Go Back   HeliFreak > R/C Batteries and Charging Support > Brand Specific Charger and Battery Support > Bantam
Bantam Bantam e-Station Charger Support Forum
Old 08-11-2011, 09:40 AM   #1 (permalink)
Default What does CAPA mean?
When I put to charge my Futaba 8FGS tx battery (1700mAh 7.2V NiMH) on Bantam BC6 DX-II after the usual 9 hours or so (@0.2C) I always end up with CAPA flashing on the screen of my charger. It should be FULL, shouldn't it? So why does CAPA appears, is it normal and what can I do to get FULL at the end of the charging period? thanks!
marian206 is offline        Reply With Quote Quick reply to this message
Old 08-11-2011, 09:41 AM   #2 (permalink)
Capacity?
Inverse is offline        Reply With Quote Quick reply to this message
Old 08-11-2011, 09:41 AM   #3 (permalink)
Capacity maybe--check if you have an mah limit (say 2000mah when you're trying to put back 3000mah)
nparker13 is offline        Reply With Quote Quick reply to this message
Old 08-12-2011, 10:01 AM   #4 (permalink)
Yes, CAPA means Capacity. You hit the capacity limit that was set when you started the charge. The battery is full. On a peak detection charger, you cannot slow charge a battery. On the BC6DXII you can by turning off the Delta Peak sensativity, set the capacity much higher than what the battery actually is, and then set the safety timer to the # of hours (minutes on the charger) for how long you want to charge.
RC Accessory is offline        Reply With Quote Quick reply to this message
Old 08-19-2011, 06:19 AM   #5 (permalink)
now I understand; thanks for the help!
Old 11-26-2011, 04:55 PM   #6 (permalink)
Bumping an old thread for the same/similar question
I tried to balance charge 4 3s 2200 mah lipos in parallel at 5 amps. I got the "CAPA" message and all the batteries were at 11.5 volts
I switched to "charge mode, it then stopped at 12.4 volts or so and i don't remember much else because my wife was giving me grief at the time, but it showed the "capa" message again.
I reset it again and it charged to a full 12.6 volts.
This is a BC6HP.
va aviator is offline        Reply With Quote Quick reply to this message
Old 11-26-2011, 06:38 PM   #7 (permalink)
This is a BC6HP.
CAPA means Capacity. You hit the capacity limit that was set when you started the charge.If you are charging 4 2200's in parallel, your capacity is now 8800 mah. Set the Capacity Limit to 8800 in the User Setup.
Human Verification
