Compass 7HV setup thread. - Page 13 - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > Compass 7HV, 7HVU and Chronos
Compass 7HV, 7HVU and Chronos Compass Compass 7HV, 7HVU and Chronos Model Helicopter Discussion
Old 07-23-2015, 06:48 AM   #241 (permalink)
On my 7HV and Chronos I have the low voltage cutoff on the YGEs turned on at the lowest settings (3V per cell I think). However, when I get the chance I will turn it off.
On my X3s I have the low voltage cutoff on the HW50 turned off. The advantage is I can then use both 6S for normal and 4S for lowish head speed flying. This is the reason I will be turning off low voltage cutoff on the 7HV and Chronos as I want to experiment with low head speed flying with one 6S or 7S lipo.
KBDD Team Pilot / Team Compass
Compass Chronos | 7HVU | 550U | Atom 5.5 | Gaui X3 #1 | X3 #2
cyclo is online now        Reply With Quote Quick reply to this message
Old 07-23-2015, 09:31 AM   #242 (permalink)
Okey, i've planned the maiden for tonight,
now i've " Low voltage thresshold " at middle
Should be around 3.3v i think.
Spektrum DX9 & DSMX Satellites
Logo 550
Lynx Oxy 3 ( 4s )
sven75 is offline        Reply With Quote Quick reply to this message
Old 07-31-2015, 04:40 PM   #243 (permalink)
I'm finishing my 7hv v2 Ultimate! It's my 4th big heli...the others are listed in my sig. Here is the set up:
Stock Compass motor with 14T pinion
Egde 160 HV esc
MKS 665 cyclic servos
MKS 669 tail servo
IKon fbl controller
Futaba 6303 Sbus receiver
Pulse 2s 2550mah flight system battery
Host of 6s 4000mah Turnigy and Glacier packs
Fixed end points, just have not got into governor mode yet...i fly intermediate big sky i would say, not 3D.
SAB Goblin 500, Gaui X5, SAB Goblin 630, Compass 7HV, Mikado Logo 690SX
maukaheli is offline        Reply With Quote Quick reply to this message
Old 09-09-2015, 01:04 AM   #244 (permalink)
What do you guys think of this setup?
7HVU
Stock motor (Latest version)
Hobbywing 120a platinum HV (V1)
BK-7001HV cyclic servos
BK-8005HV tail servo
Vbar clone
Hobbywing RPM sensor
2s lipo for electronics
I fly 3D and big air, like using a lot of pitch and going fast haha. I'm trying to advance further in my 3D flying, working towards smack flying which is still a long way away yet. Hoping to use around 2100 rpm and 12-13* pitch.
I've got all the components except the servos so far, so when I get my tax return that's where my money will go!
Goblin 700 Black Thunder-Xnova XTS 4525 560kv- BK7001HV/BK7006HV- Hobbywing 130a V4- Spirit Pro Citizen 828
HeliHamish is offline        Reply With Quote Quick reply to this message
Old 10-01-2015, 10:23 AM   #245 (permalink)
Looks good. Not sure about the vbar clone though. Never tried one. Use a 14t pinion to get the potential out of the stock motor. It's kv is quite low and needs the 14t for good power even down at 2100.
MSH USA TEAM PILOT
Protos max v2
RCHN #232
quinn is offline        Reply With Quote Quick reply to this message
Old 10-01-2015, 10:03 PM   #246 (permalink)
Cheers Quinn!
I'm pretty happy with the Vbar clone, as much as I would like the real deal I can't afford it at the moment, I owe my dad alot of money now haha (I've bought all the servos and electronic components!)
I'd like to run about 2200 HS, I ordered new head links on Tuesday so should have added a 14T pinion to the order then, I've got the stock 13t on it at the moment. I'll get the 14T some other time haha
So it's all pretty much setup and should be ready to fly tomorrow when the links arrive, weather doesn't look to good though so maiden might not be for a few days yet!
Old 10-04-2015, 08:14 PM   #247 (permalink)
Yeah for 2200 definitely get the 14. It will fly fine on the 13, you just won't be getting the best power.
MSH USA TEAM PILOT
Protos max v2
RCHN #232
Old 10-05-2015, 10:05 PM   #248 (permalink)
Can I use a cool kosmik in a Chronos?
Thanks.
firemedic295 is offline        Reply With Quote Quick reply to this message
Old 10-05-2015, 11:55 PM   #249 (permalink)
Thanks.
Lol, yeah I think that would work fine. I bit too much for me to spend on an esc but its about the best you can get.
If its the size your worried about, I think you can fit just about anything in there, but I'm not 100% sure.
MSH USA TEAM PILOT
Protos max v2
RCHN #232
Old 10-06-2015, 03:42 AM   #250 (permalink)
Not needed yes. I just have one sitting in a box and rather use it than buy a new esc.
Old 10-09-2015, 02:05 PM   #251 (permalink)
Just received a KDE G3 motor. you guys think I have enough to reach the counter bearing? 6 to 7mm.
Old 11-02-2015, 09:25 PM   #252 (permalink)
34mm is a perfect extension length from the bell to the opposite end of the coiunterbearing with no shaft remaining protruding from the bearing. No idea what your shaft length is. It looks short to me, but I may be mistaken. Goblin edition will be too short, the XL edition would be plenty and likely want to cut it shorter.
One other comment on the Kosmik. One of our friends here lost his Kosmik in a crash. Think about a severe nose-in crash and the potential of losing the ESC in a totaled helicopter. That's one scenario, although low in probability that is way too expensive for me. It actually swayed me away from it.
= Rb43 =
Rob43 is offline        Reply With Quote Quick reply to this message
Old 12-02-2015, 10:42 PM   #253 (permalink)
I have had the 7hv for 2 years now... Started with a budget setup and have gone through many different electronics upgrade through out this time... I finally feel comfortable posting here
What I started with...
7HV V1 airframe
Motor: Compass 7hv gen1 motor C-5828
ESC: Hobbywing 120HV
Cyclic: Align DS610
Tail: Align DS650
FBL: Robird
BEC: Direct 2s LiFe pack
RX: R6008SB S-FHSS with Futaba T8J
Lipo: Cheap chinese lipos
What I have now:
Compass 7hv ULT upgrades
Motor: Compass SZ4926 V2 with updated can
ESC: Jeti Mezon 130A with Internal BEC
Cyclic: Servoking DS-695 HV
Tail: BLS256HV
FBL: Mini V-Bar with Pro ( I Prefer iKon )
RX: Futaba 7008SB FASST mode with Futaba 14sg
Lipo: Gensace 5000mah 45C
I think the transformation is complete
The only other upgrade I want next is Chronos technical upgrade...
X7F#1-Xnova 4530-525, HW 160HV V4, MKS X8 Servos, Mini Vbar
X7F#2-HK4525-520 LE, HW 160HV V4, MKS X8 Servos, Mini Vbar
suthae is offline        Reply With Quote Quick reply to this message
Old 09-04-2016, 06:21 AM   #254 (permalink)
Default My Compass 7HV Ultimate.
Hi Guys, I picked this up a little while ago from a guy here in Adelaide.
So after a bit of a break from flying ( enjoying other hobbies etc ) it was time to get a bigger Heli, but as luck should have it, work has been awesome, So a couple of larger birds have made it my way this and a stretched synergy E5.
As I haven't had much time outside of work and trying to sleep, it has sat idle in the shed, so after some prompting from a member of an Aussie forum ( Ozzy Mozzy ) I decided to get it out and set it up.
The heli has the following components...
Kontronic Pyro 700-52
YGE 120HV
Fullsize V-bar Pro with Pro software with Spektrum sats
Align ds 615 on cyclic and a torq bl 9188 on the tail
Optipower power guard thingy
Gryphon voltage reg
Gov sensors for use with v-bar
The heli also came with a complete second airframe, 2 x new canopies plus the one on it and an additional 2 sets of main blades, as well as the main and tails fitted.
The Tx i am using is a JR Pcm9xII LE ( or also known as the JR 9303 ).
As I have flown before and have had a bit of a break form flying enjoying other hobbies, I never used bank switching and governors before, so fingers crossed.
Thanks for looking,
Cheers Dave.
dx3r, dx3r pro, baja 5sct shorty, hpi savage xs flux, hpi firestorm flux, axial scx10, beam E4 V2 x2, mcpx x3.
savage600 is offline        Reply With Quote Quick reply to this message
Old 09-04-2016, 09:05 AM   #255 (permalink)
Nice I still love that white 7hv canopy. I think its one of the best stock canopys ever made. You will love that 7hv. Its one of the best helis ive ever flown
dominator is offline        Reply With Quote Quick reply to this message
Human Verification
