Go Back   HeliFreak > R/C Electronics Support > Hitec Radios > Hitec Gyro/Servos
Hitec Gyro/Servos Hitec Gyro and Servo Support
Old 05-16-2013, 09:18 PM   #1 (permalink)
Default does strength of servo increase with every decimal of voltage?
I have the 5065mgs on my trex and s9257 on tail.
the 9257 says 4.8v only why i havnt a clue, but the lowest option i have is 5v anyway on all of the escs i have.
my questions are:
. what would be the best option to get the 5065mgs running at the best i can with that setup?
. Is the 1.8kg @ 4.8v sufficient for my trex 450 pro? im not a massive fan of aerobatics but i like it on occasion, but I'm running flybarless system so faster reaction time is preferable.
. Do many people use the 5065mg for cyclic on flybarless systems, how do they hold up? if not what hitec alternatives are there?
will increasing the voltage to ..... say 5.5v give me 2.0kg or is it a non linear step in power as voltage increases?
thanks in advance guys
Chris
c_kalava is offline        Reply With Quote Quick reply to this message
Old 05-16-2013, 10:03 PM   #2 (permalink)
Default Re: does strength of servo increase with every decimal of voltage?
The 1.8kg is fine, it's more the speed and refresh rate that matters. Also it should be easy for you to look up the specs for that servo, as long ad you don't exceed the max rated voltage you'll be fine. I run MKS DS92A+ for cyclic
Joly
jolyboy is offline        Reply With Quote Quick reply to this message
Old 05-17-2013, 04:49 AM   #3 (permalink)
my questions are:
will increasing the voltage to ..... say 5.5v give me 2.0kg or is it a non linear step in power as voltage increases? thanks in advance guys Chris
HS-65MG
Operating Speed (4.8V): 0.14sec/60 at no load
Operating Speed (6.0V): 0.11sec/60 at no load
Stall Torque (4.8V): 25 oz/in. (1.8kg.cm)
Stall Torque (6.0V): 31 oz/in. (2.2kg.cm)
As with all servo, the higher the voltage, the higher the speed and current draw = faster burn out.
. Hitec 2013 Servo Chart
Futaba S9257 specs.
4.8v is the nominal voltage of a 4 cell NiMH/NiCD pack which can be 5.8v when fully charged,
dropping to and running at about 5.3v for majority of time before sudden fall to below cut off,
so a 5.0v switchmode regulator/UBEC is AOK.
Much more information available under sub sections
"Battery Care, Performance & DIY Battery Packs."
"ESC & BEC - Setup to prevent majority of all RF Problems, Brownouts & Crashes"
"Glitches & Jitter in Receiver, Servo & ESC - Causes and Cures"
"Servo - Alterations, Calculators, Databases, Leads, Repairs, Convert to an ESC or winch & FAQ."
below
"Radio Systems, Accessories, Alterations and FAQ" at
Alan's Hobby, Model & RC FAQ Web Links
Alan T.
A.T. is offline        Reply With Quote Quick reply to this message
