NEW GEARS for high power users - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 550
Hurricane 550 Discussion and support of the Gaui Hurricane 550
Old 06-11-2007, 08:45 PM   #1 (permalink)
Team Taco VP
Default NEW GEARS for high power users
OK while these have NOT been fully tested I wanted to let everyone know that once they are tested..... We will ALL have a solution for those users wanting more power for thier hurricane 550 and hopefully not worry about gear wear.
So you know I have worked with Adrian before and his stuff has always worked out and is awesome stuff.
BUT he and I will not commit until they are tested! Anyway Adrian wanted to show you whats coming for those that want to run higher power and higher head speeds.
My gears are on the way to test and I will let you all know how they perform!
Below are some pictures of the new CNC gears.
Adrian please elaborate on how they are made and the material. You da man and THANKS for doing this for use Hurricane users
Bob
Old 06-11-2007, 09:24 PM   #2 (permalink)
The gears are CNC machined from a very strong form of delrin used for prototyping of high precision parts. It is temperature and humidity stable. The gears are gauranteed to be concentric to within 1/1000th of an inch. If you have high and low spots with these gears you have a bad gear hub :wink:
I made the first reduction gear .6M so pilots can use readily available pinions for the Hirobo Lepton. The gear is 68T and this works out to in between the 42T and 61T gears currently available for the Hurricane.
The Lepton gears come in 18T to 26T sizes so Hurricane pilots will have a huge range of gear ratios for motors from ~900Kv to ~1600Kv and 4s to 6s power systems.
Like Bob said we are testing these now. If all goes well we can have gears in a couple weeks.
Stay tuned......
www.RevCo-RC.com We make stuff that works like its supposed to!
AdrianM is offline        Reply With Quote Quick reply to this message
Old 06-12-2007, 12:08 AM   #3 (permalink)
Hi, sounds nice, just one question, when using larger pinion, wont they rub against the servo? Please check this as well.
Tom Viper is offline        Reply With Quote Quick reply to this message
Old 06-12-2007, 12:59 AM   #4 (permalink)
No, There is no problem with the pinions and the servo. The 68T .6M 1st gear is smaller than the 61T .8M gear some pilots are using in this position. There is enough room to gear the heli 26/68 which is the biggest currently available .6M pinion.
Old 06-12-2007, 04:28 AM   #5 (permalink)
Good to hear you are making such good stuff. I have problem with the main shaft gear after upgrading the power system to Trex600 BL.
I will be glad if you can send me some samples to test :mrgreen:
>>Trex 600N - BLS451 ; >>Trex 600CF Flybarless
>>Trex 500 ESP ; >>Trex 450
>>Hurricane EP550 Coastguard
>>Chinook Twinrex
>>V22 Osprey Twinrex
tungym is offline        Reply With Quote Quick reply to this message
Old 06-12-2007, 07:13 PM   #6 (permalink)
Looking at my Hurricane I see a problem. The gear mesh between the auto gear and the main gear is really loose. There is no good way to fix that short of a carbon frame with the auto gear moved back a few tenths of a mm.
We will see if my gear is strong enough that this will no longer be an issue. Hopefully this will be the case and this will be a good solution for stripped main gears.
Old 06-12-2007, 07:44 PM   #7 (permalink)
Team Taco VP
Adrian, hmmmm mine doesnt have that issue??? you might try loosening the back frame screws for this bearing and slightly over thightening the front set. It might flex the frame enough to move the drive gear back towards the main gear.
Bob
Old 06-14-2007, 10:29 PM   #8 (permalink)
Team Taco VP
OK I got the gears from adrian and while sitting down to decide what pinon, I decided to do the calculations on the NEW gear ratios with this set.
So you all know how to do it
(maingear/auto gear) x (secondary/pinion) = gear ratio
So for instance the stock Gaui gears with 14T piunion are:
(61/19) x (42/14)+ = 9.63 ratio
For the other Gaui pinions the rations are:
14T = 9.63
15T = 8.98
16T = 8.42
Also thew Gaui pinions with the Gaui 61T the ratios are:
14T=13.99
15T=13.05
16T=12.24
Now Adrian's new secondary is 68T which might shock some folks but do not worry it is smaller in diameter than the 61T gear but larger than the 42T.
So here are the new ratios with the pinons from 18T to 26T
Note: 24T and 26T are not supplied by Adrian. You can use Hirobo Pinions from the lepton for 24 and 26.
18T = 12.12
19T = 11.48
20T = 10.91
21T = 10.39
22T = 9.91
23T = 9.48
24T = 9.09
26T = 8.39
FYI I was running my 1100KV motor with the 14T Gaui pinion and 42T secondary.
With Adrians gears I am going to go with the 23T which will give me 40 more ropm in the head. Probably not enough to even notice. It I still want more head speed though I will try the Hirobo 24T
Bob
Enjoy
Bob
So that is a LOT of choices there
Old 06-18-2007, 08:37 PM   #9 (permalink)
The Hurricane gears are on order. ReadyHeli.com will have them in a couple of weeks.
Perfect Circle Tranmission gears for the Huricane 550:
PC-3068 CNC .6M 68T 1st reduction gear
PC-5061 CNC .8M 61T Main Gear
Also for more ratios for the Lepton and Hurricane I am adding 3 more .6M pinions
Hard One Pinions for the Hurricane 550 (with RevCo Perfect Circle 1st gear) and Lepton EX:
HO-3024 24T .6M Hardened Steel Pinion Gear
HO-3025 25T .6M Hardened Steel Pinion Gear
HO-3026 26T .6M Hardened Steel Pinion Gear
Old 06-18-2007, 11:34 PM   #10 (permalink)
Team Taco VP
OK folks and a special thanks to AdrianM for sending me a set of gears to test but here are the results.
This video is my RAW test:
http://video.helifreak.com/?subpath=...=1revgears.wmv
The secondary gear ROCKS!
Watch this vid and I put the sucker through some decent stuff that on the stock gear would have STRIPPED THEM in LESS one flight!
Adrians secondary is a MUST have for folks wantring a good drive system or anyone powering up this system!
Now you all know me.... and I dont give you a bunch of sh*t... TELL ME IF I DO!
This is a MUST HAVE gear even stock! I dont owe Adrian anything and I honestly am telling you the straight poop... Get this gear for sure.....
Adrian is sending me a new CNC main gear too... It is needed as you will see in my vid the frames flex enough that when your driving the head and expecting the tail to be driven as well is a problem.... I bet you that Adrians main gear will solve this but until I can test I wont know.....
WHEN I DO... I will share the info!
Adrian, you da man for helpingt to make this heli better
Old 06-19-2007, 02:47 AM   #11 (permalink)
Please "hurry" up! We want thoose gears!
About the video, best one Ive seen so far on the Hurricane. Anyone know the setup?
Old 06-19-2007, 03:47 AM   #12 (permalink)
Team Taco VP
Yes... thats my heli and I have pretty much documented my setup here but I will again.
Century 600+ motor (kind of the same as the z30-1100)
Century 80 ESC
Adrians 68T secondary gear
Adrians 23T pinion
FlightPower 2500ma 6S packs
Mikado 500mm CF blades
All metal grips and head
2420 head speed
Raptor tail hub and tail grips (to solve tail locks with Gaui tail at higher than 2200 HS)
Tom... thanks that you like this vid.... I told you I would make a ROCKIN setup! Now all I need is Adrians CNC main gear
Bob
Old 06-19-2007, 03:51 AM   #13 (permalink)
Wow!!! Nice flying!!!
I NEEED NEW GEARS
and uncle Bob, any news about cf frame development???I've managed to broke mine
Piranha is offline        Reply With Quote Quick reply to this message
Old 06-19-2007, 03:56 AM   #14 (permalink)
Team Taco VP
Charlie from RotorWorkz and I will be working on something soon!
It's going to take a few months to get right so you should probably get a new frame set for now!
BUT when the CF frames come out.... It's going to ROCK
Часы для преобразования и в heli с новыми структурами
Bob
Old 06-19-2007, 04:05 AM   #15 (permalink)
Боб, я очень рад, что ты пытаешся писать по русски
And ok, I'll try to fix my broken frame,
Now I'm waiting some parts and autorotation gear (I broke 2 of them) and then I'll try trex 600L motor with Align 75ESC and 7S123 setup and Z20 1700KV with 8S 123
I have already install GY611 Gyro on my heli it is a little bit heavy but really rocks!
Old 06-19-2007, 04:15 AM   #16 (permalink)
Team Taco VP
WOW Piranha! a 611 on this heli? You are really going for it man
Yes you need gears and Revco will have them soon.
Adrian's stuff is quality and you will like them.
Если бы я имел дополнительный набор, то я послал бы их Вам СВОБОДНЫЙ!
Фактически я могу воздействовать на набор для Вас бесплатно. Позвольте мне видеть то, что я могу сделать для Вас. Вы - ранний пользователь урагана, таким образом я буду пробовать заставить readyheli.com посылать Вас свободный набор.
Bob
Old 06-19-2007, 04:36 AM   #17 (permalink)
Oh, Bob, you r DA MAN! )
I would be so much appreciated!!! I think that i need just a couple of 61T gears cause now I use only them.
Also I wold like to say that I was the FIRST HURRICANE USER IN WHOLE RUSSIA :glasses2:
I decided to go for 611 gust after some attempts to fly tail forward after piroflips! 401 sometimes decided that I'm flying wrong direction and suddenly turns the heli by 180 degrees!
Old 06-23-2007, 10:11 PM   #18 (permalink)
Bob
I had a strpped out one way with only a few flights . Seems a new front shaft that is longer and mounts into a bearing on a new motor mountis out
Gaui now offer 550 cf blades.
And a new kit with CNC head and CF blades from the get go.
I would like to get some of adrians gears also.
soundgodz is offline        Reply With Quote Quick reply to this message
Old 06-23-2007, 10:29 PM   #19 (permalink)
Soundgodz - A lot of us already have the new gear shaft and motor mount. The stock gears still do not last. The 42T front gear last ~2 flights with a strong motor.
Old 06-24-2007, 01:40 PM   #20 (permalink)
Thanks adrian I got the link and see the pinions ,but how do i get one of your main gears for the ep-550? :?:
Human Verification
