Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Compass 7HV, 7HVU and Chronos
Compass 7HV, 7HVU and Chronos Compass Compass 7HV, 7HVU and Chronos Model Helicopter Discussion
Old 03-19-2012, 10:52 PM   #1 (permalink)
Default Removing the thrust bearings from main blade grip
Anyone else have a difficult time removing the thrust bearings from the main blade grips?
Lynx Team Pilot
Colonny5 is offline        Reply With Quote Quick reply to this message
Old 03-20-2012, 04:27 PM   #2 (permalink)
Heat up the grip with a lighter and it will be much easier to remove. Same with putting them back. Just use a rag or something to hold the grip in order not to burn yourself.
belcom is offline        Reply With Quote Quick reply to this message
Old 03-20-2012, 04:48 PM   #3 (permalink)
Mine actually came out super easy.. But I agree with Vlad , heat it up or even use a heat gun.
Sent from my iPhone 4S using Tapatalk
Team Rotorquest/ SAB Heli Canada
mtymyk is offline        Reply With Quote Quick reply to this message
Old 03-20-2012, 04:49 PM   #4 (permalink)
Also you might want to back out the arms on the grips first, the drilled out holes in the grips were a bit rough, and that could be what is making it tough for anything to come out of the grip
Old 03-20-2012, 06:40 PM   #5 (permalink)
Thanks for the suggestions, using heat works.
Lynx Team Pilot
Old 03-27-2012, 03:13 PM   #6 (permalink)
Mine came out easy to today I took the grips off to grease the dampners and the dang dampners are so dry I can't even get my feathering shaft out of the head block any suggestions?
"Quit crying about your airplane and fly it already!"
weaselbean is offline        Reply With Quote Quick reply to this message
Old 03-27-2012, 03:38 PM   #7 (permalink)
That one is harder if you don't have the special spindle tool. But try to apply some heat to the feathering shaft and try to move it to see if it gives. Otherwise you can probably pickup an Align 8mm/10mm spindle tool at your LHS. Or Amain Hobbies carries G-force tool which is the one I bought. I've scratched up enough spindles and the tool is golden to have in your tool box.
Old 03-27-2012, 04:18 PM   #8 (permalink)
I used a quick grip bar clamp to get my spindle moving, I also put a little silicone oil on the spindle and once that was through the first damper it slid a lot easier.
Compass 6hv & 7hv. MSH Protos. RCer Dragonus Pro & Elite. MS Hornet Custom. Robbe Eolo. MCPX.
buzzsaw 46 is offline        Reply With Quote Quick reply to this message
Old 03-27-2012, 06:07 PM   #9 (permalink)
I picked up a spindle tool as well, much easier...however since you dont have one get 2 pieces of wood. Drill a hole in one big enough for the spindle but not the head. Put some grease on the side thats not in the hole and then use the other block to push it through. I had to brace mine between 2 buckets and put everything I had into it...multiple times, but it will come free.
Team Synergy
VP Racing Fuels
Team Scorpion
Gawl is offline        Reply With Quote Quick reply to this message
Old 03-27-2012, 07:48 PM   #10 (permalink)
Ok thanks guys! I got one more question is it the 8mm or 10mm grippy tool?
Old 03-27-2012, 08:00 PM   #11 (permalink)
I got this one http://www.amainhobbies.com/product_...1-Spindle-Tool
has 4,6,8 and 10mm holes and doesn't use one way bearings.
Old 03-27-2012, 08:16 PM   #12 (permalink)
Great thanks belcom!
Old 03-28-2012, 08:19 AM   #13 (permalink)
Vlad did you know G-force is in Markham ON and you could gotten it direct?
Old 03-28-2012, 09:38 AM   #14 (permalink)
Knew they were Canadian but wasn't sure they're in Markham Learn something new every day.
Old 03-29-2012, 07:52 AM   #15 (permalink)
8mm grippy here.
1 - Diabolo 1 stuffed with, well, see below
2 - Diabolo 2 stuffed with testosterone, jittery sweat, and rippling flanks
OverTemp is offline        Reply With Quote Quick reply to this message
