Compass 7HV setup thread. - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > Compass 7HV, 7HVU and Chronos
Compass 7HV, 7HVU and Chronos Compass Compass 7HV, 7HVU and Chronos Model Helicopter Discussion
Old 11-28-2011, 12:36 PM   #1 (permalink)
Default Compass 7HV setup thread.
is there a setup (components and weights) thread yet. lots of the forums have a sticky. i searched and can't find one that would qualify.
i'm considering the 7HV for my next e700. but, i'd like to see what guys are flying and what the AUW are like.
if you've got one, feel free to start on this thread and i'll ask the mods to sticky it once it hits critical mass.
thanks.
˙ʇı ʞɐǝɹq 'ǝʞoɹq ʇ,uıɐ ʇı ɟı
Last edited by DominicD; 11-28-2011 at 03:29 PM.. Reason: Changing name to make it more clear what the sticky is for.
cudaboy_71 is offline        Reply With Quote Quick reply to this message
Old 11-28-2011, 12:51 PM   #2 (permalink)
If you scroll down through the topics in this part of the forum, you'll find my build thread.
Here's what I'm running:
Hyperion 4035-500kV motor
Hyperion Atlas 130A Opto ESC
Skookum Robotics SK720 w/Power Bus
x2 Spektrum Satellites (hooked direclty to SK720)
MKS HBL950 (Cyclic) High Voltage Servos
MKS HBL980 (Tail) High Voltage Servo
VoltMagic EX System Monitor
(Hyperion EMeter Phase Tach Sensor for governor is on order)
.... did I miss anything??
Jeff_Barrett is offline        Reply With Quote Quick reply to this message
Old 11-28-2011, 02:20 PM   #3 (permalink)
Yes, a bad ass fusuno canopy
Oxy 3 SK540 Minijazz 20 / WARP 360 SK540 Koby 55 / Goblin 500 SK540 jive 100 / 6HV ultimate Helijive120 SK540 / 7HV SK540 Kosmik200 / Futaba18mz / Skookum support rep
heathy is offline        Reply With Quote Quick reply to this message
Old 11-28-2011, 03:00 PM   #4 (permalink)
Hm... good point. I'll have to get one of those eventually, too!
Old 11-28-2011, 03:20 PM   #5 (permalink)
can you toss it on a scale and post the AUW?
thanks. nice looking setup.
Old 11-28-2011, 03:27 PM   #6 (permalink)
I currently have two machines, don't have weights though.
7HV #1
Mini Vbar Blue Line 5.2
2 JR DSMX Sat Receivers
Pyro 700-52
13T Pinion
Jive 120HV
Std Radix 710 Main Blades
Radix 105 Tail Blades
MKS BLS950 Cyclic
MKS BLS980 tail
RC Booya Canopy Mounts
7HV #2
Mini Vbar Black 5.2
Align 510MX
13T Pinion
HeliJive 120HV
Radix 710 FBL Mains
Futaba BLS451 Cyclic
Futaba BLS251 Tail
snipealot is offline        Reply With Quote Quick reply to this message
Old 11-28-2011, 10:54 PM   #7 (permalink)
Here is going to be my setup, please keep in mind that I dont do hard 3D nor stick banging. Just a sports flying.
Mini V Pro
Futaba R6203SB S-Bus
Hyperion Phase Sensor
CC BEC Pro2 ( I know, but never have problems with this unit on my ESP )
Align 700MX 510
Align 610's
BLS 251
HW 120HV
14T pinion Governed at 1900
Gaui X3 Fubar Trex 500 Vbar
Trex 550 Vbar Compass 6HV BD3SX
Compass 7HV HC3SX Compass Chronos HC3SX
chucky21022002 is offline        Reply With Quote Quick reply to this message
Old 11-28-2011, 11:32 PM   #8 (permalink)
Align 700MX 510kv /w Revco 14t pinion
Castle Creations Ice2 120HV
BeastX
Spektrum AR7110 receiver
JR 8717HV cyclics
Align DS650 tail
Thunder Power G6 2S 1800mAh 45C for electronics
Thunder Power G6 6S 5000mAh main batteries
Governed at 1750/1850/1950
When it's released I'll use a AR7200BX with satellite to replace the receiver and BeastX. At that point I will also replace the tail servo with the MKS HBL980.
I just started on a second 7HV, which is going to be running DS610 cyclics for now, and a Scorpion 4035-500 since it's what I have on hand. When I can I'll make the machines more uniform over time. 2 7HVs in 2 weeks was already a lot. :-)
A Main Hobbies
aralan is offline        Reply With Quote Quick reply to this message
Old 11-29-2011, 01:09 AM   #9 (permalink)
As soona it's completed, I will do that for you.
Old 11-29-2011, 09:00 AM   #10 (permalink)
Kontronik Jive 80Hv
Pyro 700-45
14t Revco.
Futaba BLS252 Cyclic
BLS251 Tail
R6203SB Rx S-Bus
Mikado Mini V-Bar 5.2 Pro
Gens Ace 5300 30C
Edge 693's
105's
Head Speed 1750,1800,1850,1900
AUW w/GA 5300's...5118g
As is flies good. I have some Edge 713&115's Blems on the way to try.
GimpyGolden is online now        Reply With Quote Quick reply to this message
Old 11-29-2011, 09:46 AM   #11 (permalink)
Awesome sounding setups guys. Thanks. Keep em coming.
Old 11-29-2011, 06:22 PM   #12 (permalink)
Skookum sk720 with powerbus / 2 sat's
Hyperion phase sensor for gov
Hobbywing Hv 120 [ for now ]
Cyclics Torq BL 9180
Tail Torq BL 9188 Both @ 8.4v
Scorpion HK2 4035 560kv with extended shaft
14t stock pinion
KBDD extreme edition 104mm tail baldes
Stock compass 700 mains
Old 11-29-2011, 07:29 PM   #13 (permalink)
My initial build was just a "get 'er in the air" setup and looked lik this:
700MX 510KV
HW 120HV
Sky lipo 5000 30C
Mavrikk 690 FBs
Hyperion DS20X- SMD
Hyperion DS20X-GCD
3GX V1.2
The heli lew well his way, but never got the 3GX to my liking.
My newsetup will include:
700Mx 510KV
Ice 120HV
Sky Lipo 5000 30C
Mavrikk 690 FBs
MKS HBL950
MKS HBL980
BeastX V3.08
AR7000
Cullen Colapietro is offline        Reply With Quote Quick reply to this message
Old 12-02-2011, 03:28 AM   #14 (permalink)
Vbar 5.2 pro Mini with Skookum powerbus / 2 sat's
YGE 120HV (use the YGE Governor store mode)
Cyclics Futaba BLS 255HV @ 8.4v
Tail Futaba BLS 256HV @ 8.4v
Scorpion 4035 560kv HKIII
12t pinion
Radix 105 mm tailblades
Compass 700 mainblades
One day I got stung, and now I love rotor sounds...Team RIGIDHELI.COM
T-Rex 700N Pro, Compass 7HV ult., MSH PRTOS
EricW is offline        Reply With Quote Quick reply to this message
Old 12-15-2011, 04:53 PM   #15 (permalink)
HC3-Xtreme fbl unit
Cyclics Savox HV @ 8.4
Tail Align 620 servo @ 6.0
ZTW HV Optic 120A Esc
NEW Compass motor
13t Pinion
KBDD twee 105 tailblades
Radix SB 710s mainblades
Compassmodel / Savox / BavarianDemon / Fusuno / Rotor-tech / Revolectrix / Mks-servo / www.hobbyhangar.co.nz
Raynman is offline        Reply With Quote Quick reply to this message
Old 12-16-2011, 08:27 AM   #16 (permalink)
  • Compass 7HV Beeatch 1
  • V-Bar (Full Size) with 5.2 Pro
  • Align 700MX-510 BL Motor
  • 14t Revco Pinion
  • Kontronik 120HV
  • JR DS8717 x 3 to swash
  • JR DS8900G to tail
  • Spektrum DSM2 Satellite Rx x 2
  • Fromeco DC-UP to V-Bar (1.2f reserve capacitance)
  • Mavrikk G5 Pro WC FBL 690mm Main Blades
  • KBDD 104mm Extreme Tail Blades
  • Gens Ace 6S5300 30C x 2 Pairs Batteries
= Rb43 =
Rob43 is offline        Reply With Quote Quick reply to this message
Old 12-16-2011, 02:05 PM   #17 (permalink)
Scorpion 4035-560kV motor
Castle ICE2 HV160 ESC (when available)
Spektrum/BeastX FBL (when released)
1 Spektrum DSMX sat connected directly to the Spektrum/BeastX unit
Revco 14tooth pinion
Edge 693mm FBL blades
KBDD 105mm Extreme's
Chrome 5000mah 6s 35C Lipo's X2
Team Compass USA--Team Pilot
KBDD Team Pilot ):>
http://www.experiencerc.com : Making Helicopters Great Again!
Old 12-17-2011, 07:48 PM   #18 (permalink)
Here's my current setup:
  • Hacker Turnado A-50 12l
  • Castle Creations Ice2HV 160
  • Revco 15t pinion
  • Mikado Full-size V-Bar 5.2pro
  • 2x Spektrum DSMX satellites
  • Savox SC-1267MG HV on cyclic
  • Outrage Torq 9188 HV on tail
  • Voltz 2500mah 2s lipo unregulated
  • 690 Mavrik G5 Pro FBL WC
  • 104 EE KBDD tails
BakedMopar is offline        Reply With Quote Quick reply to this message
Old 01-02-2012, 10:01 AM   #19 (permalink)
My current setup:
- Scorpion HKIII 4035-500 PowerDekker
- Stock 13T
- YGE 120HV
- Mikado Vbar 5.2 pro
- MKS BLS 950 cyclic
- MKS BLS 990 tail
- Western Robotics super bec
- 2 x 6S Desire Power 5200 35C
- Maniac 2 703mm mainblades
- Radix 105mm tailblades
rotorWIZZ is offline        Reply With Quote Quick reply to this message
Old 01-03-2012, 12:09 PM   #20 (permalink)
Scorpion Hk 4525LE-520 - 14 T
Yge 120Hv
Mini Vbar 5.2 Pro 6203 SB Futaba
3xMKS 670
1x MKS760
WR Superbec
Edge 713
Edge 115
2x6s Nanotech 5000
pelle58 is offline        Reply With Quote Quick reply to this message
Human Verification
