Custom Aluminum Frame - Page 2 - HeliFreak
Go Back   HeliFreak > R/C Helicopters > CAD/CAM
CAD/CAM R/C Helicopter CAD/CAM
Old 07-27-2011, 01:03 PM   #21 (permalink)
Dude that is freaking awesome! Well done
I would love to do that some day.
Airtronics SD10G, SK540
Synergy N5c, Novarossi .57 3DS
MAAC #85462
Down Low is offline        Reply With Quote Quick reply to this message
Old 07-27-2011, 04:58 PM   #22 (permalink)
Great looking frames, are you going to ircha ?
ChopperCrazy is offline        Reply With Quote Quick reply to this message
Old 07-27-2011, 05:10 PM   #23 (permalink)
maybe you can powder coat instead of anodize? Nice work.
rotorfan is offline        Reply With Quote Quick reply to this message
Old 07-28-2011, 06:13 PM   #24 (permalink)
Thanks Guys,
Always nice to hear positive feedback!
I will definitely post more pics when I have the other parts cut. I think it would look great to anodize or powder coat and then cut the parts.
ircha... I have never gone. I'm not that great a flier but it would be fun to watch.
Kelly
FineScale 360
skray775 is offline        Reply With Quote Quick reply to this message
Old 07-30-2011, 11:28 PM   #25 (permalink)
Hi Guys,
I had a chance to work on the frames a little more. Here is a video of the lower frame half's being cut and some pictures of the frames assembled.
I need to rework the landing gear area a bit and I want to make a few other changes.
I can fully understand the use of Carbon or Fiberglass.... The lower frames take about 4 minutes to cut per side.
[ame]http://www.youtube.com/watch?v=ighiTXPtElw[/ame]
Kelly
FineScale 360
Old 07-30-2011, 11:44 PM   #26 (permalink)
Test fitting the parts.
Kelly
FineScale 360
Old 07-31-2011, 12:02 AM   #27 (permalink)
Really nice Kelly
It must be really nice making something like that yourself, great satisfaction.
Compass 3D+ - OS55 Hyper/Hatori/Vbar
Atom 500
Tarot 450 Pro - AR7200BX
Spektrum DX8
Inverse is offline        Reply With Quote Quick reply to this message
Old 07-31-2011, 12:59 AM   #28 (permalink)
I love threads like this. Just awesome. Kelly, you rock!
Old 07-31-2011, 07:34 PM   #29 (permalink)
Thanks Guy's,
Everything fits great but I made a critical mistake with the front 2 servo's.... The push rods hit the servo case in extreme throws... ARRRGGG !!! I need to rotate the servo mounts so the arm is not over the case.
For now I can mess around with a different servo arm. I will fix this in version 4! LOL
Kelly
FineScale 360
Old 08-04-2011, 01:34 AM   #30 (permalink)
Sar
That looks great but watching you machine that G10 just makes me feel itchy all over. What type of bit were you using for that routine?
Sar is offline        Reply With Quote Quick reply to this message
Old 08-04-2011, 09:48 PM   #31 (permalink)
Here is another picture of V3 put together.
Had a minor error in the servo layout that I fixed in V4. I never cut version 4 because I got a bug up may rear
about moving the motor up top and keeping full size servo's.
So here is a cad drawing of V5...Integrated bearing-servo upper mount, Integrated bearing-servo-motor mount mid block, motor up, batteries low and flat (the rectangle in the lower right is the outline of a 12s-a123 pack).
full size servo's.
I will start cutting the test parts out of plastic this weekend.
The bit I used on the G10 is a Diamond Cut Routers Style. It cuts like butter and no dust or itching if you use the vacuum like I did in the vid.
End Mill Cut Flute Length: 1/2 Shank Diameter: 1/8 Head Diameter: 1/8
Style: End Mill Cut
Flute Length (Inch): 1/2
Shank Diameter (Inch): 1/8
Head Diameter (Inch): 1/8
Overall Length (Inch): 1-1/2
Material: Solid Carbide
Manufacturer Part Number: A9800815
http://www.use-enco.com/CGI/INPDFF?P...MITEM=327-1469
ID:	244401   Click image for larger version
Kelly
FineScale 360
Old 08-05-2011, 09:26 AM   #32 (permalink)
Cool, learn to make more pieces and you can have your own custom helicopter!
Blade 500x, 450x, 300x, 200srx, MCPX BL, DX7
Courtesy Clerk at Safeway, Lonetree!
Varc is offline        Reply With Quote Quick reply to this message
Old 08-15-2011, 05:35 PM   #33 (permalink)
I was able to get full size servo's installed with the motor up top but it is a really tight fit with the wider scorpion motors. I think it is all just to tight to be a viable option unless I can go down to 18mm servo arms.
If 18mm servo arms will work I could slide the servo's over a 1mm and have more room for the motor.
Here are some pics.... Please ignore the rough looking plastic I used inexpensive PVC type of material just for the prototyping. I can cut it much faster and it can be carved with a knife for modifications. Unfortunately is absorbs dirt like a magnet and looks a little rough around the edges.
ID:	246979   Click image for larger version
ID:	246980   Click image for larger version
Kelly
FineScale 360
Old 08-15-2011, 10:41 PM   #34 (permalink)
Version 5 is looking Great. Becareful you may not be able to keep up with the orders once guys see the finished heli...
Cheers, Glenn
Outrage Fusion 50 FBL SK720 12s Xera 4025-560,Kon.HV 80 ,JR8717,OR 9088 on 6v TP 6s 65c 3300's
Trex 700CHP FBL SK720 MX510,Kon HV 80, JR 8717,OR 9188, 6v, TP 6s 45c 4400's
Gernejr is offline        Reply With Quote Quick reply to this message
Old 08-16-2011, 12:24 AM   #35 (permalink)
Jahmer on here uses some sort of laser to cut his g10.
Volcano is offline        Reply With Quote Quick reply to this message
Old 08-16-2011, 09:45 AM   #36 (permalink)
Any opinions on the 18mm servo arms for direct servo to swash? Will that be to short?
Kelly
FineScale 360
Old 08-16-2011, 11:44 AM   #37 (permalink)
If the servo is too close I'd think you could change the angle of the servo mount by about 5 deg. and bring it out enough so that the ball is on the other side of the arm.
I'd still like to see a nitro version. If you decide to do one I've got a cad file of the trex frame...think its in dwg.
X-cell Fury 90: 601/9251, 8231's Cyc; DS650; OS 91MP-6; Jr Vibe 90; OS 91RJX Pipe; Jr 8231 cyclic, 770 3D/G8900, Prfct Reg. CCPM; T-Rex 600 NP: 6965HB, 425MG Throttle GY 520/9254; OS50 Hyper,MP-5, Prfct Reg; 600E Bstx, nue1910
seanh is offline        Reply With Quote Quick reply to this message
Old 08-16-2011, 03:19 PM   #38 (permalink)
For FBL, it will be near perfect, it will not be enough throw for FB.
fastflyer20 is offline        Reply With Quote Quick reply to this message
Old 08-16-2011, 05:05 PM   #39 (permalink)
Have you considered moving the aileron servos rearward? This will eliminate the problem of having the servos interfere with the motor.
Like this...
Mikado Model Helicopters
Edge Blades
Big Fil is offline        Reply With Quote Quick reply to this message
Old 08-16-2011, 06:43 PM   #40 (permalink)
Big Fil, Yes I have a drawing like that but the elevator servo becomes an issue with frame but still playing with the idea.
I am designing this for flybarless right now so 18 will be great. I actually have everything drawn with 20 mm servo arms now so 19 may be fine.
Thanks guys.
Kelly
FineScale 360
Human Verification
