Go Back   HeliFreak > R/C Helicopter Support > Gasser Helicopters
Gasser Helicopters Gasser Specific Discussion
Old 12-07-2011, 05:32 AM   #1 (permalink)
Default My homemade onboard generator mount for Helibug Trex 700 gasser
I wanted to mount the brushless motor to the start shaft because the motor in tail TT gear shaft doesn't look safe to me.
I tried the stock clutch One way bearing (OWB). No success because an OWB needs load to lock its shaft. The brushless motor can not provide such load. Therefore OWB stops holding the shaft over 7-8 k RPM. So the motor stops rotating. Battery drains, heli crashes. I have tried a few different OWB's. One of them is a BOCA high speed OWB (19k) but it still needs load to work at 13k RPM.
I find a good balanced (some of them are not balanced) 12mm hex wrench bit and 12mm T60-61 hex shaped aluminium rod. OD of the bit is +-0.05 18mm. I machined the alu rod until i get 5mm thickness. The root remains 12mm hex. I replaced the wrench bit with the OWB in the clutch. Replaced the machined alu part with the stock clutch start shaft.
You can name this as a winter project or an experiment. Either way this setup works good for now.
Edit:I'll add more photos for the rest.
Suat
Trex 700 Gasser
FBL | HeliBug HB7-RC 17T | Silverline V-Bar| TRM VX290TT | SG | RJX Gas muffler (modded)
Trex 600 Gasser FBL | HeliXHeli conv. | OS GT15HZ | iKon | Homemade onboard generator
Azalin is offline        Reply With Quote Quick reply to this message
Old 12-07-2011, 08:22 AM   #2 (permalink)
Default Cool!
I always love to see people using the generator on their helis, makes me smile
If you have a hard time with it, I am having some CF mounts made for the trex 700 that will mount the generator right to the top of the start shaft. Hopefully they will be ready by the new year.
All the best and catch you later -- I'm in FL now and will be visiting Iskoos (Alex Oksit) who lives here but is originally from Turkey -- he was there this past summer for a couple of months, don't know if you guys know each other.
-=>Raja.
MA 1005, Hanson 280, 4254 flights, Spectra-g, Hanson 270, 3366 flights
Whiplash-g V1-2, Hanson 300, 1715 flights, Whiplash-g V2, Hanson 300, 565 flights
Jewel on-board Generators, Miniature Aircraft Team Manager
rbort is offline        Reply With Quote Quick reply to this message
Old 12-07-2011, 09:29 AM   #3 (permalink)
Thank you Raja.
Sorry, I am not familiar with Iskoo.
Suat
Trex 700 Gasser
Old 12-07-2011, 12:53 PM   #4 (permalink)
Send me one so I can test it out for you
HeliXHeli 700 | VBar Silverline | TRM275TT
TREX 550 V2 DFC | VBar Silverline | CC Ice 100 | CC BEC Pro
Rototerrier is offline        Reply With Quote Quick reply to this message
Old 12-07-2011, 03:16 PM   #5 (permalink)
Mine holds just fine. Did you press the OWB out of the shoe assy and flip it over?
ID:	271912   Click image for larger version
Just another crappy day in Paradise.... Aloha!
CNCjunkie is offline        Reply With Quote Quick reply to this message
Old 12-07-2011, 03:18 PM   #6 (permalink)
Yes, of course.
What OWB is it?
Suat
Trex 700 Gasser
Old 12-07-2011, 04:25 PM   #7 (permalink)
I'm running the Lynx Nitro Clutch and just ordered the gas version to try out. Now that my BHH 290RC has been upgraded to a 3D Max, I might need it.
Old 12-07-2011, 08:11 PM   #8 (permalink)
Default CNCjunkie
Please don't forget to put the servo screws back in!
Rototerrier, when I get some I'll let you know
-=>Raja.
Old 12-07-2011, 08:40 PM   #9 (permalink)
Default Rbort
Now you tell me!
Na, those are old photos. I go over everything with a fine tooth comb before the maiden and every time out to the field. Knock on wood, I haven't had anything fall off yet.
How's the weather in Fla?
Old 12-08-2011, 05:13 PM   #10 (permalink)
Default Fl weather
Not too bad, was hot yesterday in the 80's then a cold front came through it got real windy and dark black clouds had to pack up quick and then the rain hit and it dropped to 68F and cooled from there.
Today in the 60's but mostly sunny. Tomorrow should be warmer and less wind hopefully but hey coming from MA its WARM!!
-=>Raja.
Old 12-09-2011, 06:32 AM   #11 (permalink)
I'm in the process of converting my 700 gasser to fbl + beastx..
Also adding a generator too at the same time..
Checkout this one-piece cnc'd mount a guy on archeli made for me
It's the BeeKnees and even has raised arch sections on the side that fit perfectly into the arched slots on the helibug frame..
You have to file down the top of the frame a fraction for it to sit level - takes about 1min..
That's it - no alignment issues, no drilling any holes, etc... and has std 16mm and 19mm motor mount holes
predrilled in the top... sweeeet..
Double as a great frame brace as well..
He may be making more of them later!!!
If anyone is interested in one, I can find out how much he's going to charge and how many he can make..
ID:	272256   Click image for larger version
ID:	272257   Click image for larger version
ID:	272258   Click image for larger version
DX7 Mode-1 | 450 pro 6s | 450 pro | Schweizer 300C Gasser Scale | T-Rex550e | Aeolus 50 | HeliX T-Rex700 fbl Gasser | HWC600 Gasser | Henseleit MPXLe | Henseleit 3DNT | Suzi-Janis 700 | Gaui NX4 | Gaui X5 | Blade 350QX
jockstrap is offline        Reply With Quote Quick reply to this message
Old 12-09-2011, 07:42 AM   #12 (permalink)
Very nice jock. But be careful with that motor you are using. I have the same. The set screw on the bottom (on the up side in your picture) that holds the shaft it can be loosen easily because of vibration. Mine get lost. I'll machine a longer shaft for it.
BTW i am interested with the mount. Please keep me informed about price.
Suat
Trex 700 Gasser
Old 12-09-2011, 07:57 AM   #13 (permalink)
I had not heard of this before this thread.. very cool! at this point all my heli's are electric, but I am very curious about this! how much power does the generator put out? I understand that different motors will generate different amounts, but some examples of "x produces y" would be great!
I can see the top of my house with 1000's of little wind generators running!!! lol
badfrog is offline        Reply With Quote Quick reply to this message
Old 12-09-2011, 08:04 AM   #14 (permalink)
I get 16-18 volts DC with this motor. I use 5.8v regulated.
Try to play with the body of the motor. Be sure if it not plays up and down. If it plays that means the set screw is loosening. It's a good motor btw. Nicely balanced.
Edit: Oh, badfrog i thought you were jockstrap.
Suat
Trex 700 Gasser
Old 12-09-2011, 01:30 PM   #15 (permalink)
Very nice!
Old 12-09-2011, 09:30 PM   #16 (permalink)
Cool - thanks for that - I may remove it and reloctite it then..
I'll let you all know about the mount when I hear any news from the guy..
Good news on your success with this motor thou - it's very hard to find an appropriate KV one.. took me a while to decide on using this one..
PS: I started working on a generator for my Radikal G20 ages ago.. ended up putting it on hold trying to make a strong enough mount.. then ended up selling the radikal and getting the helibug. Been meaning to put a generator on the 700 ages ago but never got around to it due to problems making a good mount till a forum friend showed me his and I loved it so he made me one too..
@Azalyn - how have you mounted your generator ?
Old 12-10-2011, 02:53 PM   #17 (permalink)
So these are the products of your new toy at home Azalyn? Looking shiny
700 N
sundust is offline        Reply With Quote Quick reply to this message
Old 12-11-2011, 06:54 AM   #18 (permalink)
Oh Oh - be careful Azalyn - I can see a video comming with lightning and sparks comming out of your generator now...
Old 12-11-2011, 07:02 AM   #19 (permalink)
My generator works just fine. No need to panic
Suat
Trex 700 Gasser
Old 12-11-2011, 03:35 PM   #20 (permalink)
Nah - you didn't get it..
Didn't he make all the funny videos for you with fire ,etc.. so I thought now with a generator he can make some with lightning and sparks..
Sorry - was my stupid humor.. I wasn't making fun of your heli.. you're heli is sweet...
