900E AP - HeliFreak
Old 12-22-2011, 05:09 PM   #1 (permalink)
Default 900E AP
Yep, going to give it the old school try..
Stainless steel torque tube is already fabbed up along with a carbon fiber boom.
Waiting for the new head to be delivered and test it out before ordering up the blades.
Hopefully by the New Year will test spooling it up.
Old 12-22-2011, 07:17 PM   #2 (permalink)
I think you should save your money and buy a full size heli. Thats where your headed
600 Align Futaba 14SG
And about $7000 in assorted things.
Goldenhour is offline        Reply With Quote Quick reply to this message
Old 12-22-2011, 08:45 PM   #3 (permalink)
What are you wanting to lift?
yeehaanow is offline        Reply With Quote Quick reply to this message
Old 12-22-2011, 11:58 PM   #4 (permalink)
Who knows
Payload is considerably lighter than most AP rigs, a pair of small cameras, one for video the other for stills.
Target AUW should be under 16 lbs.
The next question would be ..Why build a 900 for such a light payload.
Answer...
Why not? Need a winter project, besides how many home grown 900E's are around?
Old 12-23-2011, 01:40 PM   #5 (permalink)
Hey nightflyr,
I never learned what the sizing criteria are for helis... How do you know what size of blades/boom constitutes a 900 size heli?
Scott
s_linste is offline        Reply With Quote Quick reply to this message
Old 12-23-2011, 02:18 PM   #6 (permalink)
Boom is easy...
As long as you clear your main blades from your tail blades your good to go.
As to blades.. that is a gray area..
700 class can run 680, 690, 700, 710, 713, 720
As to 800 classI think there is a 790 blade set, 800's, 810's, 820's and I believe 830's
900 class would start @ 880's and up
Old 12-23-2011, 02:30 PM   #7 (permalink)
The "class" specifications are pretty broad and don't forget tail blade size is a factor. The "700 class" Logo is getting pretty close with 710's and 105 on the tail. The "800 class" Trex is pretty damn close with 813s and 115s. I wouldn't go bigger on either.
But AUW of 16 pounds on 900? At least you shouldn't have a problem autoing.
onlocation is offline        Reply With Quote Quick reply to this message
Old 12-23-2011, 06:19 PM   #8 (permalink)
Will post the final weight once it is all together. but I should be close to the target
Old 12-24-2011, 11:35 AM   #9 (permalink)
Head and Boom are now ready to go..
700 boom in comparison to the 900+
Old 12-24-2011, 02:24 PM   #10 (permalink)
What brand Blades did you intend on trying Nightflyr?
We've run up to 850's on our Tazer, will be interested in your thoughts on the flight characteristics with the big blades and light weight.
https://www.helifreak.com/showthread...ht=850mm+tazer
Chris D. Bergen
Bergen R/C Helicopters
cbergen is offline        Reply With Quote Quick reply to this message
Old 12-24-2011, 02:52 PM   #11 (permalink)
Hi Chris,
Going to give these a spin..
SAB 880mm Right Hand Rotation
SKU: SAB-0232-88R
BTW this is in no way any comparison to your Tazer, Hopefully I will be ordering one of those from you very soon.
Just a winter tinkering project to keep my mind busy, and I don't think it's been done before quite like this.
Old 12-25-2011, 02:09 PM   #12 (permalink)
Not at all. As I said I'm curious to see if your experience is similar to ours.
Chris D. Bergen
Old 12-25-2011, 02:27 PM   #13 (permalink)
The final pieces should be here by mid week,
With any luck we'll be spooling up on New Years Eve and I'll let you know
BTW.... Merry Christmas to you and yours
Old 12-26-2011, 05:33 AM   #14 (permalink)
Starting the construct of the 900E
And found a simple and readily available source for booms that would be required.
Even though I have a set of custom carbon fiber booms that will work on this 900 build.
For the average person stock booms are not so readily available and to have custom length booms made is very expensive.
So the simple alternative...
The the supplier for this little gem...no other than....
The only minor issue found ..the TTrubber bearing holders are slightly loose when inserted, ut this was easily remedied by wrapping a length of silicone bead material around the rubber holder to take up the play.
It's a simple and inexpensive solution to a expensive hard to find item.
Old 12-27-2011, 07:33 PM   #15 (permalink)
What is the floor mop handle made of?
Old 12-27-2011, 07:40 PM   #16 (permalink)
Light weight steel tubing..
And it fits..
Old 12-27-2011, 09:29 PM   #17 (permalink)
Very nice Night!
Rob D.
nocontrol1 is offline        Reply With Quote Quick reply to this message
Old 12-28-2011, 06:23 PM   #18 (permalink)
Default Construction is now complete
Less the new blades ( which should arrive tomorrow ) the 900E AP build is now complete.
This is one HUGE mother!!....from the batteries to the tail case just a hair over 6 feet long
ID:	276459   Click image for larger version
Old 12-29-2011, 04:42 PM   #19 (permalink)
Now fitted with the correct length blades....
Old 12-29-2011, 05:01 PM   #20 (permalink)
Seems like you'll be in search for another winter project soon.
Nice work, awaiting results. BTW, is that MOD1 gearing or 0.7?
Anto6ka is offline        Reply With Quote Quick reply to this message
Insurance
Human Verification
Copyright © VerticalScope Inc. All rights reserved.
