Old 11-15-2011, 03:53 AM   #1 (permalink)
Bag 9 - Rotor Head Assembly - wmv 77MB
Pretty straightforward - bit unusual in that the bearings are assembled onto the spindle and then the grips heat shrunk onto the completed assembly.
Swash to grip links very robust and adjustable with turnbuckles - swash driven by two radius arms and ball links to the inner swash.
Name:	P1050279 [800x600].jpg
ID:	270302   Click image for larger version
Name:	P1050280 [800x600].jpg
ID:	270303   Click image for larger version
Name:	P1050281 [800x600].jpg
John
Old 11-15-2011, 03:53 AM   #2 (permalink)
Default New - Minicopter Diabolo Shaft Assembly
Next up the boom and tail gearbox assembly - pretty straightforward. Very simple and elegant gearbox with a novel boom securing system and also an innovative use of a toilet roll tube to stop belt slap
Bag 3 - Tail Boom and Gearbox - wmv73 MB
Name:	042 [800x600].jpg
ID:	267627   Click image for larger version
Name:	P1050230 [800x600].jpg
John
Old 11-15-2011, 03:53 AM   #3 (permalink)
Default New - Minicopter Diabolo Build Videos
Motor mounted up here and assembly of lower frames - pretty straightforward - needed to machine a further flat on the Scorpion motor to accommodate the pinion and vital to get correct engagement with the pinion
Diabolo - Lower Frames and Motor Mount - Bags 5,6,7 - wmv 88MB
Name:	P1050238 [800x600].jpg
ID:	268437   Click image for larger version
Name:	P1050240 [800x600].jpg
John
Old 11-15-2011, 03:53 AM   #4 (permalink)
Here the frame stiffeners and odds and ends finishing with fitting the left upper frame
Bag 4 - Upper Frame Assembly - wmv 50MB
Name:	P1050227 [800x600].jpg
ID:	267794   Click image for larger version
Name:	P1050228 [800x600].jpg
ID:	267795   Click image for larger version
Name:	P1050231 [800x600].jpg
John
Old 11-15-2011, 03:53 AM   #5 (permalink)
Here's the actual first build vid - assembly of the main and intermediate shafts and gears onto the right upper frame. Very precise machinging and goes together like a dream apart from the belt pulley which was a little tight - I have discussed with Gerd and he's going to increase the tolerance - we're talking hundredths of a millimetre here !!
Notable is the one way which is not on the main but the internmediate shaft and consists of TWO one way roller bearings mounted end to end ! Otherwise not much of note apart from the large alloy belt pulley for the tail drive.
Note: The 1.5mm spacer goes between the intermediate gear and the belt pulley on the intermediate shaft and not between the belt pulley and the bearing block as shown in v1 of the video - been corrected in v2 !!
Also note the locking collar has been replaced by a spacer
Video 2 - Shaft Assembly - wmv 118MB
Name:	020 [800x600].jpg
ID:	267294   Click image for larger version
Name:	P1050225 [800x600].jpg
John
Old 11-15-2011, 03:53 AM   #6 (permalink)
Here's the tail rotor assembly and linkage including the innovative pushrod supports - no real surprises here - the tail is similar to the Joker 3 but has detachable CHinese weights on the tail blade screws.NB The original build instructions showed the thrust bearing between the radial bearings - in the latest advice it is shown on the outside.
Bags 10,11 - Tail Rotor & Pushrod Assembly - wmv - 108MB
Name:	156 [800x600].jpg
ID:	270324   Click image for larger version
Name:	159 [800x600].jpg
ID:	270325   Click image for larger version
Name:	170 [800x600].jpg
ID:	270326   Click image for larger version
Name:	177 [800x600].jpg
ID:	270327   Click image for larger version
Name:	new tail rotor [800x600].jpg
John
Last edited by Jason Cole; 01-23-2020 at 08:40 AM.. Reason: Amended tail rotor assembly
Old 11-15-2011, 03:53 AM   #7 (permalink)
Default Review - Minicopter Diabolo Build Videos
Minicopter been around for a long time producing uber-quality boutique helicopters - well known for their ruggedness the Joker series have found favour with those in the AP line of work and those who want a fine German engineered and produced quality helicopter. What is not so well know is that he Joker3 has regularly given the TDR a good run for its money in German Speed Cups and taken line honours on a number of occasions.
The Speed Cup win by the Diabolo at IRCHA 2011, narrowly beating the TDR by a whisker put international focus on the Diabolo, which incidentally is named after a childs spinning top and a particular hunting bullet! ANyway I put my hand up very early on for a piece of the action and was excited by my Diabolo arriving yesterday
Assembly Manual (English)
Video 1 - What's In The Box - wmx - 48MB
Bag2 - Shaft Assembly - wmv 118MB
Bags 5,6,7 - Lower Frames and Motor Mount - wmv 88MB
Bag 8 - Swash & Servos - wmv 77MB
Pics of electronics install
Diabolo Updates and Mast CHange - wmv - 117MB
Name:	Diabolo_04 [800x600].jpg
John
Old 11-15-2011, 09:25 AM   #8 (permalink)
You lucky dog!
I will be looking forward to this one as the others boutique heli build vids you have done are always a delight!
By the way, you are responsible for me buying a Srimok N and a TDR which I wouldn't even have known of. It will be interesting to have your insight on this heli versus or rather besides the TDR
Ben
Goblin 500 IKON w/ gov, Quantum 4115-1200, Hitec 5245, BLS251
DX8, RF6
HeliBenj is offline        Reply With Quote Quick reply to this message
Old 11-15-2011, 11:25 AM   #9 (permalink)
Thanks for putting up a video so quickly.
I too would love to hear your views on how it compares to a TDR?
Looking forward for more, when you have time.
minicopter DIABOLO LOGO 550sx
scorpion spirit futaba IISI
smsodhi is offline        Reply With Quote Quick reply to this message
Old 11-16-2011, 05:00 AM   #10 (permalink)
Second video up showing assembly of shafts and gears onto frames
John
Old 11-16-2011, 08:21 PM   #11 (permalink)
What a magnificent piece of engineering!
Dogdocphil is offline        Reply With Quote Quick reply to this message
Old 11-16-2011, 11:16 PM   #12 (permalink)
thanks for doing the videos! I just got my kit - though apparently canopies are backordered.... still, I'll be following right behind you :-)
seanq222 is offline        Reply With Quote Quick reply to this message
Old 11-17-2011, 09:51 AM   #13 (permalink)
Any ideas WHEN the canopies will be shipped ????
I got mine yesterday, no instructions, no canopy
I'm very appreciative you are doing the build thread, otherwise, I would be scare of messing up the build. Looks like it is an easy feat
plankdriver is offline        Reply With Quote Quick reply to this message
Old 11-17-2011, 11:52 PM   #14 (permalink)
Bri
Subscribed John.
Nothing like watching an accurate build of a high quality heli.
Maybe one of these days when I win the lottery, I will own a "Diabolo".
Brian
T-Rex 700F3C / T-Rex 450 Pro / Blade mCPX / Blade mSR / Blade mCX / Walkera 53Q3
JR X9503 /
Spektrum DX7
Phoenix Sim
Bri is offline        Reply With Quote Quick reply to this message
Old 11-18-2011, 03:26 AM   #15 (permalink)
Boom assembly and tail gearbox vid posted here
John
Old 11-18-2011, 07:18 PM   #16 (permalink)
It's beautiful, just beautiful. Can't wait for the next one. Mercuriell, you always do such a beautiful job with these boutique builds. Thanks for the vids!
David
HD Cell 500 w/ Ikon, Blade 130x, Citizen #258.
minnzoo is offline        Reply With Quote Quick reply to this message
Old 11-18-2011, 08:09 PM   #17 (permalink)
And here's the frame assembly
John
Old 11-18-2011, 08:38 PM   #18 (permalink)
Thats it! Im addicted! love the Vids!
Old 11-18-2011, 11:39 PM   #19 (permalink)
The Capi
Love your esoteric builds John.
Old 11-20-2011, 08:21 AM   #20 (permalink)
That's one beautiful heli and it looks strong too.
pmerritt is offline        Reply With Quote Quick reply to this message
