Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 630/700/770
SAB Goblin 630/700/770 SAB Heli Division 630/700/770 - Goblin Helicopters Factory Support
Like Tree1Likes
Old 11-23-2011, 08:54 AM   #1 (permalink)
Default What's your Goblin Setup Thread
Hi All, I seen this in a Synergy thread done by "ElectricSheep" (thanks for the idea) and thought that it would work here as well. Quote this and fill in all that apply.
  • Flight Style: (Sport / Smooth 3D / Smack 3D / Big Sky / FAI / Speed
  • FBL System: (Brand, Model, Version [if applicable])
  • Motor: (Brand, Model, KV)
  • Pinion:
  • Target Headspeed(s):
  • ESC: (Brand & Model/Size)
  • Governor: (ESC, FBL System, none, etc.)
  • BEC: (Brand & Model, or NONE if straight from pack)
  • RX Pack: (Brand, Model, Chemistry, Capacity) [e.g., Hyperion LiFePO4 6.6v 2S 2100mAh RX Pack])
  • Cyclic Servos: (Brand, Model)
  • Tail Servo: (Brand, Model)
  • Main Blades: (Brand, Model [if applicable], Length)
  • Tail Blades: (Brand, Model [if applicable], Length)
  • Lipos: (Brand, Model, C-Rating, Cells, Capacity) [e.g.,Thunder Power G6 65C 6S 4400 mAh in series as 12S)
  • Anything else: (Buffer pack w/Jive, Fromeco DC-Up II, etc.)
Goblin, SK720 / TREX 450 Sport FBL SK720
TREX 600 3G, CPii
MSR / mCPX brushless/YAK / McFoamy
teb1963 is offline        Reply With Quote Quick reply to this message
Old 11-23-2011, 09:00 AM   #2 (permalink)
  • Flight Style: Sport / Smooth 3D / Big Sky
  • FBL System: Skookum 720
  • Motor: HKiii 4035-500
  • Pinion: stock
  • Target Headspeed(s):1500-1900
  • ESC: Jive 80HV
  • Governor: (in ESC.)
  • BEC: (?)
  • RX Pack: Skookum 720 with 2-spektrum satellites
  • Cyclic Servos: (BLS451)
  • Tail Servo: JR8900
  • Main Blades:Stock SAB
  • Tail Blades: Stock SAB
  • Lipos: (not sure yet)
  • Anything else:
Heres mine. Terry
TREX 600 3G, CPii
Old 11-23-2011, 12:55 PM   #3 (permalink)
Mine
  • Flight Style: Smooth 3D
  • FBL System: V-Bar 5.2
  • Motor: Scorpion HK5025 5+6 x 1,6mm YY
  • Pinion: 20t
  • Target Headspeed(s): 1400-2000rpm
  • ESC: Robbe Roxxy 9120-12 Opto
  • Governor: V-Bar
  • BEC: Western Robotics Hercules SuperBEC
  • RX Pack: none
  • Cyclic Servos: Savox SB-2271SG
  • Tail Servo: Futaba BLS 256HV
  • Main Blades: SAB 700mm Green Edition
  • Tail Blades: SAB 110mm / EDGE 115m (second if the SAB are not that good)
  • Lipos: 2x Turnigy 6S 4000mAh 40C (not sure)
  • Anything else: Mikado carbon servo arms
Armadillo is offline        Reply With Quote Quick reply to this message
Old 11-23-2011, 01:41 PM   #4 (permalink)
Smile Setup
  • Flight Style: Beginner
  • FBL System:SK720
  • Motor: Strecker 435.30 LRK 430KV
  • Pinion: ?
  • Target Headspeed(s): 1300-1700
  • ESC:Jive 80 HV
  • Governor: Jive 80HV
  • BEC:Jive
  • RX Pack: T8FG; Futaba S-Bus
  • Cyclic Servos:BLS451
  • Tail Servo: BLS254)
  • Main Blades: Brand
  • Tail Blades: Brand
  • Lipos: 2x 6S Robbe Roxxy 5000mAh 20C
  • Anything else:
Awaiting....
Pampaflieger is offline        Reply With Quote Quick reply to this message
Old 11-23-2011, 03:14 PM   #5 (permalink)
Flight Style: Smack 3D / Speed
FBL System: Mikado Mini V Bar 5.2 black with governor
Motor: Scorpion 5035 rewinded to 500 KV or KDE 495
Pinion: ?
Target Headspeeds:2150 Smack - 1750 lov
ESC: YGE 160 HV 16S
Governor: V-Bar
BEC: Hercules BEC or if I go 16s / a special made from a guy in Germany up to 17S
RX Pack: none
Cyclic Servos: JR 8717
Tail Servo: JR 8900
Main Blades: Original and next any 710mm
Tail Blades: Original
Lipos:4 4s Gens Ace for an 16S
Anything else:
This should be mine-maybe a different Motor.
.....any better option than GOBLIN and Vortex VX1.... not
Regards Janis
Vom Feinsten is offline        Reply With Quote Quick reply to this message
Old 11-23-2011, 03:50 PM   #6 (permalink)
Default Mine
Flight Style: (Sport / smooth 3d
FBL gt5
Motor: 4535-550le
Pinion:not sure
Target Headspeed(s): 2100-1900
ESC: HELI jive
Gov jive
BEC: none
RX Pack: TP 1900
Cyclic Servos: outrage 8.4
Tail Servo: outrage 8.4
Main Blades: stock
Tail blades stock
Lipos: Thunder Power G6 65C 6S 4400 mAh in series as 12S)
TDR, Srimok N x 2, Banshee 31, Dune!
jhunter is offline        Reply With Quote Quick reply to this message
Old 11-23-2011, 04:51 PM   #7 (permalink)
My setup.
  • FBL System: Vbar full size 5.2 pro
  • Motor: Scorpion 5020, 450KV
  • Pinion: 22
  • Target Headspeed(s): 1450-1900
  • ESC: Hawk 120HV
  • Governor: Vbar
  • BEC: NONE
  • RX Pack: 2 x Rhino 1050 mah 2s 30C wired in parallel
  • Cyclic Servos: Outrage 8.4v
  • Tail Servo: Outrage 8.4v
  • Main Blades: SAB
  • Tail Blades: SAB
  • Lipos: Nano-Tech 4500mah, 45C, 6s x 2 in series for 12s
//Dennis.
soXos Strike7 : soXos 600 : soXos 550 : soXos F3C 800
Protos 380 : soXos DB7 nightflyer : Jeti DS-16 & DS-12 : Mini Protos FBL Stretch : Logo 600
I am www.soxosaustralia.com.au | VTX blades | 1st-RC Products | EGODRIFT motors
Thunder Fighter is online now        Reply With Quote Quick reply to this message
Old 11-24-2011, 11:47 AM   #8 (permalink)
FBL System: Mikado VBar 5.2
Motor: powercroco 4535 4+5x1,7YY ns 490
Pinion: 17 / 18
Target Headspeed(s): 2000-2200
ESC: modified 16s-capable YGE
Governor: VBar
BEC: custom HV / high current, 16s-capable
RX Pack: 2s ~1Ah backup
Cyclic Servos: Futaba BLS 157 HV
Tail Servo: Futaba BLS 256 HV
Main Blades: CY 710s
Tail Blades: Edge 115 or CY 105, depends
Lipos: Thunder Power G6 65C 8S 3300mAh in series as 16S
Anything else: -
SuziLAOS-DNHP-CenturioMax-Protos500-Logo400-500-600SE
worldofmaya is offline        Reply With Quote Quick reply to this message
Old 11-25-2011, 10:48 AM   #9 (permalink)
  • Flight Style: Smack 3D /Speed
  • FBL System: full size vbar 5.2
  • Motor: scorpion 4530-540 le
  • Pinion:20t
  • Target Headspeed(s): 2100-2200
  • ESC: CC ice2 160 until I get the new scorpion commander v 130
  • Governor: Castle, vbar later
  • BEC: Gryphon Quasar
  • RX Pack: none
  • Cyclic Servos: Outrage bls9180
  • Tail Servo: Outrage bls9188
  • Main Blades: Sab
  • Tail Blades: Sab
  • Lipos: TP 5000 65c 12s, Pulse 4500 65c 12s
  • Anything else: I think thats it, I just ordered the rest of this stuff so should be ready when the kit arrives.
-Phillip Johnson, AMA #954735
LegndarySaiyan is offline        Reply With Quote Quick reply to this message
Old 11-26-2011, 12:31 AM   #10 (permalink)
Originally Posted by LegndarySaiyan View Post
  • Flight Style: Sport, Mild 3D
  • Motor: Xera 4530?
  • Pinion:20t
  • Target Headspeed(s): 1900/2000/2100
  • ESC: HeliJive
  • Governor: VBar
  • BEC: HeliJive @5.6
  • RX Pack: none
  • Cyclic Servos: BLS-451
  • Tail Servo: 256HV
  • Main Blades: Sab
  • Tail Blades: Sab
  • Lipos: TP 4400 45C, 5 Sets
Synergy N5C sitting in Box...
Mystic3D is offline        Reply With Quote Quick reply to this message
Old 11-28-2011, 04:54 AM   #11 (permalink)
i have all these parts waiting on my desk except main batteries (i want them to be fresh)
Flight Style: Smooth 3D, Smack 3D, Speed
FBL System: mini-V-Bar 5.2 Pro
Motor: Scorpion 4525-520LE
Pinion: 21-22?
Target Headspeed(s): 2000-2250
ESC: HeliJive HV 120+
Governor: V-Bar with modified Hyperion phase sensor
BEC: WR Hercules Super Bec
RX Pack: small 350mAh 2S (45-90C) pack for safety
Cyclic Servos: Outrage Torq BL9180
Tail Servo: Outrage Torq BL9088
Main Blades: i try the stock ones that come with the kit
Tail Blades: also stock
Lipos: TP65C series @ 12S
Anything else:
Tohtori R is offline        Reply With Quote Quick reply to this message
Old 11-28-2011, 10:44 PM   #12 (permalink)
  • Flight Style: Smack 3D /Speed/Technical 3d, and slow Techical 3d
  • FBL System: Blue full size vbar 5.2
  • Motor: KontroniK 700-52 Black Edition
  • Pinion:20t
  • Target Headspeed(s): 1700/1850/1950/2000/2100
  • ESC: Heli Jive Black Edition
  • Governor: KontroniK Mode 4
  • BEC: KontroniK intrernal
  • RX Pack: none
  • Cyclic Servos: Bls 255
  • Tail Servo: Bls 256
  • Main Blades: Sab/Mav G5/ Edge
  • Tail Blades: Sab/Edge
  • Lipos: TP 4400 65c 12s
  • Anything else:
Justin Harris It is better to measure 10 times and cut once, than to cut 10 times and measure once.
Sponsored by :
KONTRONIK, OPTIPOWER, PRC, CANOMOD
jhheli is offline        Reply With Quote Quick reply to this message
Old 11-29-2011, 12:52 PM   #13 (permalink)
  • Flight Style: Smooth 3D/FAI/Speed/Hard Sport
  • FBL System: Full size black vBar
  • Motor: Scorpion LE 4525-500
  • Pinion: Stock
  • Target Headspeed(s): 1700-2200
  • ESC: Jive 120HV
  • Governor: ESC
  • BEC: Slave/master from Jive
  • RX Pack: N/A
  • Cyclic Servos: BLS 451
  • Tail Servo: BLS 251
  • Main Blades Stock SAB
  • Lipos: (Brand, Model, C-Rating, Cells, Capacity) [e.g.,Thunder Power G6 65C 6S 5000mAh and 3850mAh (speed runs) in series as 12S
  • [B]
Yea..
-Goblin 700: Crashed but re-building, still needing electronics
-Goblin 630: CC Ice 120HV, vBar
scoti333 is offline        Reply With Quote Quick reply to this message
Old 12-09-2011, 03:05 PM   #14 (permalink)
What are your thoughts on these two setups:
#1
* Flight Style: Smooth 3D
* FBL System: V-Bar 5.2
* Motor: Scorpion HK4525 520kv
* Pinion: 21t
* Target Headspeed(s): 1800-2200rpm
* ESC: Jive 120
* Governor: Jive
* BEC: Jive @ 6v
* RX Pack: none
* Cyclic Servos: Futaba BLS451
* Tail Servo: Futaba BLS 251
* Main Blades: SAB 700mm Green Edition
* Tail Blades: SAB 110mm
* Lipos: 2x Turnigy 6S 4000mAh 40C (not sure)
or
#2
* Pinion: 21t
* ESC: Hawk 120
* Governor: Vbar
* BEC: WR Herculese Super BEC @ 8.4v
* RX Pack: none
* Cyclic Servos: Futaba BLS157HV
* Tail Servo: Futaba BLS 256HV
About the same cost wise, but what about performance?? Are the high voltage servos worth it??
d-rudie is offline        Reply With Quote Quick reply to this message
Old 12-10-2011, 06:47 AM   #15 (permalink)
Ordered for second batch due in March 2012. Anticipation is great.
  • Flight Style: (Sport / Smooth 3D / Big Sky / Speed
  • FBL System: VBar Full size 5.2 Pro)
  • Motor: (Pyro 700-52L)
  • Pinion: Stock
  • Target Headspeed(s):1900,2000,2150
  • ESC: (Brand & Model/Size)Castle ICE2 HV120
  • Governor: VBar with phase sensor
  • BEC: (None)
  • RX Pack: (TP 2SLipo 1900mAH)
  • Cyclic Servos: (MKS, HV950BL cyclics)
  • Tail Servo: (MKS HV 980BL tail)
  • Main Blades: (SAB 693 FBL)
  • Tail Blades: (SAB 105)
  • Lipos: (Thunder Power G6 65C 6S 5000 mAh in series as 12S)
  • Anything else: Spektrum telemetry module, Batt voltage.
[/quote]
chestcutter is offline        Reply With Quote Quick reply to this message
Old 12-12-2011, 11:15 PM   #16 (permalink)
  • Flight Style: Sport / Smooth 3D / Speed
  • FBL System: Mikado VBar pro 5.2 (full size)
  • Motor: Scorpion 4525-520 LE (520 Kv)
  • Pinion: 24t
  • Target Headspeed(s): 2,250
  • ESC: Castle Ice2 HV 160
  • Governor: Mikado VBar pro 5.2 w/ Hyperion phase sensor
  • BEC: None, JR VR5203 regulator on tail servo only
  • RX Pack: Thunder Power LiPo 2S (7.4v)
  • Cyclic Servos: JR 8917 High Voltage (direct from LiPo RX pack)
  • Tail Servo: JR DS8900G (via JR regulator)
  • Main Blades: 690mm (Stock)
  • Tail Blades: 115mm (Stock)
  • Lipos: Thunder Power G6 65C 6S 5000 mAh in series as 12S
  • Anything else: E-Flite EC5 connectors, Spektrum DSMX satellites, Green cable braid
The only item above that I have not yet purchased is the RX pack, as I am not certain what the largest size (1900, 2700, 3800 mAh) is that will fit. Will determine this after construction.
Cris
SynergyAero is offline        Reply With Quote Quick reply to this message
Old 12-13-2011, 01:08 AM   #17 (permalink)
  • FBL System: SK720
  • Motor: Self wound 5035 kit.... shooting for 380kv some YY pattern
  • Pinion: 24T
  • Target Headspeed(s):2300
  • ESC: YGE Hv 160
  • Governor: SK720
  • BEC: WRL-HBECS off of 1x 8s lipo at 8.4V
  • RX Pack: n/a
  • Cyclic Servos: Outrage BL 9180 HV
  • Tail Servo: Outrage BL 9188 HV
  • Main Blades: SAB 770
  • Tail Blades: SAB 115
  • Lipos: Thunder Power G6 65C 8S 3300 mAh in series as 16S)
  • Anything else: YGE cap pac
gunna be sweet, but have to wait until the 770 version comes out with this power to weight ratio should be awesome.
love the other 16s set up to
TRex-800E /Scorp 5035-478 5+5YY 1.8mm/VBar Blue Full 5.2Pro /CC Hv160/WR-Herc Super BEC/RJX 810mm 3D /RotoTech 115 + QuickUk Tail/ Hitec 7940th HV/TP 5000 65c
f22warzone is offline        Reply With Quote Quick reply to this message
Old 12-14-2011, 01:45 PM   #18 (permalink)
  • Flight Style: (Sport / Big Sky)
  • FBL System: (Skookum SK-720)
  • Motor: (Scorpion 4035-560)
  • Pinion: (21T pulley)
  • Target Headspeed(s): (1850-2000)
  • ESC: (Castle Creation ICE2 120HV)
  • Governor: (Skookum)
  • BEC: (WR Super Hercules)
  • RX Pack: (2200mah Voltz 2S 45C Lipo)
  • Cyclic Servos: (Spektrum H6040's or JR 8717's)
  • Tail Servo: (Futaba BLS-251)
  • Main Blades: (Stock or Edge FBL 693's)
  • Tail Blades: (Stock or Edge 105's)
  • Lipos: (2 x Turnigy 35C 6S 5000mah, 2 x Voltz 35C 6S 5100mah)
  • Anything else: (Futaba R6203 Receiver)
Can't wait
WannaBe3D is offline        Reply With Quote Quick reply to this message
Old 12-19-2011, 03:32 AM   #19 (permalink)
Just want to say thanks for this thread and every-ones input,
I've learned more by seeing consensus and preference than what 20 topical threads could provide! As a lone flyer stepping up to do a first time 700 size build, fbl at that, this build will present a few new challenges, but sorting out the right componants is half the battle - Your responses in this thread have really helped me out!
-Thanks again!
RUN4COVER is offline        Reply With Quote Quick reply to this message
Old 12-19-2011, 04:52 PM   #20 (permalink)
  • FBL System: Microbeast
  • Motor: Pyro 700-52 or Scorpion 4525-520 LE (520 Kv)
  • Pinion: stock
  • Target Headspeed(s): 1950 - 2050
  • ESC: Heli Jive 120 HV
  • Governor: Heli Jive 120 HV
  • BEC: Heli Jive and / or WR Hercules Super BEC or Gryphon Quasar
  • RX Pack: none
  • Cyclic Servos: BLS 451 or MKS HBL 950 HV
  • Tail Servo: BLS 256 HV or MKS HBL 980 HV
  • Lipos: Turnigy or Zippy 40C 6S 5000 mAh in series as 12S
  • Anything else: nothing
Still have to decide whether HV or not .
Greetz Marco
Align T-REX 700 E BeastX, Pyro 700-52L, Power Jive 120 HV
T-REX 600 ESP Jive 80LV, BLS451, GY520, BLS 254
ghost400 is offline        Reply With Quote Quick reply to this message
