Go Back   HeliFreak > R/C Electronics Support > Futaba Radios and Electronics > Futaba CGY750 FBL System
Futaba CGY750 FBL System Futaba CGY750 Help and features Support Forum
Old 08-29-2011, 10:15 AM   #21 (permalink)
Does the sensor work with the new OS 50SX-H- Hyper.
I guess from the thread I will need to plug the hole on the 50.
I just installed mine on the 50 with Dow Clear Silicone, and tested by hand - not reading much - jumps from 23 to 25 but I have used a starter yet.
Why wouldn't a good plug be a short screw with some high strength lock tight / seems cleaner than hooping up the back with JB?
Hollywood Jorge is offline        Reply With Quote Quick reply to this message
Old 08-30-2011, 01:07 PM   #22 (permalink)
You need to turn the motor over with a starter to see what your % will be. If not using a starter you will never get a reading above 25% (even if you place the sensor directly on the crank). Yes, you can plug the hole with a screw, just make sure it is flush with the back so it does't interfere with the crank during operation.
I just cleaned off the backplate with alcohol, put a piece of scotch tape on the inside over the hole, filled the hole with JB Weld with a toothpick, and after it cured, removed the tape. Very smooth and no gobs of JB Weld on the outside.
Team Synergy/Rail Blades, Team Scorpion, VelTye, YS Engines, JAG-RC, Electron Retracts
kcordell is offline        Reply With Quote Quick reply to this message
Old 11-28-2011, 05:35 AM   #23 (permalink)
Do you know what the thread size is in the backplate ? thanks
Following Jesus !!!!! My Lord, He Never changes!
1#SAB RAW Scorpion Tribunus V2 300A ,
NEO-Vcontrol Touch,The only Way to Fly!
2#SAB Kraken 700 Scorpion Tribunus V2 200A
Helicrazy2 is online now        Reply With Quote Quick reply to this message
Old 11-28-2011, 06:00 AM   #24 (permalink)
You mean the threads that hold the backplate to the engine? I believe those are 3mm.
Old 11-28-2011, 06:12 AM   #25 (permalink)
The Threaded hole in the middle
Old 11-28-2011, 02:41 PM   #26 (permalink)
Still 3mm, BUT, if you put a bolt in this hole, make sure it is FLUSH on the inside. The hole is for the pressure on the pressure run carb for that motor.
If you don't think you will ever run that (a pretty $$ to buy it), put a piece of scotch tape on the inside of the backplate, fill the hole with JB Weld (use a toothpick to evenly get it into the hole. After it cures, remove the tape and you have a very nice seal.
Old 01-08-2012, 07:36 PM   #27 (permalink)
I installed my BPS-1 sensor and it reads 22% without rotating the engine. Rotating with the starter, the cgy750 reads max 84%. Is it ok if it reads the 22% while just sitting there?
mtheli is offline        Reply With Quote Quick reply to this message
Old 01-08-2012, 09:17 PM   #28 (permalink)
Yes, this normal behavior.
dchekas is offline        Reply With Quote Quick reply to this message
Old 01-25-2012, 09:46 PM   #29 (permalink)
Odd thing is with my os91hzr the sensor doesn't just push right in. Looks like I need to take a Dremel to the sensor to get it to work. Anyone else have this issue?
Trex700 V.bar, 500, 450pro 250
wolfcbr2003 is offline        Reply With Quote Quick reply to this message
Old 01-27-2012, 06:34 AM   #30 (permalink)
What's the minimum reading you can get that still makes the sensor useable. I see most guys get above 80%, the manual says you need above 60% but Jafa says he only got 48%. So what's the minimum.
As a matter of interest, why do you think Jafa got such a low reading?
FUTABA 18MZH Mode 2
Mikado Logo 500 3D and Logo 400 APM 2.5 drone
Hirobo SDX Dominik and SDX FBL
Kasama Srimok 90N with cyber head
ozsteel is offline        Reply With Quote Quick reply to this message
Old 01-27-2012, 07:52 AM   #31 (permalink)
First, you must spin the motor with a starter, just turning it by hand won't get an accurate reading due to the electronics in the sensor. Second, the manual states 60% or better.
http://manuals.hobbico.com/fut/bps-1-manual.pdf
Old 01-28-2012, 12:47 AM   #32 (permalink)
So I installed my sensor exactly per the manual using Permatex Clear RTV Silicon and let it cure for 12 hours and I only get 42% when spinning the motor using a starter. What could the problem be?
Do I need to redo the install which means a new sensor as the one I just used is bogged with silicon now and the backplate will need a good cleaning?
Is this the best way to get this sensor installed? Can't Futaba come up with something a little more reliable? Using silicon is a one off chance - if you get it wrong you throw it away and get a new one - doesn't sound like the best way to go - but thats only my humble opinion.
FUTABA 18MZH Mode 2
Old 01-28-2012, 02:19 AM   #33 (permalink)
That will work fine - I only got 24% but it worked perfectly
Maybe my starter cranks slowly
I couldn't get the sensor into the hole far enough because of the boot/shield
Gryphon field rep
Jafa is offline        Reply With Quote Quick reply to this message
Old 01-28-2012, 06:18 AM   #34 (permalink)
Thanks Jafa, always to the rescue.
I got the sensor all the way in. What I thought might have happened is that I got air bubbles trapped between the sensor and the backplate.
Why's Futaba so keen on 60% if 24% works perfectly?
FUTABA 18MZH Mode 2
Old 01-28-2012, 09:17 PM   #35 (permalink)
GCY 750 says need over 80% or 90% - yet worked fine with only 24%
There is something different about this sensor
And the head/coil is pretty delicate
Gryphon field rep
Old 06-09-2012, 11:58 AM   #36 (permalink)
Hey Guy's
Will the high-temp Red RTV silicone gasket stuff work with theback plate cover ?.
MA Furion 6, LHS Setup
MA Fury 55: Futaba BLS 251, BLS 451, CGY 750, FGH12, OS 55 HZR, Hatori
Synergy E5S: CGY 750, 14SG, KDE Direct
Forza 450: Xnova, CGY 750, 14SG, MKS
rtnaviman is offline        Reply With Quote Quick reply to this message
Old 06-10-2012, 03:40 AM   #37 (permalink)
Yeah - but it's messy
You should not need to use RTV - just the standard gasket works fine
If your engine is a newer one using an O-Ring definitely don't use the RTV
Gryphon field rep
Old 06-10-2012, 08:15 AM   #38 (permalink)
I think he's asking about using the RTV for the backplate cover.
I would not. The red RTV is a gasket maker to seal between two flanges.
The recommended stuff for this is the Permatex Clear RTV Silicone Adhesive sealant. Should be right next to where ever you bought the red stuff.
Old 06-10-2012, 10:45 AM   #39 (permalink)
Thanks Dchekas,
That's what I was looking for .
Old 08-30-2019, 11:08 AM   #40 (permalink)
Default Back Plate Adaption
..... Will this Backplate on the OS 55 HZ-R, with the built-in BLS-1 sensor adapter fit on my OS 50 SX-R ?? TY
Zacattack is offline        Reply With Quote Quick reply to this message
