TAROT 3 axis gyro - Page 20 - HeliFreak
Go Back   HeliFreak > R/C Electronics Support > Electric Motors, Gearing, Speed Controls, Gyros, Receivers, and Other Electronics Discussion
Electric Motors, Gearing, Speed Controls, Gyros, Receivers, and Other Electronics Discussion Electric Motors, Gearing, Speed Controls, Gyros, Receivers and Other Electronics Discussion
Old 12-05-2011, 12:56 PM   #381 (permalink)
Originally Posted by UHx1xHuey View Post
If you program it with the TX, Do you need a programing box once it comes out? And is the setup and programing easy to do on the TX?
I am going FBL on my B450 and i dont do any 3D or anything so i think this would be the best FBL unit for me right now.
Or buy the Copterx 3x-1000 with the programming box from ehirobo and get it over with in one fell swoop.
CopterX 450 Black Angel FBL "Night Rig" | ZYX v4.0
PRTOS 500 FBL "Sky Whip" | Robird G31
Audacity P6 FBL "Phoenix" | MSH Brain | 12s
Goblin Speed | iKon
Dr. M is offline        Reply With Quote Quick reply to this message
Old 12-05-2011, 01:03 PM   #382 (permalink)
I think i will just get the beast x, I was reading some where on a differnt forum that the tarot fbl unit is not that good.
BLADE
UHx1xHuey is offline        Reply With Quote Quick reply to this message
Old 12-05-2011, 01:36 PM   #383 (permalink)
I have 2 x Beastx, 1 x Tarot ZYX, 1 x Copterx 3X1000, 1 x ALZRC 3GYS - the last 3 are fundamentally all teh same unit. They are not as good as the Beastx currently, but the Beastx has been out for over a year and is on V3 software and it is about 6 times as expensive as the cheapest of these 3 (the Copterx).
Personally I think that the Copterx / Tarot / ALZRC is a good unit, not as good as the Beastx admitedly, but for me (and at the price) the question is not "is it as good?" but "is it good enough?" - for me the answer is definitely YES, for my bank balance and my level of flying - YMMV
Mikej is online now        Reply With Quote Quick reply to this message
Old 12-06-2011, 12:53 AM   #384 (permalink)
Talking
Bought three Tarot FBL units last week. This weekend, I maidened my first Tarot FBL on an old 450 V2 beater of mine. If flew really good with stock settings!
For the first day of testing, I did stall turns with some backwards tail slides, FFF, side ways sliding, inverted, inverted backwards hurricanes and hurricane figure eights.
Small photo album of my setup:
https://www.helifreak.com/album.php?albumid=8116
  • T-Rex 450 (frame)
  • Tarot FBL head
  • Align DS410 plastic gear servos for cyclic
  • Hitec HS-5084 metal gear tail servo
  • Hitec Aurora 9 radio
  • Turnigy Typhoon 450H motor (3450kv)
  • Turnigy Nanotech 3s2200 battery
EDIT: forgot to mention that the postings on this thread really helped out with setups. Especially the discussions for checking the pirouette compensation and getting the heli up high to test it out.
Hitec Aurora 9 ∙ FrSky Taranis ∙ Walkera Lama 2 ∙ T-Rex 250 ZYX ∙ T-Rex 500 ESP Robird∙ T-Rex 500 ESP V-Bar ∙ 480 stretch V-Bar ∙ Logo 600 V-Bar ∙ Logo 500 SE V-Bar ∙ Thunder Tiger E820 14s V-Bar
skyhigh is offline        Reply With Quote Quick reply to this message
Old 12-06-2011, 04:58 AM   #385 (permalink)
Received my copterx 3x1000.. brought it to work tonight to have a play with menus on the controll box... however, jsut sits there with "Hello. Loading data"..
Manual says check data cable and make sure gyro is in working mode..
by working mode - does the gyro have to be hooked up to a bound receiver to work with the box?
I'm hoping that's the reason otherwise I may have issues Can anyone quicly confirm if the 3x1000 needs to be connected to receiver and working in order to load the menus on the control box... just so I don't sit here at work all night worrying... lol
DX7 Mode-1 | 450 pro 6s | 450 pro | Schweizer 300C Gasser Scale | T-Rex550e | Aeolus 50 | HeliX T-Rex700 fbl Gasser | HWC600 Gasser | Henseleit MPXLe | Henseleit 3DNT | Suzi-Janis 700 | Gaui NX4 | Gaui X5 | Blade 350QX
jockstrap is offline        Reply With Quote Quick reply to this message
Old 12-06-2011, 05:40 AM   #386 (permalink)
Yes. The gyro won't initialize if it does not have a signal on the tail gain input.
Goblin Speed | iKon
Old 12-06-2011, 06:02 AM   #387 (permalink)
Phew - thanks for that... that's what I thought but was a little worried
Old 12-06-2011, 08:57 PM   #388 (permalink)
The programmer without the box is now down to $29 on ebay, or lower, if you are prepared to bid.
Gaui X2 FES ZYX, Gaui X3 MB, Gaui X4 II VBar, Gaui X5 FES MB
250 DFC ZYX, 450 DFC Sport MB, ALZRC 450L Pro VBar, Devil 450 FAST VCTRC FBL
500E DFC Pro VBar, 500E SDC ZYX-S
KDS 550 VBar, 550E DHPS VBar, 550E DFC Pro VBar, 700E DFC HV iKon
beenflying is offline        Reply With Quote Quick reply to this message
Old 12-06-2011, 09:57 PM   #389 (permalink)
Waiting for a review from someone who bought it. Fingers crossed.
Whiplash G2 Gasser TRM VX300TT
Whiplash Nitro 91 HZ-R 3D & Hitori
VIBE 50 big block OS 91 HZ-R IKON
JR X9503
Blade 180CFX Gaba
Rahulgaba is offline        Reply With Quote Quick reply to this message
Old 12-07-2011, 12:25 AM   #390 (permalink)
So should i get this TAROT FBL unit? I dont fly 3D or anything. I just do pretty basic flying.
And how easy is this FBL unit to set up useing the TX?
BLADE
Old 12-07-2011, 01:33 AM   #391 (permalink)
ok - i've confirmed my 3x1000 is working and just needed to be connected to the RX to work with the programming box..
But i'll be daft if I can find where to change the swash servo type - the box and manual only has tail servo type... so does that mean the swash is fixed to one frequency that suits both analog and digital?
How have others configured swash servo type - or you havn't... ???
Old 12-07-2011, 03:33 AM   #392 (permalink)
Smile
Same feelings here ... I was worrying for the same issue last night ...
Thank you Dr. M
it is easy to invent a flying machine;
more difficult to build one;
to make it fly, is everything.
-- Otto Lilienthal, 1848-1896
Dimitris K is offline        Reply With Quote Quick reply to this message
Old 12-07-2011, 04:25 AM   #393 (permalink)
Well it pays to read the manual I guess..
It seems that when using the sticks to program you can change the swash servos to/from digital/analog in the SYSTEM menu STEP-3
However - it appears that there is NO WAY to set swash servo type using the programming box... how strange.. I would have thought you could do everything plus more using the programming box ???
Old 12-07-2011, 04:53 AM   #394 (permalink)
The 3GYS manual says that setting the tail servo to 250Hz, sets the cyclic servos to analog and setting the tail servo to 333Hz or high, sets the cyclic servos to digital.
So the Tx setting of Tail digital, cyclic analog is the 250Hz setting and the tail digital and the cyclic digital is the 333Hz setting.
Old 12-07-2011, 07:29 AM   #395 (permalink)
Well - the 3x1000 came default all analog..
I set the tail to 1520-333hz using the control box and the cyclic remained on analog setting.. so the 3GYS may be a little different in that aspect to the 3x1000..
Using the control box to set the tail servo type didn't appear to effect my cyclic servo setup on the 3x1000..
Using the sticks on the 3x1000 and in system menu step 3 - it allows you to step through a limited tail/cyclic combination of A/A A/D D/D etc for the servo choices..
However, I may play a little more to see if i'm not correct as i didn't try every combination..
Here are the 3X1000 Stick options from the manual:
*Yellow, 1 flash: All the tail and swashplate servos are
1520us analog.(default)
*Yellow, 2 flashes: Tail servo is 1520us digital,
swashplate servos are 1520us analog.
*Yellow, 3 flashes: Tail servo is 1520us digital,
swashplate servos are 1520us digital.
*Yellow, 4 flashes: Tail servo is 760us digital,
*Yellow, 5 flashes: Tail servo is 760us digital,
*Yellow, 6 flashes: Tail servo is 960us digital,
There is nowhere in the Controller box that replicates these settings unfortunately..
Maybe next firmware level? if the controller is flashable?
Old 12-07-2011, 10:05 AM   #396 (permalink)
What mounting tape are you using? On my beastx, I am using the 3m 411 tape and it works great.
Would this gyro benefit with this tape also. Has anyone tried it? I want to try this gyro on my 450pro.
Ebartolome is offline        Reply With Quote Quick reply to this message
Old 12-07-2011, 11:20 AM   #397 (permalink)
I used the tape supplied with the gyro - it is pretty stiff like the 3M
Old 12-07-2011, 02:20 PM   #398 (permalink)
This gyro seems to like pretty stiff tape. I use 2mm Fusuno gyro tape.
Goblin Speed | iKon
Old 12-07-2011, 07:02 PM   #399 (permalink)
Have you read the CX-PB001 manual. It very clear and just the same as the 3GYS manual:
Click image to enlarge
Old 12-08-2011, 01:54 AM   #400 (permalink)
Doh! no, I completely missed that in the controller manual for some reason..
AAARRRGGGHHH -
Thanks for that... all's cool now
Seems no matter how many times I look at a manual I always manage to miss something..
Insurance
Human Verification
