Old 09-16-2011, 10:50 PM   #21 (permalink)
My CC Ice 50's internal BEC doesn't seem to be having any problems. I'm a newbie so I'm curious what minor symptoms might occur if it was having a hard time doing the job?
- Eric
Compass Atom 6HV, KDE 600XF-530 motor, CC Ice2 HV 80, Torq Servos, BeastX
MSH Protos 500, Scorpion/YGE, Brain
GAUI X3 6S, Xnova 1860, HW 50A V3, MKS DS95, 8910A+, BeastX, Belted Tail.
isogloss3d is offline        Reply With Quote Quick reply to this message
Old 09-17-2011, 09:41 PM   #22 (permalink)
Mine 450 Pro 6S video:
Motor Outrage 1700kv Pink
ESC Jazz 40-6-18
Cylic Hitec 65MG
Tail: Align DS520
BeastX V3 version
ddhuans is offline        Reply With Quote Quick reply to this message
Old 09-25-2011, 09:21 AM   #23 (permalink)
Well, like I said in an earlier post, I downgraded my 8S set-up into 6S keeping the same scorpion 1630kv, but now with a 15t pinion governed at 3300rpm, reason is that the heli was too heavy and too much power.
Now I'm not very impressed with the 6S result, I feel I have cut the power in half compared to 8S with a 12T pinion, and flying time is cut down by a good 2 minutes, actually it have less power than my previous 4S/scorpion 3000kv 12T.
I ordered a scorpion 2010kv and let you know the result.
martin_ is offline        Reply With Quote Quick reply to this message
Old 09-26-2011, 08:04 PM   #24 (permalink)
I have a scorp 1630 also and i just can't seem to get the "wow" everyone else is getting. It feels like a regular 450 pro with a little bit more punch. Maybe a new motor is key?
Scorp 1630kv
Cc ice 50
1300mah 30c
ProgressiveRC.com
DiggityDan is offline        Reply With Quote Quick reply to this message
Old 10-02-2011, 03:48 PM   #25 (permalink)
one questions guys... i have the 1630 on 6s like posted above but want to try the scorp-10. for me idle up 2 is 100 flat curve. if i got the new motor can i just bolt it in, plug it up and fly? or do i have to start tweaking stuff before i fly? i need help with this because im not to happy with the 1630. any input is appreciated!
ProgressiveRC.com
Old 10-02-2011, 09:26 PM   #26 (permalink)
If you flew the 2010 motor on the same pinion you are using now that would potentially raise your head speed by an additional 600-900 rpm so you will definitely want to change to a lower pinion if you want the same head speed.
- Eric
Old 10-02-2011, 11:01 PM   #27 (permalink)
Well after about 60 flights my Scorpion HK 2221 2010 has already trashed the top motor bearing despite being lubricated with Scorpion's oil every 6-10 flights.
I'm on Boca Bearing's site right now with 6 different bearing types to choose from. Any advice on which bearings have worked well?
Also any tips on special tools or techniques required? This is my first motor bearing replacement.
- Eric
Old 10-03-2011, 01:50 PM   #28 (permalink)
Ok cool so I'll plug in the new motor and get a new pinion and I should be good to go? What pinion do you suggest?
ProgressiveRC.com
Old 10-03-2011, 10:44 PM   #29 (permalink)
Yes, mechanically speaking, the pinion is the only thing you should have to change. What pinion you run depends on the head speed/type of flying you will be doing.
I'm doing sport flying and transitioning into moderate 3d. On an ungoverned ESC I ran a 12T pinion and set a flat throttle curve of 90% on idle 1 and 100% idle 2. Running at 100% created gobs of power and head speed was peaking around 3500 rpms when at zero pitch, which is a bit to high for me. Once I sorted out how to use governor mode on my Castle Creations ICE 50, I had to move up to a 13T pinion to allow enough "head room" for the governor to maintain a 3200 rpm head speed during full collective on idle 2 . I'm running 3000 rpm on idle 1 and 2800 rpm in normal mode.
What ESC are you using?
- Eric
Old 10-03-2011, 11:07 PM   #30 (permalink)
Closer inspection revealed that my motor shaft was spinning against the inside race of the upper bearing, thus wearing down the shaft in that area causing the radial slop in the shaft. Why the shaft was allowed to spin inside the bearing is not certain (The one crash I've had, poor QC at the factory that day, who knows?). The bearings are smooth when tested by hand.
New bearings and shaft are on their way.
- Eric
Old 10-04-2011, 07:43 PM   #31 (permalink)
I have a ice 50 esc. I really just want to put the 10 in. Leave my 100 flat and change the pinion. What pinion do u suggest for this motor/setup
ProgressiveRC.com
Old 10-04-2011, 10:48 PM   #32 (permalink)
Short answer: 11T for tossing it around, 12T for harder 3D.
My opinion: Use the wonderful governor in "Set RPM" mode to maintain a constant head speed (that suits your flying style) throughout the entire flight.
Just curious as to why you are choosing not to run governed?
- Eric
Old 10-05-2011, 08:49 AM   #33 (permalink)
+1 for the governor, it work beautifully on a 450. 13T pinion will be needed.
T-rex 600E pro
T-rex 450L
Coaxial Collective Pitch 550
Old 10-05-2011, 04:29 PM   #34 (permalink)
Well it's not that I choose to it's that I have no idea how to even begin to setup the gov. And just today my motor took a dump so I need this setup by this weekend!
Edit- I just ordered the scorp hk 2221-10 v2 for my pro with a 11 tooth pinion and a 13 tooth pinion. I'm going to try the 11 first with my setup as is and bought the 13 just in case I figure out how to use the gOv. Thanks alot for everyone's help!
ProgressiveRC.com
Old 10-05-2011, 11:52 PM   #35 (permalink)
That's a good reason not to be running governor mode Coming from the simple stock Align ESC on my 450 Sport, the Castle with all of it's bells and whistle was really intimidating.
Figuring it out did come at the cost of a couple stress headaches and barking to myself about how ridiculously complicated it seemed. I won't lie, I think set up (for the first time) and having to tune it with a laptop at the field, was a pain in the tush. So I did just run it with fixed end points on the 12T pinion for the first few flights. This is how I know that with a new pack during hover at the beginning of the flight, the head is screaming at 3500 -3600 rpm... lol)
Once I was able to wrap my head around the idea and now after experiencing the improved and very consistent flight behavior, I can't imagine going back.
If you decide to jump into Gov mode and you're curious about my settings, I have the Castle report (all esc settings) posted in my last blog.
Good luck and have fun with it.
- Eric
Old 10-06-2011, 04:17 AM   #36 (permalink)
Try a Jazz ESC. Governor mode is simple. And not that much more money when you consider the fact that you have to buy the Castle link cable.
TRex888 is offline        Reply With Quote Quick reply to this message
Old 10-06-2011, 05:43 AM   #37 (permalink)
Thanks alot isogloss. You have been a big help!
ProgressiveRC.com
Old 10-06-2011, 08:45 AM   #38 (permalink)
The castle link is free when you bought a brand new CC ESC.
The best mode is ''set rpm'' gorvernor mode, and is very very easy to use, it only took a couple of minute of setting and enjoy...!! no need to tach the head speed in this mode, you get the rpm you entered in your setting.
T-rex 600E pro
T-rex 450L
Old 10-06-2011, 09:25 AM   #39 (permalink)
Anybody here running "Hyperion G3 EX - 6S 1100mAh (45C)" battery on the 450 Pro? Need to know if they fit.
Trex 700E DFC - Logo 690SX - Gaui R5 - V-Bar Control
V-Bar Control flight analyzer (Win/OSX/Linux) - Latest release v5.0.0 July 5 - 2017
Sleipnir timing system - How fast can you fly?
Only the ground is the limit!
LinusLarsson is online now        Reply With Quote Quick reply to this message
Old 10-19-2011, 11:32 AM   #40 (permalink)
Verdict: On 6S, the 2221-2010 scorpion is much more powerfull than the 1630, I'm very happy now.
So, for those who want to convert 6S, I strongly recommend the 2010 on 13T over the 1630 on 15T, both governed @ 3300rpm, this is like night and day difference.
The 1630 is not a bad engine, since I have tried it on 8S I can tell it's a step more power than 6S 2010, but no go for 6S.
I don't have tried the align 1700KV on 6S, but I suspect it not better than scorp 1630.
T-rex 600E pro
T-rex 450L
Tags
450 6s
Human Verification
