Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 630/700/770
SAB Goblin 630/700/770 SAB Heli Division 630/700/770 - Goblin Helicopters Factory Support
Like Tree1Likes
Old 09-20-2014, 11:42 PM   #261 (permalink)
Goblin Speed
Flight Style: Hard 3D/Speed
FBL System: Vbar Silverline
Motor: Scorpion 4535-450LE
Pinion: 24
Target Headspeed(s): 1900/2200/2600
ESC: KOSMIK 200
Governor: KOSMIK
Cyclic Servos: BK 8001
Tail Servo: BK 8005
Main Blades: RAIL 716
Tail Blades: RAIL 106
Lipos: Pulse 7s 4500 45c
Backup: Optipower Ultraguard
Tri$tate 3D | BK Servo | Switch Blades | HeliDirect | Canomod
cjpainten is offline        Reply With Quote Quick reply to this message
Old 10-04-2014, 01:44 PM   #262 (permalink)
Default What's your Goblin Setup Thread
Goblin 700C Full carbon
FBL System: Demon 3SX
Motor: Xnova 4530-500
Pinion:24
Target Headspeed(s):1850-2150
ESC: Kosmik 160
Governor: Kosmik
BEC: Kosmik
Cyclic Servos: Savox 2284SG HV
Tail Servo: Savox 2283MG HV
Main Blades: Zeal 700
Tail Blades: Zeal 115
Lipos: PU - 5000/45C
Team - "Self Interests" -
Old 10-07-2014, 08:50 AM   #263 (permalink)
Scorpion 5035
ug6gkg is offline        Reply With Quote Quick reply to this message
Old 10-22-2014, 12:03 PM   #264 (permalink)
Goblin 700 comp
Scorpion hkiii 4035 530 v3
Castle pro bec
Castle creations 160hv
Align ds700h cyclic servos
Spartan vortex vx1n
2 sdmx sats
2 pulse 5000 45c 6 cells
Sab main and tail blades
24t pulley for 2200 to 2300 head speed
Changing for torque tube tsa 700e to the goblin comp kit should be an interesting Chang
Sent from my SAMSUNG-SM-N900A using Tapatalk
Rotary wing team pilot, halo team pilot.
Thrumpness is offline        Reply With Quote Quick reply to this message
Old 10-22-2014, 01:30 PM   #265 (permalink)
Goblin 630
  • Flight Style: Sport
  • FBL System: iKON V2 w/ Bluetooth Module
  • Motor: Scorpion 4035-560
  • Pinion: 21T
  • Target Headspeed(s): 1950, 2100, 2250
  • ESC: CC Edge 120HV
  • Governor: iKON
  • BEC: Gryphon Vega Voltage Regulator w/ Pin-Flag Switch
  • RX Pack: Pulse 2S 3600 mAh
  • Cyclic Servos: BK DS-7001HV
  • Tail Servo: BK DS-7005HV
  • Main Blades: SAB Stock 630mm
  • Tail Blades: SAB Stock 105mm
  • Lipos: Thunder Power G8 Long Configuration 45C 6S 3850 mAh in series as 12S and THOR 45C 6S 3800 in series as 12S
  • Anything else: 2 Spektrum DSMX Satellite Rx's, 2mm Main Frame, HPS Head w/ Heavy Duty Main Links, Competition Tail Rotor, Quick Release Canopy Mounts,
Goblin 700 (Green)
  • Motor: Scorpion 4525-520 Ultimate
  • Pinion: 23T
  • Target Headspeed(s): 1775, 1950, 2150
  • ESC: CC Edge 160HV
  • Governor: iKON
  • Cyclic Servos: Futaba BLS272SV
  • Tail Servo: Futaba BLS276SV
  • Main Blades: SAB Stock 690mm
  • Tail Blades: SAB Stock 115mm
  • Lipos: (2) Glacier 45C 12S 5000 mAh Stick Packs
  • Anything else: 2 Spektrum DSMX Satellite Rx's, HPS Head w/ Upgrade Grips and Heavy Duty Main Links, Competition Tail Rotor, Competition ESC Support, Quick Release Canopy Mounts, Green Lynx Frame Washers
Synergy 766:Pyro 750 Comp, Kosmik 160, Futaba, CGY750
Synergy E5SS: Pyro 700, Jive Pro, Futaba, CGY750
Synergy N5c: OS 55HZ-R, Hatori, Futaba, CGY750
Futaba T18SZ
HeliDinoRC is offline        Reply With Quote Quick reply to this message
Old 11-08-2014, 11:32 AM   #266 (permalink)
Default G700 Pinion Change
I checked the logs and the ESC was running just over 80% with the 23T pinion @ 2150 RPM so I installed the 22T pinion, which should be a more optimized setup.....we'll see after the weekend!
Futaba T18SZ
Old 12-09-2014, 02:43 PM   #267 (permalink)
Goblin 700c
https://www.helifreak.com/showthread...49#post6236349
Flight Style: (Sport / 3D)
FBL System: ( bavarianDEMON BD3sx V202)
Motor: (Pyro 750-56c)
Pinion: (19T)
Target Headspeed(s): (HS 1900-2150)
ESC: (Kosmik 160)
Governor: (Kosmik 160)
BEC: (Kosmik 160 / 7.4V)
RX: (Spektrum AR7010 + SAT dsmx )
Cyclic Servos: (Torq 9180)
Tail Servo: (Torq 9188)
Main Blades: (SAB 690mm Blackline carbon blades ( Red ) 2D)
Tail Blades: (SAB 115mm Carbon Fiber)
Lipos: (Pulse 45C 6S 4500 mAh in series as 12S)
Upgrade´s: (Spaniard - FULL CARBON, LynX - Ultra Swash Plate - Black, LynX - ULTRA MAIN GEAR SET, LynX - ULTRA FLEX LANDING GEAR SKID, LynX - Ultra Landing Gear Support - Red Devil, SHS Canopy mount, KDE Performance Tail Control)
Diabolo 550 / Diabolo 700BE /Triabolo 700 / Srimok 90N
Goblin-700/700C/KSE/BlackNitro/380/Logo700/Trex600NSP
Jeti DS-14 Edition
Grittner is offline        Reply With Quote Quick reply to this message
Old 03-08-2015, 04:37 PM   #268 (permalink)
Here's what I have planned. Any input much appreciated.
770 Carbon Edition
Flight Style: Smooth 3D progressing over time.
FBL System: Vbar full blueline
Motor: Scorpion 4525-520U
Pinion: -- don't know. Need guidance.
Target Headspeed(s): 1650/1750/1850
ESC: YGE 160
Governor: VBar
BEC: Gryphon Quasar
Cyclic Servos: MKS DS660A+
Tail Servo: MKS DS760
Main Blades: Stock 770
Tail Blades: Stock 110
Lipos: Gens Ace 6S 4400
Backup: Scorpion BUG
AMA 373608
K2Freak is offline        Reply With Quote Quick reply to this message
Old 04-07-2015, 11:04 PM   #269 (permalink)
planning for a Goblin 700 competition orange kit
Esc: Yge 120hv
Motor: Scorpion 4025-520 ultimate
Fbl: Ikon
Servos: Bk 7001hv cyclics Bk 8005 brushless tail servo
Batteries: Pulse 12s 5000mah 45c
Goblin 500: Kontronik Jive, Kontronik Pyro, MKS, Pulse, Mini Vbar
Goblin 700:Xnova, Yge, BK, Pulse, Ikon
All flown By a Spektrum Dx7 gen 1, and A Spektrum Dx9
Team Helidirect
Helis4Life77 is offline        Reply With Quote Quick reply to this message
Old 04-08-2015, 01:09 AM   #270 (permalink)
700 Competition
Flight Style: 3D
FBL System: Vortex Vx1n
Motor: XNOVA 4530-500 8D
Pinion: stock
Target Headspeed(s): 2150
ESC: KOSMIK 200HV
Governor: KOSMIK Mode 4
BEC: KOSMIK @ 7.4
Cyclic Servos: MKS 950
Tail Servo: MKS 980
Main Blades: SAB Black line
Tail Blades: Stock
Lipos: Swixcore 12S 60C 5000
630 Carbon 1
Flight Style: 3D
Motor: Scorpion 4035-560 III
Pinion: stock
Target Headspeed(s): 2300
ESC: KOSMIK 160HV
BEC: KOSMIK @ 7.4
Cyclic Servos: MKS 960
Tail Servo: MKS 990
Tail Blades: Stock
Lipos: Pulse 4100 6S x 2
630 Carbon 2
Flight Style: 3D
Pinion: stock
ESC: Castle Creation Edge 120HV
Governor: CC
BEC: 2S Lipo
Cyclic Servos: BK 7001
Tail Servo: TORQ 9288
Tail Blades: Stock
Goblins 380/500/570/630/700
xahhax is offline        Reply With Quote Quick reply to this message
Old 04-21-2015, 11:24 AM   #271 (permalink)
700 Competition
Flight Style: (Sport / Smooth 3D
FBL System: (VBar Full size)
Motor: (KDE, 700XF, 505KV)
Pinion:19
Target Headspeed(s):1900 - 2000
ESC: (YGE &160 HV)
Governor: (ESC Gov Store)
BEC: (NONE )
RX Pack: (Pulse LiPO 7.4v 2S 2550mAh RX Pack])
Cyclic Servos: (BK DS 7001 HV)
Tail Servo: (JR SPG01)
Main Blades: (Align)
Tail Blades: (Align 115MM)
Anything else: (None)
Gttahoe is offline        Reply With Quote Quick reply to this message
Old 06-03-2015, 01:25 AM   #272 (permalink)
Goblin 700 Competition yellow and orange kit (on its way)
Flight style: mild 3d and smooth 3d:
Fbl system: ikon
Motor: Xnova 4530-525
Target headspeed: 1900-2100
ESC: Yge 160hv v5
Rx pack: 2s 1350mah pulse
Cyclic servos: BKds7001hv
Tail servo: BKbl02
Main blades: stock Sab 690mm blades
Lipo: Pulse 12s 5000mah 45c stick packs
All powered by a JR XG8. (In the mail as well)
Team Helidirect
Old 06-15-2015, 11:28 AM   #273 (permalink)
Goblin 700 comp
Scorpion 4530-450, Rotorstar 180 esc, R2prototyping HV2alu bec, Spirit FBL, Futaba 255/256, 14S.
minicopter DIABOLO LOGO 550sx
scorpion spirit futaba IISI
smsodhi is offline        Reply With Quote Quick reply to this message
Old 06-17-2015, 01:05 PM   #274 (permalink)
700 v2
scorpion 4525-520
3*bk7001hv
savox sh1290mg
cc bec pro, running 6v
cc ice 160a hv
msh brain
turnigy 5000mah heavy duty 60c *2
stock blades
heli option tail upgrade
jerry t petersen. ishøjheliklub
jonnyflox is offline        Reply With Quote Quick reply to this message
Old 07-15-2015, 05:02 PM   #275 (permalink)
Goblin 700 Carbon (Yellow/Black)
Flight Style: 3D
FBL System: VBar Silverline
Pinion: 22T
Target Headspeed(s): Still working it out (2000 - 2200)
ESC: Castle HV 160
Governor: VBar (using Castle ESC RPM output)
RX Pack: Pulse 2250 LiPo
Cyclic Servos: BK Brushless HV
Tail Servo: BK Brushless HV
Main Blades: Stock
Tail Blades: Stock
Lipos: GensAce 4400 (x2) / Lectron 5200 (x2)
Anything else: TM1100 Telemetry + AR8000 Recv + 1 Sat
ryanha is offline        Reply With Quote Quick reply to this message
Old 11-18-2015, 01:08 AM   #276 (permalink)
Goblin 700 (Green)
Flight Style: Sport
FBL System: Vbar silverline
Motor: Scorpion 4530-500kv
Pinion: 21
Target Headspeed(s): <1600, 1800, 2000
ESC: Kontronik kosmik 200cool
Governor: Kosmik
BEC: Kosmik
RX Pack: Flightpack
Cyclic Servos: Futaba ???
Tail Servo: mks 760
Main Blades: SAB Stock 690mm, radix v2 690mm, switchblade 713mm
Tail Blades: edge 115mm, edge nb 105mm
Lipos: (2) Gensace 12s 5000mah 45c
Anything else: HPS2 Head, Competition Tail Rotor with boom, Quick Release Canopy Mounts, optipower ultraguard,
338federal is offline        Reply With Quote Quick reply to this message
Old 01-03-2016, 05:09 AM   #277 (permalink)
Here's mine:
Goblin 630 Comp
  • Flight Style: ‘Old man’ Sport
  • FBL System: Spirit Pro
  • Motor: Scorpion HKIII 4035 560Kv
  • Pinion: 21T
  • Target Headspeed(s): 1900, 2000, 2100
  • BEC: Gryphon Quasar LMT
  • Cyclic Servos: KST HV brushless
  • Tail Servo: KST HV Brushless narrow band
  • Main Blades: MS Composite Rapid 560mm wide chord
  • Lipos: Nono 65C 3850 mAh 12S (2 x 6s)
  • Anything else: ‘Speed up’ tail pulley for lower headspeeds.
Goblin 770 Carbon Comp
  • FBL System: Vbar Silverline
  • Motor: Kontronik Pyro 750 560Kv (to be rewound to 500Kv Comp+ spec)
  • Pinion: 18T (will change to 20t on re-wind)
  • Target Headspeed(s): 1700, 1825, 1950
  • ESC: YGE 160HV
  • RX Pack: Zippy 2S 2200 mAh
  • Cyclic Servos: KingMax HV Brushless
  • Tail Servo: KingMax HV Brushless
  • Main Blades: SAB Stock 770mm
  • Lipos: Turnigy/Zippy 40/60C 12S 5000 mAh (2 x 6s)
  • Anything else: Linx Delrin main gear
Gob Kraken |Gob 700 BT 'T' | Gob 770 Comp | SoXos Strike 7 | Henseleit TDR, TDSF & TDR2 | Kasama Dune | OMP M1&M2 | UK stockist for OMPHobby M1/M2 ScotiaRC.co.uk
Old 01-03-2016, 03:20 PM   #278 (permalink)
Goblin Speed
Orange for now, soon to be black and red carbon.
Flight Style: Fast sport, big air, sloppy 3D
FBL System: Bavarian Demon 3sx
Motor: KDE 700XF-535-G3
Pinion: 23T
Target Headspeed(s): 2200
ESC: Hobbywing 160a V4
RX Pack: BEC from Hobbywing
Cyclic Servos: BK7002
Tail Servo: MKS HBL980
Main Blades: Cyclone 715
Tail Blades: Cyclone 115
Lipos: Pulse and Turnigy 5000mah 6s packs. Pulse 14s stick pack
Anything else: Optipower Ultraguard
Goblin 380|HD500
Destroyed: Urukay
|Goblin Speed
DX9|#652
earhythmic is offline        Reply With Quote Quick reply to this message
Old 01-26-2016, 03:06 PM   #279 (permalink)
Goblin 700
  • Flight Style: Sport & some 3D, rainbows, tic tocs
  • FBL System: AR7200BX
  • Motor: Scorpion HKIII 4035 500Kv
  • Pinion: not sure, bought 2nd hand with motor
  • ESC: CC Talon 120 (not using BEC, cut red wire)
  • FBL power: Hyperion LIFE 2S 6.6v
  • Cyclic Servos: Align DS615
  • Tail Servo: Align DS655
  • Main Blades: Helix by VBlades
  • Lipos: Pulse 45C 4500 x2 and EcoPower 65C 4500 X2
gmann is offline        Reply With Quote Quick reply to this message
Old 01-30-2016, 08:16 PM   #280 (permalink)
SAB 630 competition : January 30, 2016
HK III 4035-560kv w/22 tooth pinion (4225-610 SOON!)
CC ICE2 120 HV running GOV
Align BL700h HV cyclics / BL750h HV rudder
IKON FBL
2s Rx pack with redundant power leads into fbl
Glacier 4000 x 2
Rail 626mm mains
SAB 105 tail
2300 Headspeed
13 degrees of collective +/-
4:30 flight times
-Markus
*LINKS*
* G700c BRAIN2 * T-rex 500 *308DUO *450x #429
Relisys190 is offline        Reply With Quote Quick reply to this message
