Old 12-08-2011, 01:43 PM   #61 (permalink)
6min. on just 1000mah sounds pretty good to me.
srt4tom is offline        Reply With Quote Quick reply to this message
Old 12-08-2011, 04:52 PM   #62 (permalink)
Dude your heli is quite heavy and you are effectively using a 3S 2000mah (i know you are running 6s) I also assume you are using fixed end points which again doesnt promote amazing flight times
Andrew_ZA is offline        Reply With Quote Quick reply to this message
Old 12-08-2011, 06:07 PM   #63 (permalink)
Yes i am running fixed end points...
Do you mean that I should should fixed governor or change to flat throttle curves?
MHN777 is offline        Reply With Quote Quick reply to this message
Old 12-09-2011, 04:38 AM   #64 (permalink)
Nah im not saying you should run a governor, im just saying it would promote longer flight times. However, the outlay for an ESC with a decent governor is $85, so you must ask yourself if its not worth it to just buy another battery I also only get 6.5 minutes hovering with my 6S 1300mah leaving the cells at 3.77-3.85
Old 12-09-2011, 05:37 AM   #65 (permalink)
Errr... Ummm... Dang.
So, basically you guys are turning your 450 motors into... 500 motor setup?
Some of them video's... are just sick/insane/holyschitt.
Erazor 450 (2801 rx) 2750kv | EXI 450 Pro (2702V rx) FBL Tri-Blade head 3500kv AKE | V450 Walkera (2702V rx) 3950kv Turbo ACE 804 | 4F200 & 4F200LM | V200DQ02 & V200D02 | V120D02 & V120D05 | 250 CopterX | 250 EXI FBL | Genius - WK2801
Silver-techie is offline        Reply With Quote Quick reply to this message
Old 12-14-2011, 11:38 PM   #66 (permalink)
Ok, I've switched to a 4S setup from a 6S setup. 6S appears to hold the rpms better, but on my heli (heavier because of heavier electronics, and it swings 350mm blades at the start), it only makes things heavier for me if I wanna stick with Hobbyking 6S 1300 mAhs, I like the weight and handling using 6S 1000mAhs.
So I'm letting go of my Hyperion 2221-1630 motor. Only 4 flights. I'm gonna have to ship it from Singapore ( it's not part of China, nor Taiwan, go Wiki....) . Please pm me. Original Box, maual and catalogs intact, just no esc connectors.
good luck on the 6S setups...
Old 12-19-2011, 10:16 PM   #67 (permalink)
hi 6s guys,
I think its myb a bit late or someone already posted this question. But anyway, here it is..I would like convert my 450 pro [all stock component except servos (Hitec 65MG)] to a 6s setup. which components do I need to change/upgrade?.....thx
All begins (Jun 2011).......
Next project:
MSH Mini Protos, 450 Scale Airwolf, BAH Mini Quad
cpmboy is offline        Reply With Quote Quick reply to this message
Old 12-20-2011, 02:10 AM   #68 (permalink)
I suggest picking up a Castle Creations ICE 50 Lite ESC, Scorpion 2221-2010 v2 motor, and some Voltz 6S 1300mah LiPo's. You'll also need some bullet connectors for the motor to ESC connections. Other than that, you'll also have to keep in mind that some frame modification will probably be necessary in order to fit the LiPo under the canopy. That should about do it.
There are other options for the ESC, but they get much more expensive. The ICE 50 Lite is the cheapest option that has already proven itself with the 450 Pro 6S setup.
http://www.readyheli.com/CSEM6000-Ca...C_p_32398.html
http://www.readyheli.com/Scorpion-HK...r_p_36988.html
http://www.readyheli.com/VT130035C6S...k_p_37283.html
- 6S TREX 450 Pro FBL - ÁBeast, MKS, Castle Creations
- Goblin 500 - Kontronik Pyro 600-12, Jive 100lv, iKon, BK servos
- TBS Discovery - Pixhawk
- Spektrum DX7
SeanM is offline        Reply With Quote Quick reply to this message
Old 12-20-2011, 09:23 PM   #69 (permalink)
Thanks for reco seanM.....o ya..do you (& others) have pics showing how to mod the canopy to fit the 6s batt?.....thx
Next project:
Old 12-22-2011, 01:27 PM   #70 (permalink)
Default Joining the 6s club!
Joining the 6s club! I had my Align 550 esc laying so i figured id give the 6s setup a whirl using an align 1700kv motor and fixed end points. All I need is some batteries which should arrive anytime now. Here are a few pics...still need to do the battery tray mod. Can't wait to fly it.
ID:	275240   Click image for larger version
ID:	275241   Click image for larger version
ID:	275242   Click image for larger version
timmay is offline        Reply With Quote Quick reply to this message
Old 12-22-2011, 02:58 PM   #71 (permalink)
Great post! I do want to add here though that if you inside mount the esc you may want to go with the heavier Ice50. Even with the smaller amperage being pulled with the 6s app through the lite it is still recommended for an outside frame mount high airflow mount. I use the 50s on all my 6s builds. I just cut the frame and mount them flat with the heat sync extending out both sides of the frame in the lower front of the base plate. Looks fantastic and helps balance out my helis since I run stretches on them. Plus they run cool!
The one mod I do to them is to add better capacitors, and I route and shorten the input leads through them so the input wires to the Rx come out the tail side. this way I don't have wires running everywhere.
Old 12-23-2011, 06:49 AM   #72 (permalink)
What caps do you recommend or use?
Old 12-27-2011, 12:10 AM   #73 (permalink)
For anyone out there building theirown packs, I'm thinking 2 3s 1300 gns ace in series, shortening 2 poer leads to save weight. I am wondering however, if there is a 2X3s to 6s balance adapter?
Cullen Colapietro is offline        Reply With Quote Quick reply to this message
Old 12-27-2011, 05:07 PM   #74 (permalink)
Default Cullen...
TRex888 posted this on post #51. Might give it a try myself.
Originally Posted by TRex888 View Post
I am posting this because a couple of people have PMed me this week.
Wiring details for home made 6S pack from 2x3S packs. The diagram is something I Googled. I do not use the extra wiring harness but instead join the two packs together with a pair of bullet connectors. I also leave the 2x3S to 6S balance connector on the charger to save weight. They are colour coded. Get them plugged in wrong and you puff the batts and charger (I've done that once).
Questions, just ask.
ID:	276226   Click image for larger version
Old 12-27-2011, 05:32 PM   #75 (permalink)
That looks doable, bu I foresee more battery companise building up similar packs in preparatin for releases like this:
https://www.helifreak.com/showthread...=367195&page=8
Old 12-27-2011, 08:10 PM   #76 (permalink)
Default 4 to 6 cell
I recently converted 1 of my 450's to a 4 cell setup and loved it the added power and torque fit me really well. and as I use castle ice 50's in all my 450's I was thinking of move up to a 6 cell on one
I found this
http://www.rc711.com/shop/3dpro-next...?cPath=165_244
its a fbl trex 450pro clone BNF with a beastx
price isnt bad
reguardless you all have peeked my curiosity and now I will have to order a motor and 6cell battery just to see what the hype is about.
4 x Rush 750/stretched V-bar KDE 700XF-495 HV servos Greys reactor CC 160-HV
Trex 600EFL V2 V-Bar ds610 ds650 CC bec/pro Scorpion 130a HV KDE 600XF-530
450L KDE 1750 cc50 4xDS215MG k-bar
X-8 FPV Wing, TBS Discovery FPV, TBS Caipirinha FPV
satgod is offline        Reply With Quote Quick reply to this message
Old 01-04-2012, 04:45 AM   #77 (permalink)
I suggest picking up a Castle Creations ICE 50 Lite ESC, Scorpion 2221-2010 v2 motor, and some Voltz 6S 1300mah LiPo's....
I have four of the Voltz 6S 1300 mAh lipos and being the right capacity and already wired up in the 6S configuration is definitely handy. I have a couple issues however.
One being that they've been out of stock for months (either that or they come in stock and sell out every time I check their website, which is almost weekly)
The second issue is that after about 60-70 cycles, two of the packs are dropping to 3.2 to 3.3 volts per cell halfway through a basic 5 minute flight according to my Castle Ice 50 logs.
I haven't taken this issue up with Ready Heli yet and they've always offered above par customer support so I don't want scare anyone away from these packs, but simply share my experience and remind people that there are plenty of other options out there for lipos especially since the Voltz 6S 1300 mAh packs are never in stock.
- Eric
Compass Atom 6HV, KDE 600XF-530 motor, CC Ice2 HV 80, Torq Servos, BeastX
MSH Protos 500, Scorpion/YGE, Brain
GAUI X3 6S, Xnova 1860, HW 50A V3, MKS DS95, 8910A+, BeastX, Belted Tail.
isogloss3d is offline        Reply With Quote Quick reply to this message
Old 01-04-2012, 04:50 AM   #78 (permalink)
Looks good, and I like the wire routing for the motor/esc leads. Which batteries do you plan on using?
- Eric
Old 01-04-2012, 12:48 PM   #79 (permalink)
What do you mean by better capacitors? Which ones are you using? How much better flight times do you get with those caps?
Blade 130X, Blade Nano CPX
Edge 540T, Mini Funtana X, UMX Sbach 342 3D
Lunchbox is offline        Reply With Quote Quick reply to this message
Old 01-04-2012, 01:37 PM   #80 (permalink)
I found this
price isnt bad
I recently purchased their 6s motor and HW 40A ESC. I'll report back on how it runs. Hope it is easier on batteries than my 3s setup.
Tags
450 6s
