NEW GEARS for high power users - Page 2 - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 550
Hurricane 550 Discussion and support of the Gaui Hurricane 550
Old 06-24-2007, 04:19 PM   #21 (permalink)
www.ReadyHeli.com will have them next week. I will post here when they come in.
www.RevCo-RC.com We make stuff that works like its supposed to!
AdrianM is offline        Reply With Quote Quick reply to this message
Old 06-25-2007, 07:35 AM   #22 (permalink)
The front gear must use 61T and a high kv motor, to prevent gear stripping. I have been using this setup for +60flights and the front gear is still in shape. My problem is now the rear 61T gear and I am still testing the new Delrin gears this weekend.
>>Trex 600N - BLS451 ; >>Trex 600CF Flybarless
>>Trex 500 ESP ; >>Trex 450
>>Hurricane EP550 Coastguard
>>Chinook Twinrex
>>V22 Osprey Twinrex
tungym is offline        Reply With Quote Quick reply to this message
Old 06-25-2007, 11:41 AM   #23 (permalink)
Adrian or bob
My One way bearing has the gear teeth loose.
It looks like they glue the teeth to the bearing surface.
I super glued it back on and looks like it will hold for a while is the a better replacement for the one way bearing with teeth attached from another manufacturer....T.T or the like?
soundgodz is offline        Reply With Quote Quick reply to this message
Old 06-25-2007, 12:04 PM   #24 (permalink)
Team Taco VP
Make sure the gear is not cracked which made it loose. Some peopl ehave reported this. If it is OK I would use green locktite to secure it to the one way bearing. CA may not hold well.
Bob
Old 06-25-2007, 07:48 PM   #25 (permalink)
Thanks Bob
I have a couple more on the way.
I'll have to find some green ...Should not be hard in Oregon!
I got the new motor mount today and got inline for some of Adrian's gears.
I have the stock motor 'but i have been flying the 550 wood blades.
They are real smooth for a newby like me.
I have a pair of 11.1v 4400 mah batteries get 18-20 minutes hover and beginner flight. I bet the combo of big blades and heavy batteries are whats getting my gears.
What kind of pinion & gear set up would you use in this situation where head speed is not the goal but more torque to the blades and less wear on the gear train.
Have you seen the new combo kit , Has the CNC head....Some of it.
looks like they left out the stablizer and can't tell if the new motor mounts are in, carbon blades
Do you know about this new package ?
thanks again for all the good work!!
Old 06-25-2007, 08:49 PM   #26 (permalink)
Team Taco VP
Well if you not looking for head speed the stock motor is not a bad thing!
With 4400 packs you will get GOBS of fly time
BUT 550's are big and you dont say how many cells your using... Maybe the Century 550 or a motor like it might be a good way to go?
Bob
Old 06-25-2007, 08:56 PM   #27 (permalink)
6 cells and the CG was not bad . Not tail heavy this way.
I have no Idea how they would be in your hands!
My father in law was a crane pilot at Erickson.
He past way 10 yrs ago , but he would have flipped If he saw what you guys are doing with a heli.
:mrgreen:
Old 06-26-2007, 06:17 PM   #28 (permalink)
The Gears arrived today! I am shipping them to Ready Heli tomorrow and they will have them on Thursday.
Old 06-26-2007, 06:21 PM   #29 (permalink)
Woohoo! I'm just waiting for them to get their parts stock in and I'll order everything at the same time.
Joe
(1) EXI 500 GT, (5) Beam 450's, (3) Align 450's, (1)180CFX, (3) MCPX, (1) MCPX BL,(2) MCX2, (1) MSRX, (1) NCPS. All these helis and I can't fly ANY of them worth a damn!
Turbojoe is offline        Reply With Quote Quick reply to this message
Old 06-27-2007, 03:32 PM   #30 (permalink)
Paul from Gaui said that they are shooting new materials for the gears since last week. I'll let you know if these survive torture.
red_z06 is offline        Reply With Quote Quick reply to this message
Old 06-27-2007, 06:27 PM   #31 (permalink)
Team Taco VP
If thier still molded I have my doubts but we will see I guess! Glad Gauyi is working on it.
Bob
Old 06-28-2007, 02:28 AM   #32 (permalink)
I see ReadyHeli have them listed, although not in stock yet. Which gears are actually required as there are 61 & 68T 0.6 gears listed, I know stock is 61T? Is the second main gear available as well?
Steve H
Trex 600N Sport, 700N , Trex 250, Beam E4, Trex 550E, Raptor E550, Mikado Logo 500 3D, now a happy user of Futaba 10CG
stevehonn is offline        Reply With Quote Quick reply to this message
Old 06-28-2007, 05:42 AM   #33 (permalink)
The p/n PC-5068 is the 68T 1st reduction gear (the one that contacts the pinion). It is in a diffrent pitch (.6M as opposed to the Gaui .8M gear) in order to give you more pinions possibilities. This gear lets you use commonly available .6M pinions for the Hirobo Lepton (18 to 26 teeth)
The p/n PC-5061 is the 61T main gear. This gear fits on the main shaft.
Note: I Recommend using M3x6mm screws to mount RevCo gears to both gear hubs. The Stock self tapping screws do not have enough bite into the material and even with the stock gears they have a nasty habit of backing out.
Old 06-28-2007, 09:58 AM   #34 (permalink)
gears in stock.
thanks for looking.
readyheli is offline        Reply With Quote Quick reply to this message
Old 06-28-2007, 11:24 AM   #35 (permalink)
Originally Posted by readyheli
gears in stock.
thanks for looking.
I have a stock Hurricane, but would like to replace the gears even though I don't have a higher power system yet.
Your site lists the 61T and 68T - Are these direct replacement or do I need a new pinion that will mesh properly?
Thanks.
Mark
mlinder is offline        Reply With Quote Quick reply to this message
Old 06-28-2007, 11:50 AM   #36 (permalink)
You can replace all three (1st gear, main gear, hardened steel pinion) or just the main gear.
No problems there.
Old 06-28-2007, 01:43 PM   #37 (permalink)
Where are the new gears listed? I couldn't find them last night.
Joe
Old 06-28-2007, 01:53 PM   #38 (permalink)
Just found the info after going through my stack of e-mail. They're in the "upgrade" section.
Joe
Old 06-28-2007, 01:53 PM   #39 (permalink)
ok, cool. yeah in the upgrades section.
jg
Old 06-28-2007, 01:56 PM   #40 (permalink)
thats because they came in this morning...
they are listed at:
rh, upgrades, gaui.
Is there a chance they'll run out before the rest of the Hurricane parts are listed? I'd rather do just one big order but don't want to miss out on these.
Joe
Human Verification
