Old 05-17-2007, 11:27 AM   #1 (permalink)
Team Taco VP
Default TREX 600 - build & repair vids by Mercuriell
Mercuriell has done a great job with these build vids. These are intended to be a supplement to the 600E vids I have here and Mercuriell's show you the differences e.g. Motor, clutch, etc.
TREX 600N Build videos
TREX 600N Build thread
Engine installation assembly - 34MB wmv
Clutch assembly - 35MB wmv
Clutch relining - 23MB
Clutch removal from the top - 16MB
Engine fan & ducting assembly - 40MB wmv
Engine starting - 23MB wmv
Metal blade grips & feathering sleeve - 30MB wmv
Throttle linkage and setup - 28MB wmv
Rotorworkx T600 Nitro frames overview - 12MB wmv
Rotorworkz T600 Nitro frames E -> N conversion notes - 38MB wmv
Damage control: Apply to E & N
Smackdown - what to do after you crash
Smackdown 1 - General overview - 33MB wmv
Smackdown 2 - Rotor assembly overhaul and metal grip install - 52MB wmv
Torque Tube front bevel gear replacement - 28MB wmv
Hitec 6975 servo gear change - 28MB wmv
Setup videos - applicable to 600E & 600N
Tail Setup Part 1 - Basics - 23MB wmv
Tail Setup Part 2 - Gyro setting - 32MB wmv
Engine & Motor - disassembly and repair
Bearing replacement on the Neu 1910/1Y/H - 50MB wmv
Bearing replacement on OS SX-50 Hyper - 59MB wmv
Articles on OS teardown from Audacity Models
Old 05-28-2007, 06:07 AM   #2 (permalink)
cool looking good :glasses2:
ĴŐĔ ĞŔĔČĨŃ
HIROBO SHUTTIL BLINGED UP
T-REX 450 SE
T-REX 450 SE V2
REAL FLIGHT G3
FIELD FORCE 9
s9joe is offline        Reply With Quote Quick reply to this message
Old 05-29-2007, 02:39 PM   #3 (permalink)
Great. thanks a lot.
Diamond
GOD bless us good flying
Trex 450SE V2
Futaba T9CHP
diamondtai is offline        Reply With Quote Quick reply to this message
Old 06-11-2007, 05:04 PM   #4 (permalink)
Put up a 'how-to' change a damaged front bevel gear which revealed another source of TT binding and possible tail wag Changing Torque Tube front bevel gear - 28MB wmv
John
Old 06-11-2007, 07:32 PM   #5 (permalink)
Team Taco VP
Mercuriell, WOW... I have not got a gear like that that was warped in that way. I have changed 4 myself. Yours looked warped possibly by heat or something?
Anyway nice idea for the fix BUT..... I would worry that the gear would float now and possibly move against the bevel drive gear thus leaving no backlash.
As a tip I would then use green locktite or thin CA to secure the inner race of the bearing to the plastic so the gear wont move forward. Just an idea to save premature wearing of the gears should the one gear move forward.
Bob
Old 06-23-2007, 07:51 PM   #6 (permalink)
Added in clutch relining - removal of engine block, gear pinion block, cleaning clutch housing and gluing in new lining - few tips, not a difficult job overall and a view of governor sensor damage from the fan.
John
Old 06-29-2007, 02:21 AM   #7 (permalink)
If you don't want to remove the engine block to change the clutch lining here's how (~:
John
Old 07-04-2007, 07:23 AM   #8 (permalink)
By request a how-to video on throttle linkage and setup on the Futaba 9C Super and Spectrum DX7 Throttle linkage and setup - 28MB
John
Old 09-05-2007, 04:28 AM   #9 (permalink)
Default New videos
Revised front bevel gear video posted - much easier and aesthetic way to change the gears without taking apart the bearing case.
Also Part 1 of a three part tail setup series for N & E - 401 and 611 -
Part 1: Basics
To come:
Part 2 Gyro and linkage
Part 3 Trouble shooting
John
Old 09-08-2007, 01:33 AM   #10 (permalink)
Thanks John for a very comprehensive vidoes on the 401/611 gyro, can't wait for the other two parts. No doubt gyro's are the most ask question on the forum and now we have another place to point people to.
Robert
<<< Ashlyn, daddy loves you more than his heli's, don't mind mummy >>>
<<< ..............MA Spectra G (Supporting Made in USA), DX7.............. >>>
Bobbyk is offline        Reply With Quote Quick reply to this message
Old 09-09-2007, 12:24 AM   #11 (permalink)
Started the fixit series - Part 1 general overview and post mortem - Part 2 Rotor head overhaul - Part 3 Futaba 9252 servo fix !
Smackdown Part 1 - General overview after the crash 600E - 32MB wmv
John
Old 09-09-2007, 04:14 AM   #12 (permalink)
Sorry to see your heli in its crashed state, but what an fantastic idea to provides some vides as you have started here.
These will certainly help others, thank you for showing us this.
MIke
Trex 600N Pro
Trex 600N Sport
Knight 3D
captcasper7 is offline        Reply With Quote Quick reply to this message
Old 09-12-2007, 09:06 AM   #13 (permalink)
Added in Tail Setup 2 - covering 600N and 600E with 61 and 401 gyros. Also added in rotor head rebuild in the Smackdown series featuring new damper sleeve and metal grip assembly.
John
Old 09-12-2007, 01:26 PM   #14 (permalink)
Part 1: Basics
To come:
The tail set-up was very helpful thank you.
Any chance you could shoot a vid of you hovering so I can see how the tail holds.
Mike
Trex 600N Pro
Trex 600N Sport
Knight 3D
Old 09-12-2007, 06:14 PM   #15 (permalink)
Thanks Mike - yes Part 3 will consist of video of tail probs and troubleshooting - hope to enlist Finless and Fogger's help for this
John
Old 09-19-2007, 02:55 AM   #16 (permalink)
Wow, a very helpfull video.
Thanks..
ucha is offline        Reply With Quote Quick reply to this message
Old 10-12-2007, 07:38 PM   #17 (permalink)
Will we be seeing Tailset up part 3 anytime soon?
jeffp is offline        Reply With Quote Quick reply to this message
Old 10-13-2007, 05:39 AM   #18 (permalink)
Got distracted by a Logo 600 build but yes after that
John
Old 10-13-2007, 08:42 AM   #19 (permalink)
Thats great, looking forward to it. Congrats on the vids so far, very helpful.
Old 10-13-2007, 01:48 PM   #20 (permalink)
Man I want some Duck noodles now
Ginvent is offline        Reply With Quote Quick reply to this message
