Old 01-25-2013, 12:09 PM   #61 (permalink)
Vlad nice work on the Knipex and yes expensive suckers.
It took me a few days to work up the nerve to grind down a perfectly functional plier
DIABOLO: PYRO 800 Kv510 YY (built by HeliFX),MKS, Vbar 5.3 + YGE160HV, JR 11X DMS || GOBLIN 570: HKIII4025 1.5mm YY Kv 620 12S(built by HeliFX),JR 8917HV, Vbar 5.3, Heli JIVE v13 || Mikado LOGO550SX v2 https://sites.google.com/site/helifxmotors/
HeliFX is offline        Reply With Quote Quick reply to this message
Old 01-25-2013, 01:36 PM   #62 (permalink)
Thanks. Well, I did not quite put it on the grinder right away myself. It was hard to commit to it but I knew it had to be done. The small Dremel grinding wheel was key to finishing it off perfectly before sanding. And its best to have the dremel in a fixed position while holding the pliers in both hands. The dremel drill press would be perfect but I have yet to purchase that accessory.
belcom is offline        Reply With Quote Quick reply to this message
Old 01-25-2013, 01:48 PM   #63 (permalink)
have a dremel myself but had access to a drill press so took very little time
money and effort well spent I'd say.
Old 01-26-2013, 05:57 PM   #64 (permalink)
I modified a pair of jewelers wire wrapping pliers to help reach down the stator a bit. Polished them to 1500 grit, and smoothed off all rough edges
one other invaluable set of tools. A gunsmith's punch set, including a G10 large diameter punch that is great for tightening up the winding groups
Todd Moriarty is offline        Reply With Quote Quick reply to this message
Old 12-21-2013, 05:10 PM   #65 (permalink)
Smile Stator
I hold the stator with a vice. Using my hand feels awkward.
Also, my favorite tools are Knipex. But I shop regularly at http://www.kctoolco.com/Knipex-Tools-s/2506.htm.
modomains is offline        Reply With Quote Quick reply to this message
Old 09-20-2014, 05:15 PM   #66 (permalink)
Well as i have no idea how to get Knipex here, This is the tool i have made. Bought the original at a jewelers tools shop and modified it. working very well i have to say (parallel close).
ID:	537230   Click image for larger version
ID:	537231   Click image for larger version
2 X X7 | Scorpion 4525 Ultimate 4+6T YY / Xnove 4530 525 | scorpion Tribunus 200II ESC | Edge 713 | Logo 690SX | Pyro 440 7+8T YY | Castle 120HV | X3 | 4S | HW 50A V2 ESC | Scorpion 2221 2050KV 9T D | SK540 / Brain2 | Mks
omerco is offline        Reply With Quote Quick reply to this message
Old 09-20-2014, 05:19 PM   #67 (permalink)
Those are perfect.
The only thing they can bend over extensive use
Old 09-20-2014, 07:01 PM   #68 (permalink)
Its steel made. i checked it doesn't deform. bends just tiny bit under pressure which is good because it kind of sits itself well on the coils/wire.
Old 10-27-2014, 10:01 AM   #69 (permalink)
Omerco, I really like yours. Looks like they were tempered ( a good thing) by the grinding as mine were see the blueish color around the tips on yours?..... I like them because they are symmetrical . Where did you get yours? I may need you to send me a pair if I cannot get them myself.
1BOHO
1BOHO is offline        Reply With Quote Quick reply to this message
Old 10-27-2014, 11:30 AM   #70 (permalink)
Jewelers tools shop. He had only this one pair...so i don't know if i can get them? I will check when having the time its not close.
Im winding my 3rd motor now and it works really well.
Old 10-27-2014, 12:21 PM   #71 (permalink)
Lately, I've been thinking about grinding the jaws on my Knipex wrench pliers narrower so they'll fit into smaller stators and tighter spots.
Jeti DS14us -- TT e700 -- 6s Logo600se UL -- Logo600-3d -- Logo500 UL -- Charge Case
prototype3a is offline        Reply With Quote Quick reply to this message
Old 10-27-2014, 01:08 PM   #72 (permalink)
I see the comments they are hard to find and expensive. I dont know where people shop but mine were easily found on ebay and werent nearly as expensive as many other quality machine shop tools. They are hardened and feature a patent design so you can expect to pay a small fee.
Omerco's look like they could be made in the machine shop. I just dont have access at this time but they look very doable from a machinist point of view.
Prototype,
I dont think you should go too far with them in that re-guard. Belcom did a good grind on his . They will work but still are stout. Youre only goint to get so far down in there anyway once the adjacent coils are wound. The propeller blades help you to flatten them down down between the arms.I try to get them as flat as possible befor the pliers touch them. The less I have to use them the better.Seem like small stators would use smaller gauges in most cases making their need less or not at all....
1BOHO
Old 11-03-2015, 03:21 AM   #73 (permalink)
A pin Spanner wrench with assorted tips prevent bent e clips from attempting to pry them off. The wrong way....
Old 12-06-2015, 09:36 PM   #74 (permalink)
Another possibility?
http://instrumentclinicusa.com/index...oducts_id=2344
p901p901 is offline        Reply With Quote Quick reply to this message
Old 12-18-2015, 03:49 PM   #75 (permalink)
Nice link those pliers there would be really nice to prepare for such a thing as we do. I think theyd work better than the knipex.
"Diese Flugzeuge werden von Clowns entworfen, die von Affen beaufsichtigt warden....."
Old 12-18-2015, 04:38 PM   #76 (permalink)
They are almost the same as mine. same manufacturer for sure:
https://www.helifreak.com/showpost.p...4&postcount=66
Old 12-18-2015, 04:40 PM   #77 (permalink)
found it...:
http://instrumentclinicusa.com/index...products_id=11
Old 12-18-2015, 06:00 PM   #78 (permalink)
I remember Omerco, but I thought you said you got yours from a local jeweler and you could not get anymore because I wanted a pair and had asked you could you get them for me.
1BOHO
Old 12-19-2015, 05:38 PM   #79 (permalink)
All you wrote is correct. It was the last one he had. But here it is you can get it now.
Old 12-21-2015, 02:12 PM   #80 (permalink)
Cheap knipex type pliers?
http://www.lowes.com/pd_749270-16878...ctId=999957733
