Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 630/700/770
SAB Goblin 630/700/770 SAB Heli Division 630/700/770 - Goblin Helicopters Factory Support
Like Tree1Likes
Old 07-06-2016, 11:48 AM   #301 (permalink)
SAB Goblin Black Thunder Stretch
Flight Style: 3D
FBL System: Vbar Neo V/link
Motor: X-Nova 4525 560KV
Pinion: 21
Target Headspeed: 1800 - 1900 - 2100
ESC: HW130
Governor: NEO Gov
BEC: HW130 / R2 Buffer
Cyclic Servos: Xpert R1
Tail Servo: Xpert R1
Main Blades: Cyclone 695
Tail Blades: Cyclone 115
Lipos: 2 4500 65c
Raw 700 / Kraken 700 / Kraken 580 / Goblin 500 / Protos 380 Evo / OXY3 TE / Vbar Control
Citizen 266
HeliSoCal is offline        Reply With Quote Quick reply to this message
Old 09-28-2016, 10:28 PM   #302 (permalink)
SAB Goblin Black Thunder 700
Flight Style: Sport/ begginer 3d
Motor: SCORPION 4525-520
Pinion: 22
Target Headspeed: 1860-1960-2100
ESC: HW130
Governor: NEO Gov
BEC: HW130 / OPTIGUARD
Cyclic Servos: ALIGN BLS
Tail Servo: align BLS
Main Blades: Sab 690 / Rail 696 ( Will try VTX 697's)
Tail Blades: Sab 115 for now
Lipos: 2 x 5000mah Pulse
TREX 700XN 👍🏼 / TREX600n FL HEAD\ Logo 550sx 2017\XL POWER SPECTER 700\TREX 470\Vbar NEO/VBAR CONTROL👌🏼😎Citizen 789😎 DX6I RF 7.5 ( BLADE 130s oh yeah!!) ()
doubletap is offline        Reply With Quote Quick reply to this message
Old 09-29-2016, 06:56 PM   #303 (permalink)
let us know how the vtx 697 blades work out, looking to get some
for my bt thunder 700.
axia is offline        Reply With Quote Quick reply to this message
Old 10-02-2016, 06:38 PM   #304 (permalink)
Pinion: 22
ESC: HW130
Governor: NEO Gov
Align bl815 doesnt fit... its tall and its rubbing the mount... mks 665 cycic for now.
Old 10-04-2016, 05:46 PM   #305 (permalink)
bt700
yge200hv
Mks850
Mks880
Neo vlink
xnova4525-560xts
cyclone115 695
opti5000 50c
2150 opti 2s
comp7
same but with 4526-520kv f3c and vlinkrx instead of vlink
you should look into it...........
crf69 is offline        Reply With Quote Quick reply to this message
Old 10-08-2016, 01:49 AM   #306 (permalink)
Default Black Thunder 700
  • SAB Goblin Black Thunder
  • Flight Style: Sport
  • FBL System: Vbar Neo V/link
  • Motor: Xnova 50XX-530kv TAREQ special edition
  • Pinion: 23
  • Target Headspeed: 1800-2000-2250
  • ESC: Hobbywing 200Amp V4
  • Governor: Neo Gov
  • Cyclic Servos: MKS 850*8
  • Tail Servo: MKS 880*8
  • Main Blades: Stock
  • Tail Blades: Stock
  • Lipos: 2*5000 65c
Goblin 380 KSE. Goblin 570KSE. Goblin 650 Black Tunder. Goblin Black Thunder 700. Goblin 700 Comp. Goblin 700 KSE. Goblin 770 Comp. Msh Protos 700 Evo. Msh Protos 800 Evo.
Lronsen is offline        Reply With Quote Quick reply to this message
Old 10-09-2016, 03:41 AM   #307 (permalink)
Default KSE repairs to competition
Goblin 700 KSE converted into 700c carbon (2 blade)
Flight Style: 3D
FBL System: VBar Neo vlink Pro
Motor: Xnova 4530-480
Pinion: 22T
Target Headspeed(s): 1749 /1849 / 1949
ESC: Hobbywing 160HV V4
Governor: hw
BEC: Hobbywing 160HV V4 @ 7.4v
RX Pack: Optiguard Ultra guard
Cyclic Servos: Bk7002
Tail Servo: Bk 7006
Main Blades: SAB 690
Tail Blades: SAB Stock 115
Lipos: Revo 427hv 4800/5500 40c
Anything else: 23T Tail pulley
Weight 3.9kg with electronics / 5.5kg with batteries
Flight time 5:30 / 4:45 / 3.30 landed wi H 3.82-3.83v per cell
Normal flight. - 90A max draw / 130A MAX on hard 3D 1949 headspeed
keith4896 is offline        Reply With Quote Quick reply to this message
Old 10-16-2016, 02:37 PM   #308 (permalink)
Flight Style: 3D
Motor: Pyro 700-52
Pinion: 22
Target Headspeed: 1920-2020-2100
ESC: HW 130 and Optiguard
Governor: Neo Gov
Cyclic Servos: BK 7002
Tail Servo: BK 7006
Main Blades: Stock
Tail Blades: Stock
Lipos: 2*4000 50c
AUW 4,85 kg
Flight time around 3:50
|Goblins 380KSE & BT 650 And Logo 550 SX|VBC|
Ex helis:
|Mini Protos|Goblin 700|Goblin 380|T-Rex 450L Dominator|Gaui NX4|MSH Protos (carbon) R.I.P|MSH Protos (plastic)|
TimoK is offline        Reply With Quote Quick reply to this message
Old 02-25-2017, 10:25 PM   #309 (permalink)
Default Goblin 700 Setup
Originally Posted by teb1963 View Post
Hi All, I seen this in a Synergy thread done by "ElectricSheep" (thanks for the idea) and thought that it would work here as well. Quote this and fill in all that apply.
Flight Style: Always Learning... Sport, Smooth 3D, Big Air, Smack, Precision
FBL System: Vbar Neo, Pro
Motor: Xnova Xts 4530, 480Kv
Pinion: 24t
Target Headspeed(s): B1-1550, B2-1850, B3-1950
ESC: Hobbywing 130a hv v4 opto
Governor: Vbar e-gov
BEC: Hobbywing Ubec 10a cont. 20a peak
RX Pack: (none
Cyclic Servos: Bk DS-7001HV
Tail Servo: Bk DS-7006HV
Main Blades: Switch 713
Tail Blades: Switch 115
Lipos: 12s Evo Power 5000mah, 12s Pulse 5500mah
Anything else: Vcontrol, Neo, UI current sensor
V...
Blade45240 is offline        Reply With Quote Quick reply to this message
Old 07-01-2017, 05:40 PM   #310 (permalink)
HEADSPEEDS : 1600rpms-1900rpms-2000rpms
MODEL : Goblin 630comp W/Goblin 700BT tail boom
BLADES : VTX 697mm, Rail 106mm rudder blades
ESC : Castle ICE2 120HV w/fan
MOTOR : Scorpion 4225-610kv / 18tooth pulley
BATTERY : Glacier 12S 4000mah
CONTROL POWER : 2S 2200mah Rx Pack
SERVOS : 3x BK 7002 / 1x BK 8005BL
Edit : After 6 flights yesterday on a 90 degree florida day with this new setup I took some logs and temp readings. Motor temp consistently 160f, ESC temp consistent 155f-165f, Batteries 105f, Servo's 105f. 4000mah 12S came in at 3.83/cell after 4 min mixed rpm flight mostly at 1930rpms. Need to get Helicopter weight for reference.
*LINKS*
* G700c BRAIN2 * T-rex 500 *308DUO *450x #429
Relisys190 is offline        Reply With Quote Quick reply to this message
Old 07-21-2017, 01:27 PM   #311 (permalink)
Model: Goblin 700 (converted to Competition)
Flight Style: Hard 3d and precision
FBL System: Ikon 2 HD
Motor: Savox BSM 5755 Pro Spec
Target Headspeed(s): 1850, 1950, 2150
ESC: Castle 120HV (soon to be 160)
Governor: Ikon Gov.
RX Pack: Pulse 2s 2500
Cyclic Servos: Savox 2271's
Tail Servo: Savox 2272
Main Blades: Thunderbolt T 690's
Tail Blades: Thunderbolt 115's
Lipos: Glacier 12s 5300's
Ethan_Ater700 is offline        Reply With Quote Quick reply to this message
Old 08-26-2017, 11:33 PM   #312 (permalink)
Anybody running Rail 696's
Everyday I'm Hovering. .
PLANETGETLOW is offline        Reply With Quote Quick reply to this message
Old 08-27-2017, 01:27 AM   #313 (permalink)
Search the forum for "Rail 696" ?
Dawiev is offline        Reply With Quote Quick reply to this message
Old 09-09-2017, 01:51 PM   #314 (permalink)
700 KSE
Flight Style: big air/mild 3D
FBL System: iKon2
Motor: X-Nova 4530 450
Pinion: 18
Target Headspeed: 1600 - 1700 - 1800
ESC: HW160
Governor: iKon2
Tail Servo: BK 7006
Main Blades:Stock SAB
Tail Blades: Stock SAB
Lipos: Pulse 14S 5000
14S maiden was today- went perfectly!
Can now be found on the links.
Doom Buggy is offline        Reply With Quote Quick reply to this message
Old 09-14-2017, 12:34 AM   #315 (permalink)
Goblin Urukay
Flight Style: sport
FBL System: iKon2
Motor: X-Nova 4530 500
Pinion: 20
Target Headspeed: 1600,1775, 1825
ESC: HW160
Governor: HW 160
BEC: HW160
Cyclic Servos: KST X20
Tail Servo: KST X20
Main Blades:Stock SAB (replace w/ Switch 753)
Lipos: Pulse 12S 5000
Other: R2 buffer pack
TDR / Diabolo 700 / Triabolo / Diabolo SE / Diabolo 800 BEs / Diabolo UL / Logo 700
VBC, VBCT, Kontronik, MKS, Futaba, R2 buffer
Spencerkey is online now        Reply With Quote Quick reply to this message
Old 09-14-2017, 05:20 PM   #316 (permalink)
Goblin Black Thunder 700 T-Line
Flight Style: Like I stole it
FBL System: MSH Brain 2
Motor: X-Nova 4530 500kv
Pinion: 19
Headspeed: 1700,1900, 2050
ESC: Castle Creation Phoenix Edge HV 160a
Governor: MSH Brain 2
BEC: Hercules Super BEC PRO Mini
Cyclic Servos: BK BLS-8001HV
Tail Servo: BK DS-7005HV
Main Blades: Stock SAB 710mm
Lipos: Gens Ace 12s 5000mAh 60c
Chopper Crew: T-Rex 250 DFC, T-Rex 550e DFC, Goblin Black Thunder 700 T-Line
Multi Chop Crew: US75 Whoop, Martian II 250, Scratch V-Tail 355
Planks: Too Dayam Many
QueadlunnRau is offline        Reply With Quote Quick reply to this message
Old 10-17-2017, 10:28 PM   #317 (permalink)
Goblin Black Thunder Sport
Flight Style: Always Learning... Sport, Smooth, Precision
FBL System: Vbar Neo, Pro Rescue
Motor: Xnova 4530, 500KV
Pinion: 19t
Target Headspeed(s): 1600, 1800, 1900
ESC: Kontronik Kosmik 160
Governor: Kontronik mode 4
Cyclic Servos: Bk DS-7002Hv
Lipos: Optipower 5000mah 12S
Anything else: Vcontrol, Tellme Mikado, R2 Buffer pack
Diabolo 550 Vbar NEO : Diabolo 600 Vbar NEO : Diabolo 700 Vbar NEO: OXY 5 Vbar NEO : Logo 600SX V2 Vbar NEO : SAB G380 Vbar NEO : OXY3 TE : Vbar Control : Citizen 735
shadco is offline        Reply With Quote Quick reply to this message
Old 11-09-2017, 11:29 PM   #318 (permalink)
Refitted my Urukay and I’m loving it!
Goblin Urukay
Flight Style: Sport
FBL System: Neo
Pinion: 20
Target Headspeed: 1400, 1450, 1500
ESC: Kosmik 160
Governor: Kosmik
BEC: Kosmik
Cyclic Servos: Xpert R2
Tail Servo: Xpert R2t
Main Blades:750mm SAB (replace w/ Switch 753)
Other: R2 buffer pack, TelMe Mikado
Future Logo 700 (have everything except I am awaiting on a backordered 700)
Flight Style: sport
FBL System: Neo
Motor: Pyro 750L2
Pinion: 13
Target Headspeed: undecided
ESC: Kosmik 160
Governor: Kosmik
BEC: Kosmik
Main Blades: VTX 717
Tail Blades: Rail 106
Old 12-10-2017, 06:20 PM   #319 (permalink)
Black Thunder "T"
Smooth 3D
Pyro 750-500
Skookum 540
Jive 120 HV
Jive internal BEC
DS 7001, and 7005
Gens Ace 5000 45C
UAW 10 lbs 15 oz.
Black Thunder Sport
Smooth 3D
Pyro 750-500
Skookum 540
Jive 120 HV
Jive internal BEC
DS 7001 and 7005
Gens Ace 5000 45 C
UAW 11 lbs 10 oz.
SAB KRAKEN JIVE 120, BK CYCLIC, BK TAIL, PYRO 750-500, THUNDERBOLT, VBAR
GOBLIN BT SPORT HELIJIVE 120, BK CYCLIC, BK TAIL, XNOVA 4525 530, SWITCH, VBAR
GOBLIN 570 JIVE 120, MKS SERVOS, XNOVA , SWITCH MAINS, KBDD TAILS, VBAR
seefest is offline        Reply With Quote Quick reply to this message
Old 01-07-2018, 05:26 PM   #320 (permalink)
Black Thunder Sport
Sport/Big Air
Pyro 750
Kosmik 160
Neo w/ TellMe
Xpert R2 servos
Pulse 12s 5000
R2 buffer pack
Rail 716 or VTX 717
Rail 116 or 106
