Go Back   HeliFreak > R/C Helicopter Support > Scale Helicopters > Mechanics
Mechanics Mechanics Discussion
Old 08-15-2011, 08:49 PM   #21 (permalink)
I dont know if you have a problem during servo power up. I had to install a collar on the main shaft to avoid damage to the links due to the weight of the blades. This collar avoids the excessive travel of the swash plate down. This can cause damage to your links with the different geometry of the R/C AD rotor head.. Here is a picture of what I did on mine and works very nice.
ID:	247043   Click image for larger version
vale71 is offline        Reply With Quote Quick reply to this message
Old 08-19-2011, 05:25 AM   #22 (permalink)
VALE71,
Interesting i will have to look at that, I have cracked both of my aileron servo horns and all the pitchorns on the head, ive gotten a new head enroute with a swash driver to help stabilize the PC links. I also am almost done with the new tail drive with the torq tube you designed, I wll have to show you pics its coming out very nicely. And of course it allowed me to move my tail servo back to center reducing weight in the tail, And it is very smooth in Operation, Cudos on the tail drive mod should of done it along time ago, No broken tail drive for me, Now just get the head working and Im in business. Reprogrammed the ESC with low Gov and slow start, Should also went ack to my 170 gear with 12 t pinion think my head speed is going tb be right in there.I did want to know do you have the boom supports installed or are you just running the tube with out them.
Thanks for all the advice.
Chris
UH60maintainer7 is offline        Reply With Quote Quick reply to this message
Old 08-27-2011, 04:55 PM   #23 (permalink)
Chris,
Yes the tail support is installed. I trim the front wood frame inside so the two rods can be acomodated. I also secure the two rods to the fuselage with tie raps.
Old 08-28-2011, 12:23 AM   #24 (permalink)
Vale71, thanks i will do the same
Old 08-28-2011, 02:42 PM   #25 (permalink)
To reply to the original post, I just finished installing and testing my RC Aerodyne (or Smart Model depending on who you ask) and absolutely love it. The quality of machining is impeccable and everything came installed with loctite and quality hardware. Most importantly it is machined true and is balanced perfectly. I had no issues with the links, all I did was move the nut to underneath the j arm and use Align links.
I'm using a SK720 so not sure how it does without stabilization, but I would guess very well. Very happy I went with this!
All scale all the way.
My Gallery
majuro15 is offline        Reply With Quote Quick reply to this message
Old 09-05-2011, 07:04 AM   #26 (permalink)
Default Rotorhead Modification
Well here are some pics of my modification I am waiting for a new swashpalte with follower from RC Aerodyne to show up. I build the Pitch horns out of .50 aicraft aluminum weighing at 1g a peice perfectly balanced and tapped in the Align 600 ext ball link for the PC attachment. Also I have added precision turnbuckl PC rods and Align Ball link connectors.
ID:	251382   Click image for larger version
ID:	251383   Click image for larger version
ID:	251384   Click image for larger version
ID:	251385   Click image for larger version
ID:	251387   Click image for larger version
ID:	251388   Click image for larger version
Old 09-05-2011, 06:53 PM   #27 (permalink)
Which Align links do you use. I tried H60162 T600 Linkage Rod Set and they don't fit. They are supposed to be 1.96 so what size are the J links threaded for?
GimpyGolden is offline        Reply With Quote Quick reply to this message
Old 09-06-2011, 01:19 AM   #28 (permalink)
Gimpy Golden im using the following parts for my modification
01601 Da vinci Flybarless Turnbuckle control rods (4ea)
H60071A Ball links Form Align (8ea)
HN 6096 Extended Ball attachment 600n (4ea)
I tapped the the hole with a #11 course thread tap standard equivalant to 3 mm in Dia with lock tight applied.
Old 09-06-2011, 03:50 PM   #29 (permalink)
I mistyped, just using the link ends, not the whole links. The links that came with the head from Flying Hobby were a perfect length. Not sure if I got an updated version from them vs. what RC Aerodyne is selling.
My Gallery
Old 01-17-2014, 10:56 AM   #30 (permalink)
Default Looking for parts list for plug & play 4 blade
Anyone out there have a parts list or original paper work on P & P 4 blade head.
I bought mine used and have none of that.
Any help would be appreciated.
PS not much help from RC Aerodine!
curly39440 is offline        Reply With Quote Quick reply to this message
Old 01-17-2014, 01:36 PM   #31 (permalink)
Originally Posted by Andy01 View Post
I think that 1500rpm is a little high for a 4 blade scale heli.
My Long Ranger weighs 19lbs and flies well on 1350rpm with two 710 mm blades.
I don't think that anything should come apart at 1500rpm, but what may affect it is how fast you get there and how fast the headspeed changes.
Do you use a soft start, and if so, how slow ?
What are your settings for rate of change of headspeed and governor gain ?
You do not need even the power of a 4025 to fly a 17lb scale heli, never mind a 4035. I think that A 14T pinion is too much as it gives you nearly 1850rpm at 100% throttle, or 81% throttle at 1500rpm and 76% at 1400rpm, which would be starting to run the ESC a bit hot.
Semi-symmetrical blades do have a bit more lift than symmetrical blades, so you need even less rpm to get the same lift. Lift-off at 5 degrees is about right - I would have expected a bit less at 1500rpm.
Colin
What do you think is a good head speed for a scale 450class AS350? How low do you think I could go? It is a two blade head with semi symmetrical blades. WS
Wind Spirit is offline        Reply With Quote Quick reply to this message
Old 01-18-2014, 04:10 AM   #32 (permalink)
My guess is about 2200-2400rpm, but I don't have a 450 scale. I suspect your restriction may be tail authority. I replied in your other thread.
Colin
Vario Long Ranger 700e
Seahawk 600
UH-1N 500
Baumann EC-145 800+ (coming soon )
Andy01 is offline        Reply With Quote Quick reply to this message
Old 01-21-2014, 09:26 AM   #33 (permalink)
I have two of the 4 Blade rotor heads from RC Aerodyne and I haven't had any problems out of mine.I run both at between 1500 and 1600...I also converted both of them to run a 700 class 450KV motor, 11t (??) pinion and a 112 Tooth KDE 700 Helical gear. I had to cut the 600 ESP frames in the Motor area to get the 700 sized motor to fit..But they run now with plenty of power. Both helis are in the 16 - 18 pound range.
TRex 450L, TRex 500 EFL, TRex 600 EFL, Synergy E7/SE, AS350, Bell 222, Bell 206, Jayhawk, Tiger EC-665, Vbar, Beastx
erospawn is offline        Reply With Quote Quick reply to this message
Old 02-18-2014, 08:55 PM   #34 (permalink)
I've been using the plug-n-play head on my AH64 and having run into any issues so far. Still playing with different head speeds but have run it up to 1800 without any issues.
Pavilion_06 is offline        Reply With Quote Quick reply to this message
Human Verification
