Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 630/700/770
SAB Goblin 630/700/770 SAB Heli Division 630/700/770 - Goblin Helicopters Factory Support
Like Tree1Likes
Old 01-30-2013, 08:08 AM   #141 (permalink)
Default Re: What's your Goblin Setup Thread
Originally Posted by seefest View Post
For those running the internal Jive BEC and Futaba BLS251 tail servo, whats a safe BEC voltage for the LV Futaba servo? Is the default 5.6V a safe voltage? I would think so, but just curious what others have used. Thanks.
5.6 is fine. I've been running all of mine at 6 for past 2 years without an issue.
Sent from my DROID RAZR using Tapatalk 2
aviator493 is offline        Reply With Quote Quick reply to this message
Old 01-30-2013, 09:09 AM   #142 (permalink)
Thank you.
seefest is offline        Reply With Quote Quick reply to this message
Old 01-30-2013, 09:20 AM   #143 (permalink)
Thank you.
Oh, and accidentally ran one at 7.4 for a while (not really sure how long) and didn't figure it out until after I was rebuilding after a horrifically failed auto!
Old 02-05-2013, 02:12 PM   #144 (permalink)
My Goblin 770 set-up
Flight Style: (Sport / Smooth 3D )
FBL System: (Skookum or V-Bar 5.3) yet to be decided
Motor: (Pyro 700-520)
Pinion: 20t
Target Headspeed(s): 1500-1700
ESC: (HeliJive 120 HV)
Governor: ( regulated by Jive)
BEC: (None)
RX Pack: (None)
Cyclic Servos: (Hitec HS-7940TH)
Tail Servo: (ace ds0606n)
Main Blades: (original)
Tail Blades: (original)
Lipos: (Robbe Roxxy 6S-5000Mah 45c/90c)
Anything else: (4cell Nihm 120mah Graupner) back-up for Jive esc.
Kenzo is offline        Reply With Quote Quick reply to this message
Old 02-12-2013, 03:45 AM   #145 (permalink)
my goblin setup
Goblin 700
Scorpion 4525-520 Ultimate motor
Scorpion Commander V 50V 130A (opto) esc
Savox SB2271sg BL HV cyclic servos
MKS HBL 980-BLS tail servo
V-bar Silverline
SAB main blades
SAB tail blades
CC BEC pro V3 20A
trex 600efl dfc beast x, compass 7hv v-bar blueline,
sab goblin700 v-bar silverline
threedfreak is offline        Reply With Quote Quick reply to this message
Old 02-12-2013, 09:26 PM   #146 (permalink)
I'm just about ready to pull the trigger on a Goblin 700. Sadly I'm going to have to borrow the Torq servos and V-Bar from my beloved Gaui X5 to make this happen, but the X5 will be reborn down the road with a different setup.
Goblin 700 Yellow!
Flight Style: Big Air Sport, Learning 3D (Just managed my first pretty piro flips... on the sim).
FBL System: V-Bar Silverline (sorry X5)
Motor: Quantum 4530-500KV Goblin Edition unless anyone has a better suggestion.
Pinion: 22T (I believe that's stock now).
Target Headspeed(s): 1800-2100 perhaps?
ESC: HeliJive 120 HV
Governor: Jive or V-Bar
BEC: None
RX Pack: 2S... GensAce if I can
Cyclic Servos: Torq BL9180
Tail Servo: Torq BL9188
Main Blades: Stock
Tail Blades: Stock
Lipos: Unsure, would like to go with 2x GensAce 6S 5000mah but you know how that is...
Anything else: A bigger set of balls for my maiden flight
Always open to suggestions of course.
Goblin 700-Vbar Gaui X5 FES-Vbar
Trex 550E FBL-BX
FPV: TBS Discovery & Zephyr II
JR X9503 2.4Ghz Turnigy 9X with Dragonlink
Manzooka is offline        Reply With Quote Quick reply to this message
Old 02-12-2013, 09:46 PM   #147 (permalink)
Goblin 700 Yellow!
BEC: None
Main Blades: Stock
Tail Blades: Stock
Very nice! I would however, recommend a Scorpion 4525-520 Ultimate over the Quantum. With those target head speeds Id say 20 or 21t pinion.
Old 02-12-2013, 09:53 PM   #148 (permalink)
I'd recommend the RJX servos... also look into the SK540 FBL.
Be sure to follow this thread.. best build thread out there!... helped me so much... its the 770 but that doesn't matter.
https://www.helifreak.com/showthread.php?t=483451
Old 02-12-2013, 10:07 PM   #149 (permalink)
Excellent. Thanks for the suggestions, aviator. Reading up on that Scorp motor now.
Thanks Slyster, but servos and FBL are about the only items that aren't open to change on this build, but only because I'll be harvesting them from my X5 to save a heap of money in the short term. Down the road all options are open. I also have a spare BeastX on hand but I'm thinking the V-Bar wins that race.
None-the-less, I appreciate the recommendations and will look into them a little more with future changes in mind.
Trex 550E FBL-BX
Old 02-12-2013, 10:17 PM   #150 (permalink)
Default What's your Goblin Setup Thread
Regardless of which way you go, I'm sure there will be tons of sales for Presidents Day as well!
Old 02-13-2013, 12:09 AM   #151 (permalink)
Indeed, my fingers will be near a keyboard that day. Btw, any bullet points you're willing to offer on your recommendation of the scorp over the quantum?
Trex 550E FBL-BX
Old 02-13-2013, 05:26 AM   #152 (permalink)
i have tried the beast x and the v-bar silverline on the Goblin700, the v-bar is much more stable especially during strong winds. i m using scorpion 4525-520 ultimate and all i can say is awesome! just my personal opinion.
Old 02-13-2013, 06:56 AM   #153 (permalink)
Smile
Ok guys.
I might list what I have and what I will be using, when it gets here!
770 Red Goblin kit.
Just arrived, Align 800MX 520kv motor.
Kosmik 200 speedie.
RJX HV servos on cyclic and Futaba 256HV tail.
CC BEC PRO.
And.
Wait for it.
Much to everyones dismay.
I will be using an Align 3GX FBL unit.
Trex family.....100, 450L, 550E 3GX. Goblin 770.Goblin 700 speed machine. Goblin 380.
JR X9503.
PHANTMXR6 is offline        Reply With Quote Quick reply to this message
Old 02-13-2013, 08:02 AM   #154 (permalink)
Ok, so to start let me back up a little. When I first got my Goblin 700, I had the Quantum 4530 motor. It felt "ok" but I would put it more in the category of the smaller 4525 Scoprion Ultimate motor. Once I put the Sorpion 4530 motor on, I could tell instantly the power and torque was extremely noticeable even to a novice like me.
Since the Quantum 4530 was closer in power to the Scorpion 4525 Ultimate, I decided to do a little comparison with the two using my Trex 700 that housed the Scorpion 4525. To do this test, I used the same battery, ESC and pinion. SInce the 4525 is a 520KV motor and the Quantum 4530 is a 500KV motor, using the same pinion I thought would be just fine. The only real differnce was the settings used in the Scorpion SBEC ESC. The Quantum used slightly different settings that I got from other members here. SInce KV numbers can differ from motor company and ESC used, these motors were very similar in "real KV" due to the fact the the RPM was within 25 of each other.
So this is what I found comparing the Quantum 4530-500 to the Scoprion 4525-520 Ultimate
Power/Torque - Almost identical, but the Scor felt like it had the edge there.
Flight time using Spyder 5300mah packs - Scorp 4:50 / Quantum 3:55 to get to 20% left in the packs doing some FFF and "light" 3D.
Weight: Scorp = 650 grams / Quantum 556 grams (from websites, did not weight them myself)
Windings - The Scorpion using a YY wind with a single strand of copper wire. The Quantum uses a bunch of multi strand wires in a Delta wind. Some controllers such as the Kontronik Jives I believe do NOT like the Delta wind. Maybe one of the motor experts can chime in. If you look at a lot of large motors like Scorpion 45XX 42XX series as well as Kontronik Pyro 700/800, they all use single strand YY wind. I only generally see multistrand/Delta wound on the little motors like in my 450.
Anyway, hope this helps!!! If you like serious power, you can go with the Scorpion 4530-540. However, make sure you're running a 160 or > ESC and good packs! I have one in my 700 now and it's insane. I also had a custom made Scorpion 4535-450 that I'm using for my Goblin 770. There's a picture of if somewhere in the forum here. They even put my name on it!! haha
-Jason
Old 02-13-2013, 02:10 PM   #155 (permalink)
Thanks very much for the detailed response and personal account with the two motors, Jason. Between this and what I've read elsewhere I'm feeling sold on the Scorp! I think I'll pull the trigger on a kit, motor and ESC this evening. Now onto figuring out the battery situation...
Trex 550E FBL-BX
Old 02-13-2013, 05:14 PM   #156 (permalink)
The quantum has tons of power when geared properly. To say one is better that the other w/o actual statistics doesn't work well.
Helico-pteron is offline        Reply With Quote Quick reply to this message
Old 02-13-2013, 05:20 PM   #157 (permalink)
What statistics? I'm saying first hand the Scorpion 4525-520 is more powerful than the Quantum 4530-500. I don't have any numbers, but numbers mean very little anyway. Both were properly geared with a 21T pinion. I'm not saying the quantum is a bad motor, one has to be more powerful and the Scorpion just had that little extra. I'm not talking night and day here.
Old 02-13-2013, 05:25 PM   #158 (permalink)
I did also try the stock 22T pinion with both but neither motors seemed to do as well at the same RPM.
I was running 2175 RPM on both helis as well. Anything else below that would require a 20T pinion of which I never tried with either. Yes, any motor benefits from proper gearing.
Old 02-13-2013, 05:28 PM   #159 (permalink)
Don;t know about you, but am running the 21t on mine and it has plenty of power !
http://www.alignrccdn.com/
Mr.Gobler is offline        Reply With Quote Quick reply to this message
Old 02-13-2013, 05:30 PM   #160 (permalink)
Yes. 21T here as well!
