Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 450
Blade 450 Blade 450 Helicopters Information and Help
Old 03-05-2014, 05:36 PM   #1981 (permalink)
Originally Posted by Soulfly View Post
Looks like it's just pieces of fuel tubing.. Probably to help soften the landing gear on hard ground, and also to help keep it from sliding around as well.
Yep ,I use yellow nitro fuel line on mine .Got several feet of it for the Tmaxx,Savage5.9xl and the slayer.Keeps from messing up the bottom of the skids...but don`t try sliding it in to a stop.....won`t work!
Paper Money + Heli`s = Loose Change !!
Mr.D 4511 is offline        Reply With Quote Quick reply to this message
Old 03-05-2014, 05:38 PM   #1982 (permalink)
Got to fly the one I just restored..did pretty good with the new GAZ 126 gyro.Tail was more solid ...not bad for 11 bucks!
Old 03-05-2014, 07:52 PM   #1983 (permalink)
Im thinking of converting mine to FBL.....any recommendation for a good FBL head on the 450 3D?...
All begins (Jun 2011).......
Next project:
MSH Mini Protos, 450 Scale Airwolf, BAH Mini Quad
cpmboy is offline        Reply With Quote Quick reply to this message
Old 03-05-2014, 07:56 PM   #1984 (permalink)
Good budget non clone is robird
Sent from my SCH-I545 using Tapatalk
DX9, Mostro 700N 120SRX, HD Cell 500, Blade 450xl 6S, 180 CFX and 130x.
jrwalte is offline        Reply With Quote Quick reply to this message
Old 03-05-2014, 08:11 PM   #1985 (permalink)
Agreed, I went with the blade drop in on my convert..gona try out the Robird next.
Old 03-05-2014, 08:21 PM   #1986 (permalink)
Thanks for the recommendation ..just wondering what a good/suitable head set (main blade grip/head/main shaft/swash.....apart from blade's own BLH4399) for the conversion.
Next project:
Old 03-05-2014, 08:22 PM   #1987 (permalink)
Originally Posted by Mr.D 4511 View Post
..it just won`t end......
QFT! I haven't been able to fly much lately (upcoming job transition, moving, looking to buy my first house, and 3 kids keeps me pretty busy!), but I still manage to spend $30 here, $60 there, on all kinds of random little things!
*Spartan Vortex VX1e*
Old 03-05-2014, 09:41 PM   #1988 (permalink)
BLH4301 Flybarless Linkage Set: B450X
BLH4303 Main Rotor Blade Grip FBL Control Balls (2): B450X
BLH4317 Flybarless Main Rotor Grip Set: B450X
BLH4321 Flybarless Spindle Set (2): B450X
BLH4322 Aluminum Flybarless Head Block Set: B450X
BLH4331 Flybarless Follower Arms: B450X
BLH4347 Flybarless Main Shaft (2): B450X
Shouldn't need this one, but maybe grab it just in case...
BLH4338 Linkage Rod/Pushrod Set: B450X
If you get all the plastic pieces, you'll be able to keep costs down, and have spare parts locally.
EDIT:
Hmm... Just added all those up on my LHS's website.. Probably cheaper to just buy the conversion kit.. That way it's all aluminum parts.
EDIT #2:
It's $10 more for the conversion kit, and it's all aluminum parts.. At least this way, if you break anything.. You can source parts locally..
[B]-Trev
Soulfly is offline        Reply With Quote Quick reply to this message
Old 03-05-2014, 09:51 PM   #1989 (permalink)
Hah.sorry. just noticed you said head. I went with the official blade upgrade head. Amain had a good deal on it at the time for around 60.
Old 03-05-2014, 09:53 PM   #1990 (permalink)
Instead of converting mine.. I just bought a bare 450x Airframe.. and found a used Beastx unit.
I'll just swap the Mainshaft and head assembly onto my 450 3D, and then slap the Beastx on it.
Cost me the same as what my LHS wants for the conversion kit.. And I got a bunch of spare parts!
^^ That's a good deal!
[B]-Trev
Old 03-06-2014, 08:51 AM   #1991 (permalink)
Sounds like you like this better then stock. I'm still a bit annoyed that the OEM gyro seems to require constant tweaking and changing of the gyro gains.
John
Blade 450 3D, mSRX, 230S, DX6
jrtubb is offline        Reply With Quote Quick reply to this message
Old 03-06-2014, 10:11 AM   #1992 (permalink)
Ok so that is not going on mine since I spend a bit of time sliding around on the skids still!
John
Old 03-06-2014, 11:40 AM   #1993 (permalink)
I picked up this FBL head from http://www.cnchelicopter.com:
https://www.cnchelicopter.com/servle...barless/Detail
You can put it right on the 3D shaft, but it will not fit on the X shaft without shaft modification. You will have to switch the balls on the swash plate to align type ball links.
As for a controller, there are many out there. I can tell you I started with and ZYX-S controller and it didnt work out for me....... not that it a bad controller, I just didnt have the time and patience to hook it up to a computer everytime to tweek it..... not to mention I couldn't trust mine. So, like many on a budget, I picked up a AR7200BX on the HF For Sale section for a $150 and have never looked back! Love it now.
What goes up, must come down..... We hope!
Blade 500 3D, Blade 450 converted to X, Blade mCPx v2, Blade Nano Qx
youngb87 is offline        Reply With Quote Quick reply to this message
Old 03-06-2014, 01:32 PM   #1994 (permalink)
I also bought when amain had for $60.00.
Here is a link to a bare 450X frame. $90 plus $13 shipping.
http://www.ebay.com/itm/Blade-450-X-...item2a3789e5d6
I think the $340.00 shipped to your door new 450X is a better deal than upgrading a 450 3D with Blade brand parts.
megawhacker is offline        Reply With Quote Quick reply to this message
Old 03-06-2014, 06:57 PM   #1995 (permalink)
Blade 450 x Airframe w Complete Head Tail and Frame | eBay
Yup that would be a very good deal indeed. Optioning for just an upgrade is because I already have 3 450's in my little hangar & don;t want to add another 450
Next project:
Old 03-06-2014, 07:50 PM   #1996 (permalink)
Same problem here. I am thinking about disassembling one for the parts' bin.
Old 03-06-2014, 08:04 PM   #1997 (permalink)
Don't do it..
Just retire one next time you have a crash, Use what's left over for parts..
[B]-Trev
Old 03-06-2014, 10:26 PM   #1998 (permalink)
Three diff 450s...blade,trex and a mini protos....planning to convert one into scale, the blade to fbl and the mini 70% still in its build stages......o boy ha ha....this will be a very exciting year indeed....
Next project:
Old 03-06-2014, 10:36 PM   #1999 (permalink)
Three diff 450s...blade,trex and a mini protos....planning to convert one into scale, the blade to fbl and the mini 70% still in its build stages......o boy ha ha....this will be a very execiting year indeed....
OH! Okay... That's quite a bit different then.
I think most of us that have multiple 450's have more than one B450 3D or 450x.
I JUST sold my other 450 3D, only to pick up a 450x........
[B]-Trev
Old 03-06-2014, 11:43 PM   #2000 (permalink)
Default What did you do to your Blade 450 today?
Post 2000 :-)
Crash_Expert is offline        Reply With Quote Quick reply to this message
