011, 11:10 AM   #2 (permalink)
nice post, thnx
upankatz is offline        Reply With Quote Quick reply to this message
Old 07-13-2011, 10:39 PM   #3 (permalink)
anyone know about the tail blades? my lhs sold me a set of b400 tail blades, they looks identical, but of coarse different numbers.
blade msr- stock
blade 120sr- tail boom braces, strengthened flybar, rewired circuit board/motors
blade 450- stock till i learn to fly it
Sharkey_t is offline        Reply With Quote Quick reply to this message
Old 07-22-2011, 12:25 PM   #4 (permalink)
yes, are they different? My lhs did same thing, did not buy yet..
Happy flying ....Brad
Trex 550e v2,BLADE 450X ,130X NEVER! McPX BRL, 120DO2s, McPX, Stryker , Edge 540qq,UMX BEASt, Crak Yakx2,
YAK 55M 35CC,A.W. yak 54 20CC,3dhs 330sc 57inch, ALL ON MY JR9503
bradharvy is offline        Reply With Quote Quick reply to this message
Old 07-23-2011, 12:23 AM   #5 (permalink)
i got me heli back together, now have b400 tail blades on it and it flies fine. the blades look identical. the only difference i can see is the b400 have a "3" moulded into them, the b450 have a "2".
blade msr- stock
Old 07-26-2011, 09:58 PM   #6 (permalink)
I spent most the afternoon last saturday also at the local HS on their computer cross referencing parts with them. I forgot to check the gears. Can the gear set be exchanged and introduced into the B400? I know the Main shaft and collars from the B400 should work in the 450 if you hate pre collared shafts as much as me. I have had issues with them in different models in the past. If I cannot do a roll test on them or repair them it is a fail for me. This question just came up in the B400 threads and I didn't have the answer.
Old 08-12-2011, 07:09 PM   #7 (permalink)
Will the aluminum tail belt shaft fit the blade 450?
EFLH1465A Blade Tail Rotor Shaft and Aluminum Drive Pulley?
Should be the same right?
Thalios is offline        Reply With Quote Quick reply to this message
Old 08-17-2011, 10:27 PM   #8 (permalink)
horizon hobbies list the aluminum tail drive gear pulley assembly as blh1655a.
http://www.horizonhobby.com/Products...rodID=BLH1655A
i put one in my 450. the oem gear is nylon and two piece. one of the flanges separated from the teeth of the gear and the belt was only riding on half the gear, causing gear wear. the aluminum is one piece.
i think the only difference between the part numbers for the 450 and the 400 is the blh1655a comes with the brass spacer, but i'm not sure.
http://www.horizonhobby.com/Products...odID=EFLH1455A
skymonkey is offline        Reply With Quote Quick reply to this message
Old 08-27-2011, 06:27 PM   #9 (permalink)
Will the blade 400 canopies fit the 450? Are they different sizes?
Old 09-15-2011, 12:51 PM   #10 (permalink)
Mind if i dump this in the blade bible?
Old 09-15-2011, 01:45 PM   #11 (permalink)
Go ahead. If you are direct linking to this thread, it's fine but if you are copying and pasting it, you should be giving to credit to the original author.
Blade 130X
Blade mCP X (Bl)
Blade Nano CP X
Prôtos 700
Xtreme-Production
Old 09-28-2011, 05:41 AM   #12 (permalink)
Just got the feathering shaft/spindle for the Blade 400 in the mail instead of for the 450.
Do you think this part is interchangeable?
Thanks!
Like2fly is offline        Reply With Quote Quick reply to this message
Old 09-28-2011, 07:01 AM   #13 (permalink)
Mmm, i know the blade grip design is different, unsure on the actual feathering shaft.. if they are same length /diameter, should be ok.
Old 09-28-2011, 08:30 AM   #14 (permalink)
Default skids
Would the skids from the 400 work on the 450? i like the 2 piece skids better, and i would like to get a set like them, but i don't want the TREX 500 skids that are oversized on it.
kuzican is offline        Reply With Quote Quick reply to this message
Old 09-30-2011, 01:57 AM   #15 (permalink)
SPindles/feathering shafts are different.
Skids from 400 will fit on the 450... You may have to drill some new mounting holes but they'll work just fine...
JohnnyV52 is offline        Reply With Quote Quick reply to this message
Old 09-30-2011, 10:12 AM   #16 (permalink)
Thanks, I'll get the right one sent as the order was correct ;-)
Old 10-03-2011, 05:21 PM   #17 (permalink)
Default Tail and hor fin?
Does anyone know if the tail fin and horizontal stab for the 400 will fit on a 450? I would like to replace white with brighter more visible parts. I can only find upgrades for the 400, will they fit the 450?
Goblin 700, Gaui X7, 600EFL, DX8
Sharpedge is offline        Reply With Quote Quick reply to this message
Old 10-04-2011, 11:12 AM   #18 (permalink)
Doubtful as the tail boom is bigger, thus possibly making the holes larger.
Check out Fusuno, they have bright colored tail fins.
fusuno.com
Old 11-03-2011, 05:44 PM   #19 (permalink)
You forgot to include the swash plate which is the same on the 400 and 450.
Blade 450 | Blade CP Pro | Cobra Elite Gyro Mini
e92vancouver is offline        Reply With Quote Quick reply to this message
Old 11-26-2011, 11:13 PM   #20 (permalink)
What about the landing gear? Is it possible to mod the B400 to fit the B450 or do they match up without any trouble?
keetpilot is offline        Reply With Quote Quick reply to this message
