mSR X Blade Micro SRX Helicopters Information and Help |
#21 (permalink) |
![]() Don,
Martyn was saying to chop about 1/2 of the painted end of the blade i have one lightly used set of msr blades i will try it if my cnc grips ever come in. i was going to trim them to match the msrx blades but i think they will flex more than they did on the msr. i still have yet to pull apart a cf blade and duplicate the msrx blades.
Amat victoria curam: Victory loves careful preparation |
#22 (permalink) | |
![]() Quote:
#23 (permalink) | |
![]() Quote:
I've not tried it myself |
#24 (permalink) |
![]() Hmmm, you know I've noticed the BIG drift to left on take offs, and the unequal behavior on L vs R piros. I'm going to try this in a bit, thanks for the info!
EDIT: I was very careful to mind of the links being closed on one side as you mentioned. The elevator tab on my swash simply folded back (didn't break per say) and I wasn't pushing that hard at all. I seriously can't get over how weak / cheap this thing was, geez. ![]() I'll try gluing it, I have an indoor fly in Friday night.
Lawn darts have really changed since I was a kid, they now come with a remote. Blade mCP X - brushless / Blade 130x beta / T Rex 450 Pro FBL / HT Flip FPV / DJI F450 / Nano QX FPV beta Last edited by WNCmotard; 01-11-2012 at 09:04 PM.. |
#25 (permalink) | |
![]() Quote:
#26 (permalink) |
![]() Not much change with my helli, Need to have the elevator back on turns
#27 (permalink) |
![]() I did the adjustments my heli and when I turned left it still shot back and right
#28 (permalink) |
![]() Did this and didnt see any improvement on left rudder still goes back fast, but during flight my bird always want to go front right, I tried 1 turn at a time tried the heli stopped readjusted and still goes hard left on take off and goes back fast on left rudder. Went to 3 front 3 right trying multiple combination.
#29 (permalink) |
![]() Thank you! I made the modifications as recommended ( +3 & -1 turns) and my helicopter flies much better and much closer to level side to side. No more diving piros and hands off hover is greatly improved. My first heli, bought on boxing day, I'm flying with everything stock out of the RTF box with no other mods. Improving every day, but this mod was a quantum leap forward for me.
#30 (permalink) |
![]() I got mine dialed in as much as possible due to my not even close to stock configuration.
Id call it a 45% improvement as i still need input on the cyclic when using the rudder at slow speeds. It gets better when im at a dead stop hover, But its good enough that it doesnt wildly shoot accross the room. For me i dont think this method is the answer, I feel knowing how to add cyclic when needed and controling the heli manually will be the best answer. I say this as you dont see many CP pilots complaining about this issue as much as us folks who only flew FP heli's mainly. |
#31 (permalink) |
![]() Sounds like you need more forward tilt and less right. Even when dialed in, you still have to fly this bird. Takes quick small movements on the cyclic stick. I still need to nudge mine around a left turn with a little forward stick, but it behaves much better now.
#32 (permalink) | |
![]() Quote:
#33 (permalink) |
![]() I know that some people seem to still be complaining that there are still issues when using the recommended 3 and 1 setup. My recommendation is to keep playing with it till you get the heli to go the other way, and then back off a turn. I ended up doing +5 and -2 for mine. I am new to flying single main rotor helis, but in one night I went from chasing the thing all over the room, wondering if I would ever be able to get the hang of flying these things, to having a heli that I could hover hands off. I am still learning, but I can say that the improvement in controllability is orders of magnitude better. I am now using the longer attachments on the swash plate and full rate on the transmitter. I now have fun, and do not fly in fear of the thing.
Adam |
#34 (permalink) |
![]() I went with 3 turns out and 1 turn in and it was night and day from factory with the stock TX. Bound up my 6DXi and I had to go with 2 turns out and 1 turn in. Thought that was funny.
#35 (permalink) | |
![]() Quote:
Funny thing is, I could get my original X to hover very stable also, but I had to really correct it on takeoff. That's a procedure that even took me awhile to learn. I had the swash on it dead-on level. Doing this "mod" is just mechanically trimming it to take off and hover stably as opposed to doing the trim with the TX. I suppose once in the air, the gyro took over and compensated it to hover stable. Interesting. Side note, I did note that you CAN do a half turn of the link rod's eye, but you have to take the J-hook out and reverse it in the servo horn to make sure the eye is right-side in to the swash before you put it back on the swash ball. -Don |
#36 (permalink) |
![]() Thank you so much for this "mod", I had been struggling in quite a small room to take off and maintain a hover, now I get straight up in the air and can get down to the tricky business of balancing that marble in a turn.
#37 (permalink) |
![]() With all the weight loss mine has been through i actualy had to come out 1 1/2 turns on the front servo and 1 turn in at the left servo
#38 (permalink) |
![]() I don't know anymore, I've tried all of these adjustments. And while it does make things a little better, I'm about ready to sell this thing. I've not owned a heli yet that goes batshit insane like this when trying to add a little left rudder. I think it even goes nuts if it senses you are considering left turns. I'll give it another shot at the gym this weekend though...
#39 (permalink) | |
![]() Quote:
similis vobis fugere eam furatus "The beatings will continue until morale improves." -- William Bligh |
#40 (permalink) |
![]() Have you installed the canopy grommets behind all the links, If not you absolutely have to get the slop out of the head to tighten up control of this thing otherwise the adjustments don't cure the wild out of the box nature of this heli. MH blade grips also help....
