Old 09-25-2011, 03:21 PM   #61 (permalink)
Originally Posted by Patriek View Post
Soldering deans connectors -and getting a REALLY nice and good solder joint!!- but forgot to put heat shrink on first
Great topic
-Patriek
I do this one more than I care to admit
buzzsaw 46 is offline        Reply With Quote Quick reply to this message
Old 09-25-2011, 03:26 PM   #62 (permalink)
Same here. And it's always a clean solder when the shrink isn't there. Unsolder it , shrink it, and then struggle with a clean solder..
CAP21 is offline        Reply With Quote Quick reply to this message
Old 09-25-2011, 03:31 PM   #63 (permalink)
Yep, thats how it goes.
Old 09-25-2011, 04:44 PM   #64 (permalink)
I bought a POS plane on the weekend, to scared to fly it LOL
Went to my mates house and we had fun with his Losi and Erevo! Damn the revo was quick and only a baby 1/18!!!
helicraze is offline        Reply With Quote Quick reply to this message
Old 09-25-2011, 10:12 PM   #65 (permalink)
Diconected my lipo from the charger pulled out the bullet connectors with the battery still attached! It freaked me out!
Just got a new heli was not finished with it was seting it up till 4 in the morn, tired, drunk, i bumped the thottle stick when i went to grab it! Spooled up full throttle strait into my thumb! Bent the hell out of the fly bar, burnt up all cyclic servos, and striped my main gear! I got so pissed told my wife i was done with it put it up took it back dow the next day fixed everything! So addicting but i like it
gonepostal- is offline        Reply With Quote Quick reply to this message
Old 09-25-2011, 10:20 PM   #66 (permalink)
Glad to hear I'm not the only person that stays up all hours working on helis.
Derrick
TREX 450 Pro
Futaba 9CAP
rightto360 is offline        Reply With Quote Quick reply to this message
Old 09-25-2011, 10:27 PM   #67 (permalink)
A couple of weeks ago, I spooled up my 6HV on the bench (no main blades, tail pushrod disconnected) with the spark arrestor lead connected but the main power lead inadvertently disconnected. By the time I smelled the smoke, the heat shrink tubing over the spark arrestor resistor had burned off and the resistor was glowing. The resistor cooled down without any apparent damage. Resistance still measured the same as before and I've done 10 flights since.
HeliFreak Support
Graupner MZ-32
Old 09-25-2011, 10:43 PM   #68 (permalink)
I bet we all do it, as fool hardy as it is, thats at least part of what caused my $500 screw up.
Old 09-25-2011, 10:48 PM   #69 (permalink)
Count me in for twice leaving my TX on...
I once left my DX6i on the roof of the car and started driving out the driveway. Stopped to check for cars on the road and WACK it falls to the ground. Damage was thankfully minimal, just needed a new aerial (just busted hinge, transmitted fine) and a switch was a little bent but functional.
Trex 450 Pro V2 - Stock with BeastX
mCP X, Nano QX
Fuzzy Toaster is offline        Reply With Quote Quick reply to this message
Old 09-25-2011, 10:51 PM   #70 (permalink)
Have never left my transmitter on the roof of the car, but I left my transmitter on today. I had to stop flying to care it up again...
Derrick
TREX 450 Pro
Futaba 9CAP
Old 09-26-2011, 01:29 AM   #71 (permalink)
Had a perfectly good flying helicopter...
Decided..."hey, I need to mod my engine"
Mods went well...Broke the damn piston ring putting it back together...
No more flyable heli...
Order new ring, install, Second tank after that...Rear bearing decides it's going on permanent vacation and taking the piston and ring with it...
Order new bearings, new piston, another new ring. Install bearings...check, install piston...check, Install ring...No check...broke another one... the exact same way as the first...
Order ANOTHER ring...VERY carefully install...all is good
Second tank of re-break in...Thumb slips on collective while switching flight modes... Heli SLAMS into the grond at mach freaking 6 and proceeds to self destruct...:arg gg:
And hear I sit, no flyable heli...Because I couldn't leave well enough alone...
If it ain't broke...DON'T FIX IT!!!!
Airtronics SD10G, SK540
Synergy N5c, Novarossi .57 3DS
MAAC #85462
Down Low is offline        Reply With Quote Quick reply to this message
Old 09-26-2011, 02:06 AM   #72 (permalink)
Man that would be a month to remember! Im sory i think this post and the one where he almost hit his wife take the cake!
Old 09-26-2011, 02:07 AM   #73 (permalink)
Old 09-26-2011, 02:19 AM   #74 (permalink)
I had a cx2 the swash would always come appart, so i would squeeze it back together! Well one day i decided to fly in my back yard when i just put up a pop up pool. Well long story short swash came appart blade stike then bottom of the pool! Should have bought a new swash! If you guys dont know yet, if that happens to you get some purified water with no minerals or additives in it wash the electronics and get some alchol the highest grade you can find and dunk it under that! It will pull the water off the electronics and dry it out quick! I was running around like a mad man looking for high grade and only foun regular so i used it and it worked!
Old 09-26-2011, 03:00 AM   #75 (permalink)
New build and the tail won't act right on the bench, well duh ! the blades are backward you idiot!!
Blade Msr, mCP X, mCP S ,T-rex 450 Sport, 450pro, T-rex 550E FBL
DPete is offline        Reply With Quote Quick reply to this message
Old 09-26-2011, 06:38 AM   #76 (permalink)
Amen bro.. Ain't nothing gonna top this one...
Old 09-26-2011, 05:21 PM   #77 (permalink)
Yup...It's been a frustrating month. Pretty much all of that is due to me going back to working nights, than working on my heli dead ass tired... Not a good mix.
On the bright side I finally picked up a set of Compass 615 mains to try out. They arrived the day after the crash. Thank god, I would have been really really choked had they come the day before and got wasted with such a bone head crash.
Damage report
Mains, tails, flybar and paddles
Main shaft, tail shaft and feathering shaft
Tail hub, tail blade grips
Complete landing gear, along with my Push Glo (Just installed, first use)
Boom and supports
Mixxing arm and a couple links
Receiver tray
And a big ol' battle wound on my pipe
Havn't gone through the bearings yet but I'm counting on at least some of those too.
Pride (and joy)
Engine is "A" okay though.......
Ah well... Live and learn right ()
MAAC #85462
Old 09-26-2011, 05:25 PM   #78 (permalink)
Damage report
Boom and supports
Receiver tray
Pride (and joy)
Hmmm... You might wanna change your name.
Something like Up High....
Old 09-26-2011, 08:37 PM   #79 (permalink)
Originally Posted by nightflyr View Post
OK...
Everyone who has forgotten to turn off your Tx... Please take one step forward
Another guilty. I've had to send one of my DX7s in for reprogramming twice because of it.
TRex 450 SE V2
TRex 500 Mini VBar - I2 head
TRex 600 NSP
drb2 is offline        Reply With Quote Quick reply to this message
Old 09-26-2011, 08:42 PM   #80 (permalink)
Interesting, the tx programming can be corrupted if the batteries run dry? I would have thought that its all on flash ram and would just reset itself when you put a new battery in.
krobinson103 is offline        Reply With Quote Quick reply to this message
