Go Back   HeliFreak > R/C Helicopter Support > Gasser Helicopters
Gasser Helicopters Gasser Specific Discussion
Old 12-12-2011, 12:27 AM   #21 (permalink)
Originally Posted by jockstrap View Post
Nah - you didn't get it..
Didn't he make all the funny videos for you with fire ,etc.. so I thought now with a generator he can make some with lightning and sparks..
Sorry - was my stupid humor.. I wasn't making fun of your heli.. you're heli is sweet...
700 N
sundust is offline        Reply With Quote Quick reply to this message
Old 12-18-2011, 11:30 AM   #22 (permalink)
I did something better. I put the stock OWB to the clutch again. The stock start shaft has a 12.0 mm on the thick side and 5mm on the thin side. I machined a steel rod 12.12 mm on the thick side and 5mm on the thin. Now it fits super fast to the OWB. Man i love this lathe machine.
Suat
Trex 700 Gasser
FBL | HeliBug HB7-RC 17T | Silverline V-Bar| TRM VX290TT | SG | RJX Gas muffler (modded)
Trex 600 Gasser FBL | HeliXHeli conv. | OS GT15HZ | iKon | Homemade onboard generator
Azalin is offline        Reply With Quote Quick reply to this message
Old 12-18-2011, 08:09 PM   #23 (permalink)
I'm about to get my first gasser,
hope this don't sound stupid,
what if the motor stalls out during flight, where will the power come from for the electronics ?
or will it drop like a brick from the sky ?
AMAIN Heli Team
u8at711 is offline        Reply With Quote Quick reply to this message
Old 12-18-2011, 09:51 PM   #24 (permalink)
Nah - the generator is backing up and charging a battery, just like a car..
So if engine stalls you have the normal flight pack there to power everything.. it's just that on gassers you can obtain 30min flights or even longer so rather than have really large flight packs the generator keeps them topped up..
DX7 Mode-1 | 450 pro 6s | 450 pro | Schweizer 300C Gasser Scale | T-Rex550e | Aeolus 50 | HeliX T-Rex700 fbl Gasser | HWC600 Gasser | Henseleit MPXLe | Henseleit 3DNT | Suzi-Janis 700 | Gaui NX4 | Gaui X5 | Blade 350QX
jockstrap is offline        Reply With Quote Quick reply to this message
Old 12-22-2011, 09:39 AM   #25 (permalink)
I tried the generator today. Works good.
Suat
Trex 700 Gasser
Old 12-24-2011, 09:58 AM   #26 (permalink)
Where do you guys get the generators from?
coopercobra03 is offline        Reply With Quote Quick reply to this message
Old 12-27-2011, 05:25 AM   #27 (permalink)
The generator is a brushless motor. You need to build/buy a rectifier and voltage regulator.
Terry
AMA#47402, IRCHA # 3395
Pinecone is offline        Reply With Quote Quick reply to this message
Old 12-27-2011, 05:13 PM   #28 (permalink)
Default Its a wonderful thing
I just came back from an 18 day trip, 2 weeks in FL flying daily in NC the first couple of days, then daily in FL, then in VA on the last day back. Burned through 4 gallons, 58 flights between two helis, and never even brought a charger with me!! My TXs I charged with my solar panels, the helicopters charged in the air
-=>Raja.
MA 1005, Hanson 280, 4325 flights, Spectra-g, Hanson 270, 3442 flights
Whiplash-g V1-2, Hanson 300, 1965 flights, Whiplash-g V2, Hanson 300, 834 flights
Jewel on-board Generators, Miniature Aircraft Team Manager
rbort is offline        Reply With Quote Quick reply to this message
Old 12-28-2011, 01:36 AM   #29 (permalink)
-=>Raja.
Hmm. Good idea.
Suat
Trex 700 Gasser
Old 12-29-2011, 01:42 AM   #30 (permalink)
-=>Raja.
and even charge on the ground.
700 N
Old 02-22-2012, 06:43 AM   #31 (permalink)
Default Generator Mount
After seeing jockstrap's bracket mount, I decided to put in a little time and effort on making myself a new mount based on that design. I used a frame brace for the mount since I knew it was the perfect width. The height isn't optimal, but there are options. In the current configuration, it fits my coupling almost too perfectly with very little room to spare...which isn't necessarily a good thing since the coupling is design to have a little play. I would estimate maybe 1mm or a smidge more gap between the two couplings. Which is probably enough to be fine. I could have drilled and taped my holes a little lower but I felt I would have been cutting it a little too close to the edge. I might lightly sand the top of the frame hole just to allow my screws to bump up about 1 mm. It is also a perfectly flush fit across the top of the frame which ensures it is level. I drilled out a washer to be a perfect fit for the stock frame crews. Nicely self centers itself.
This whole thing was a pretty big pain in the butt because of the amount of material I had to dremel away. Took me several days of off and on work to finally get it worked out. Used a dremel with a tungsten side cutter and a bench grinder.
I "think" it will work. I'll let you all know when I get it all back together and flying.
ID:	292289   Click image for larger version
ID:	292290   Click image for larger version
ID:	292291   Click image for larger version
ID:	292292   Click image for larger version
ID:	292294   Click image for larger version
HeliXHeli 700 | VBar Silverline | TRM275TT
TREX 550 V2 DFC | VBar Silverline | CC Ice 100 | CC BEC Pro
Rototerrier is offline        Reply With Quote Quick reply to this message
Old 02-22-2012, 06:49 AM   #32 (permalink)
Nice and clean work
Suat
Trex 700 Gasser
Old 02-22-2012, 06:56 AM   #33 (permalink)
I am almost thinking about making another one just to tap my holes a little lower. Also thinking about using 4mm bolts instead. If you're like me, you may have already figured out just how easy it is to strip this soft aluminum. It might benefit from the use of a bigger bolt.
I might be able to make it quicker now that I know exactly what I need.
I had also considered using the braces in their stock form and just drilling the frame to match the existing holes, but I am really interested in finding a NON frame modifying approach. I prefer not having to modify my frames where possible. Plus this gives a little room for alignment.
Old 02-25-2012, 07:55 PM   #34 (permalink)
Hey - nice work.. yea, must have taken a while to make..
I understand about the room thing as mine is arched and still not much room..
I've had a few tanks on my 700 since converting to flybarless only so still havn't had time to connect my gen motor to the rectifier and regulator yet - soon hopefully..
I'm running 2S life so was going to use a 6V regulator but that's going to be too low now
Need something around 6.6V - I know I could possibly use a CC bec pro but any other ideas for a cheap little regulator that might be readily available ?
Old 02-26-2012, 06:27 AM   #35 (permalink)
I believe your best bet is still going to be the CC BEC Pro. The Hercules and other comparables cost twice as much. And the specs from the other post where you can build you own, calls for a Texas Instruments reg that cost 24 and then you need more parts on top of that. As far as price goes, the BEC Pro is it.
One other little nasty problem with the BEC Pro is that it also requires a programming cable. So you are really looking at $50 for the thing unless you can score one in the classifieds for cheaper.
Whats crazy is that I just bought a CC ESC and it came with a coupon for a free Link....poor timing on my part. Had just bought a link before purchasing the ESC. Didn't realize they came with coupons for a free link.
I suppose if you had any reason to buy an ESC and a BEC Pro, you could get a free link like that
Old 02-26-2012, 10:34 AM   #36 (permalink)
Default Regulators
I have fixed voltage regulators that I use with my systems:
5.4v for 4 cell NiCD or NiMH
6.9v for 5 cell NiCD or NiMH or 2 cell A123 or LiFe packs
8.4v for 2 cell Lipo or Li-ion packs
I can sell those seperately if someone wants them for $40 plus shipping.
I also have 12.6v with video filter on them for use with 3 cell Lipo or Li-ion packs for $45 plus shipping.
If you use the castle pro, just make sure you glue the wires down just in case - I do that with mine also.
Best regards,
-=>Raja.
Old 04-04-2013, 04:24 PM   #37 (permalink)
Default How to
Hi all. Been trying to research on making my own generator for my gasser. I understand the basic concept but have no idea where to start.
Is there a guide or how to on making and wiring up an onboard generator?
Any help will be much appreciated.
Thanks!
MattAUSA is offline        Reply With Quote Quick reply to this message
Old 04-05-2013, 04:15 AM   #38 (permalink)
Thanks!
https://www.helifreak.com/showthread.php?t=145109
Suat
Trex 700 Gasser
Old 04-08-2013, 06:22 PM   #39 (permalink)
Thanks!
Here is a pencil sketch of the one I made. make sure the circuit can handle 6-10 amps. Also a diode to isolate the battery from the Regulator is important. Otherwise you back-feed the regulator.
Name:	heli alternator.jpg
Trex 500, Trex 450 Pro,
thedrill is offline        Reply With Quote Quick reply to this message
Old 04-08-2013, 11:00 PM   #40 (permalink)
Thanks for the help, will give it a go when I have a weekend free!
