Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mCP X Brushless Mods
mCP X Brushless Mods Blade Micro CPx Brushless Mods and Conversions
Old 04-14-2014, 03:30 PM   #341 (permalink)
Yes those are BL grips, head and spindle, drop in replacement. Ive converted both of my mcpxs a year ago and have not bent a feathering shaft in hundreds of crashes (over grass, but original mcpx one would bend no matter). On the plastic grips though I managed to snap off the little ball for the pitch link, but again theyre burlier than the original plastic grips.
I still quite like the BL converted mcpx. Weighs much less and depending on motor less HS too than the BL which is a good thing when crashing. But I think youre right in refraining from setting one up with a bigger motor/batt . If Id want a more powerful/heavier mcpx Id go with the BL.
That being said mine are not going anywhere. I ditched the above 130 blades (servos simply too weak) and got back to the BL non bullet blades. Have them dialed in perfectly for my needs and even aquired some junk mcpxs for spare servos/boards. I think I must have well over 4000 flights on these now ...
2x MCPX I Gaui X1 I 2x Mini Protos I Protos I DX8
dr dremel is offline        Reply With Quote Quick reply to this message
Old 04-14-2014, 06:13 PM   #342 (permalink)
Nice, thanks for the info. yeah My Bl converted is at 50 grams the stock BL is 60grams from what i read on the specs . lighter bounces better, but if i built a killer one i would try my very best not to hit the ground, guess have to treat it like my 450 sized.
Oxy 4AR7200BX,Torrent 110,Theroy XL,27% bipe,lots of E-planes Powered by iX12 AMA 30 yrs.
Old 05-09-2014, 10:11 PM   #343 (permalink)
Got to looking at the v2 and BL and I like the gear on the BL and the canopy is bigger so i stuck the gear and canopy on my V2 and flew it. the bigger battery holder not issue i cut a piece of depron to go inside to take up the space. i think im get some white gear for my V2 i really like the looks of it
Name:	MCPX v2 with BL canopy (2).jpg
ID:	507957   Click image for larger version
Name:	MCPX v2 with BL canopy (3).jpg
ID:	507958   Click image for larger version
Name:	MCPX v2 with BL canopy (1).jpg
Old 05-19-2014, 10:46 PM   #344 (permalink)
Just finished up re-doing my V1 Mcpx 2BL I bought off the forums here from a member. I bought it because it was an NCcraig build with around 40 flights. Once I got it in my hands for close inspection, the solder work and everything was fantastic, but the head had developed a bit of slop in the swash and the plastic pitch links so I broke the heli down and installed new servos while I was at it. For the rebuild I decided I would try to do this heli some justice by having the most responsive head on it I could get. The answer was a DFC with carbon blades.
Build specs for those interested.
Microheli carbon frame with third main bearing
V1 board
HP06/HP03 - direct soldered
9T Pinion
BLHeli flashed ESC's - Governed running flat curves
3mm boom / MH tail fin
New 2.1g servos / New links and pushrods
Lynx OWB system and titanium mainshaft/collar
MH metal swashplate with Lynx red O-rings
Lynx DFC head with Ultra Dampeners and Titanium spindle
MH Carbon blades
RRC 65mm prop
Hyperion 550's with Microdeans
Lynx landing gear with MH delrin battery tray
X-Canopy Airbrush - modified to accommodate battery. (CG is spot on)
Pics:
[Oxy5 Meg / 12S] [JR Vibe 55] [Align 700N] [Oxy4 Max]
JR E12 ITO / 12S] [Goblin 770C / 14S] [800Xxtreme / 16S]
OXY rep
DCflyer is online now        Reply With Quote Quick reply to this message
Old 05-21-2014, 10:52 PM   #345 (permalink)
Got some white gear to go on mine. think she is Prudy now.
Name:	MCPX V2 with BL canopy and gear (9).jpg
ID:	510612   Click image for larger version
Name:	MCPX V2 with BL canopy and gear (5).jpg
ID:	510613   Click image for larger version
Name:	MCPX V2 with BL canopy and gear (6).jpg
ID:	510614   Click image for larger version
Name:	MCPX V2 with BL canopy and gear (1).jpg
Old 06-19-2014, 09:32 PM   #346 (permalink)
I finally (and I mean finally) got my mCP X HP05/Double Coreless out and converted it to a brushless tail. I designed and 3D printed a motor mount and tail fin to hold an HP03T motor on a 2mm solid rod and protect the Plantraco prop.
I'm very happy with the result. The parts for the motor mount and fin are on Thingiverse: http://www.thingiverse.com/thing:364490
I got a chance to fly it today, and it's a beautiful thing. Did my first inverted hover today. I can't believe how easy it is to throw this thing around when the tail stays where you put it.
Name:	2014-06-15 17.08.56.jpg
ID:	517018   Click image for larger version
Name:	2014-06-15 17.09.21.jpg
Blade 4503D ZYX-S Tarot DFC
mCP X v2 BL HP05s/XP-7A/twin coreless
clough42 is offline        Reply With Quote Quick reply to this message
Old 12-05-2014, 09:52 PM   #347 (permalink)
Here is my rebuild
ID:	553950   Click image for larger version
ID:	553952   Click image for larger version
Align 450 pro DFC
Blade mCP X v2(dual BL,SPIN 16k and HK 12K, DFC head and swash from Lynx)
DX8
Sailman is offline        Reply With Quote Quick reply to this message
Old 02-07-2017, 01:00 PM   #348 (permalink)
Finally finished up my brushless. What kind of batteries are you guys using. This thing eats stock 200mah up in a minute
ktmdiesel is offline        Reply With Quote Quick reply to this message
Old 02-07-2017, 01:38 PM   #349 (permalink)
Looks great
Turnigy nanotechs 300mah
Oxy 2 FE x 2, 180cfx full Rakon uBrain v2 BA-8-1 cyclic H0988UHS tail, 180cfx spartan lynx pro tail, 130 full rotary bx, 130 Xtreme build, 130x stock, nano cpx dbl bl, nano cpx wild bl, DX8, Phoenix sim for practice. For fpv Phantom 3 pro.
Bhujang is offline        Reply With Quote Quick reply to this message
Old 02-07-2017, 03:16 PM   #350 (permalink)
Originally Posted by Bhujang View Post
Looks great
Thanks! Has anyone tried the 550mah? Or will they fry the board
Sent from my SM-G930W8 using Tapatalk
Old 02-07-2017, 04:20 PM   #351 (permalink)
Default Lipos I have tried with my brushless mcpxs
I have tried 550mah Hyperion , 450mah Nanotech (1/2 of a 2S), 340mah Nanoteh (1/2 of a 2S), 325mah Hyperion [45,55, & 70C], 300mah Nanotech and others. Since they are all 1S or 3.7 volts the boards were fine.
Your HP05 will probably like the 550mah Hyperion. Try to find some of the 325mah Hyperion if you can. 300mah Nanotechs probably won't work for long.
I like the Hyperion 325mah 55C best. Most bang for the $ and gram. But, for shame, they are out of production. The 550mah Hyperions were good to start but faded quickly--on each flight and overall plus they are heavy..
Rats, I was hoping for some news of a new super good battery.
I might have to go back to splitting the Nanotech 450mah 2S lipos again. I gotta break out the aluminum soldering supplies...
Good luck and happy landings.
daveapplemotors is offline        Reply With Quote Quick reply to this message
