Like Tree1Likes
Old 12-02-2011, 04:07 PM   #241 (permalink)
Please
mfedasiuk is offline        Reply With Quote Quick reply to this message
Old 12-04-2011, 09:14 PM   #242 (permalink)
Blade Forum Support
mfedasiuk here are some pics of your work on my heli . I really like your designs. Keep up the good work.
I also added a 3mm boom and boom mount for the rakonheli frame thanks to my boy Brain fr CA thank you bro.
Be blessed
Isaac
ID:	271212   Click image for larger version
ID:	271213   Click image for larger version
ID:	271214   Click image for larger version
ID:	271215   Click image for larger version
ID:	271217   Click image for larger version
Jesus Rep Its all Good,Its all GOD
FPV Everything Now
GOD BLESS
tntburnett is offline        Reply With Quote Quick reply to this message
Old 12-05-2011, 07:32 PM   #243 (permalink)
Default Mine
Well here is mine. Grommet mod, microheli swash and better batteries courtesy of everyones recommendations here. It flys so much better! Still trying to figure out how to make a half way decent paper canopy.
Helicopters just beat the air into submission!
Blade MCPx
DX6i
mepilot is offline        Reply With Quote Quick reply to this message
Old 12-05-2011, 11:07 PM   #244 (permalink)
Default TDR has arrived!!!
I finally got my skidz and I love the new look!
ID:	271476   Click image for larger version
ID:	271477   Click image for larger version
ID:	271478   Click image for larger version
ID:	271479   Click image for larger version
X5-12s/Yep120/KDE600-530/FullSizeVbar/belt/550mm
180cfx-ServoSaverMod/TorqueTubeClutch/CarbonBlades, DX7se
My son Enzo - X5, 180cfx, DX7se
ccnada is offline        Reply With Quote Quick reply to this message
Old 12-06-2011, 12:01 AM   #245 (permalink)
Well here is mine since I started this sticky. It now has Microheli swash, head, grips and frame. For the motor I got an XP-7A with an HPO5 motor with stock pinion. Nanotech batts. Also I installed a 120sr 3mm boom with the adapter that comes with the micro heli frame.
It flies like its on rails and way better than stock. If you have any questions let me know.
This sticky has turned out awesome thanks to all of you out there with the same freakishly sickness I have
Thank you and Aloha
Gill P
Gill P.
SAB Goblin 700.
SAB Goblin 500.
JR X9303
gill4321 is offline        Reply With Quote Quick reply to this message
Old 12-07-2011, 05:28 PM   #246 (permalink)
My new mods. I think it looks pretty good! Can't wait to test it tomorrow.
Rago is offline        Reply With Quote Quick reply to this message
Old 12-07-2011, 07:56 PM   #247 (permalink)
Default 2s MCPX
http://www.kodakgallery.com/gallery/...05%3A171999765
KnightHawk517 is offline        Reply With Quote Quick reply to this message
Old 12-08-2011, 01:54 PM   #248 (permalink)
Very Nice photos KnightHawk, could you please tell me what tail motor and rotar blade are you using, also any input on the wire and tail boom length would be a great help, Thank You.
HT.
Heli-Tweak is offline        Reply With Quote Quick reply to this message
Old 12-08-2011, 02:37 PM   #249 (permalink)
Originally Posted by KnightHawk517 View Post
Nice photos
What battery do you have in the 2S model? Seems a Thunder Power. I actually use the Hyperion 2S 320 mAh. Have you set the governor with the CC10? How many rpms?
Very similar to mine 2S powered
and my 3S powered
Today unfortunately I crashed on the grass at high speed with 3S
liftbag is offline        Reply With Quote Quick reply to this message
Old 12-08-2011, 03:03 PM   #250 (permalink)
Ouch liftbag, thats a shame =[
So I notice you arent using the dual core tail anymore. Do you only use the 120sr tail motor for your 2s and 3s?
Also, I see your 3s is angled forward. Why do you have it like that? And how did you do that? For one, it does make the heli look meaner. I like it.
Blade mCP X (Microheli'd up - helimax 10a/thesteve/hp05/9t, old school single brushless, not reprogrammed)
dx6i
vlz91 is offline        Reply With Quote Quick reply to this message
Old 12-08-2011, 03:30 PM   #251 (permalink)
I use the tail of the 120SR only on models with governed rotation speed.
The motor bog helps a lot the tail and in fact I use the dual coreless tail in my TA915.
But if you use the governor, the dual tail fails and the 120SR is the only choice and I am forced to accept a certain degree of tail wag.
However I have had good luck with the tail of my 2S.
The 3S is so angled due to the Rakonheli skids (maybe coupled with MH frame? ). If I put the stock skids the tail boom is horizontal.
Old 12-09-2011, 01:15 PM   #252 (permalink)
Thanks!
The tail rotors. The White and red is the walkera 4g3 tail rotor blade and the Black, white and red is a Walkera-V100D01-Tail-Blade. The main blade is the white TBDD blade, I just add the decal on it.
The tail boom is 3mm and the length is about 135mm long. The tail hold very well on the 2s setup with the v100d01 tail rotor. I try the 4g3 tail rotor and the 120 sr tail rotor blade full length and it no good. The 4g3 and 120 sr tail blades is good for 1S setup. I have it on with the spin 16000kv 1S motor and it work pretty good but not on the 2S setup.
Old 12-09-2011, 02:18 PM   #253 (permalink)
Hi Liftbag,
Yes, its a Thunder power 250 mah 2s lipo battery I use.
Its exact like your 2s setup. I follow your 2S setup on the forum you post. You are the best. I admire your work. Make my MCPX rock. Thanks!!
I will try to convert my Blue MCPX to 3s soon. I saw you have a post of the 3S set governor for 8T. How it different on 9T setup on the governor? I saw your 3s MCPx video. its pretty nice Can you post your setup?
Thanks!!
Old 12-10-2011, 03:44 AM   #254 (permalink)
Default Here's mine :-)
Hi! Been a regular 'lurker' here at HeliFreak for a while now and figured I'd post a couple pics of my mCP X. Certainly nothing new with my brushless conversion, just wanted to show how guys like tntburnett and liftbag (among others) inspire people like myself to mod their helis to achieve the best possible performance. Thanks!
-dave
ID:	272442   Click image for larger version
kokoki is offline        Reply With Quote Quick reply to this message
Old 12-10-2011, 11:15 AM   #255 (permalink)
Hi Liftbag,
Thanks!!
The 3S with 9T pinion is the equivalent of the Goblin in the micro-helicopter, a ridiculous power to weight ratio. Fast and difficult to control, but a challenge that gives strong emotions.
O.T. here.
You can view my settings here
Old 12-10-2011, 11:40 AM   #256 (permalink)
Which skids are those? Where can I buy them?
You can see thats all my mTDR needs.
The thicker tail boom is just a black drinking straw.
Paul
pgleesonuk is offline        Reply With Quote Quick reply to this message
Old 12-10-2011, 12:01 PM   #257 (permalink)
Paul
You can buy at Rakonheli. Now you can have the new aluminium/carbon type. The delrin one breaks easily.
Old 12-10-2011, 04:55 PM   #258 (permalink)
New double tail motor bl mcpx
Chris20 is offline        Reply With Quote Quick reply to this message
Old 12-11-2011, 07:15 AM   #259 (permalink)
O.T. here.
Thanks for the data. I will give it a try.
Old 12-11-2011, 06:47 PM   #260 (permalink)
Recently upgraded my MCPX. MH Swash, Head, Grips. Astroid designs boom supports and fin.
MCX2 counter clockwise tail motor with Cat5 wires after i screwed my stock one. Extended boom (should be about 140mm) and Grommet mod.
I have to say... Dylan's products are top notch and excellent customer service to back it up.
Blade mSR, Blade mCPX. Spektrum DX6i.
groovesoul666 is offline        Reply With Quote Quick reply to this message
