Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Compass 7HV, 7HVU and Chronos
Compass 7HV, 7HVU and Chronos Compass Compass 7HV, 7HVU and Chronos Model Helicopter Discussion
View Poll Results: Should I Mount My Vbar Main Sensor On Top or Bottom (Last two Photos look at)
Top of Gyro Tray 14 58.33%
Sensor on Bottom tucked away 10 41.67%
Voters: 24. You may not vote on this poll
Old 02-25-2012, 11:37 AM   #21 (permalink)
Did u have to shape that top tray by hand? It Looks cool as hell....but if u had to cut the shape your self for top tray that seems like a but or work to do...that's why I did mine the easy way simple and fast just screws right on...but I'm jealous cause yours looks soo good...good job man!!
Compass 7HV 9180/9188 Vbar
Compass 6HV 9180/9188 Skookum,4025-630KV
Compass 6HV Savox/ 9188, Vbar,
Fusion 50 9080/9088 Beast X
Velocity 50n 9080/9088 VbarSAB Goblin 9180/9188 Kontronik helijive Coming soon
AnTi Taco is offline        Reply With Quote Quick reply to this message
Old 02-25-2012, 02:42 PM   #22 (permalink)
nice, looking good anti toco
BLACKOUT MINI,ZMR 250,TBS Discovery ,Zephyr 2
TARANIS X9D + ,ez-uhf jr mod
GauiX5 Gauix3
kachur779 is offline        Reply With Quote Quick reply to this message
Old 02-25-2012, 03:51 PM   #23 (permalink)
Thank you, and Thank you for the idea.
I cut down a gyro mount to make it. After I had it cut down and the corners rounded over I used double sided tape to stick the original gyro mount and the sensor shelf together in position to drill the holes.
dankcincy is offline        Reply With Quote Quick reply to this message
Old 02-25-2012, 03:54 PM   #24 (permalink)
ohhhh now i see how u did it NICE...seems like it would be pretty easy im just to lazy to do that lol
Old 02-27-2012, 07:44 AM   #25 (permalink)
What happened to the pic from darkcincy? I wanted to look at it again.
= Rb43 =
Rob43 is offline        Reply With Quote Quick reply to this message
Old 02-27-2012, 04:04 PM   #26 (permalink)
Just had an idea, what if instead of mounting the sensor on the bottom or on the top is to put both in there, but mount the sensor upside to the 2nd deck, this way it's protected from impact... You might need to use taller then 20mm risers but it's possible.
T-rex 500, CC 75, HK-3026-1600, TracX Head & Full vBar
Logo 600 3D, CC 80HV, WR Super BEC, HK-4035-560, 10S & Full vBar
Compass 7HV, CC 120HV, WR Super BEC, HK-4035-560, 12S & Full vBar
vadimr is offline        Reply With Quote Quick reply to this message
Old 02-27-2012, 04:13 PM   #27 (permalink)
not a bad idea u would need prob the 35mm long ones would be all high and stuff but who cares since its protected underneath
Old 02-27-2012, 05:04 PM   #28 (permalink)
I wanted to order these axial standoffs, set screws and an extra gyro tray today, everything OOS on amainhobbies and this Axial stuff seems to be removed from catalog once sold.
Old 02-27-2012, 05:19 PM   #29 (permalink)
just google the part #'s to find what u want at other shops thats what i do for anything i need thats out of stock at a shop i normally buy from
http://www.amainhobbies.com/product_...mm-Post-Blue-2
Old 02-27-2012, 05:55 PM   #30 (permalink)
I found the standoffs here. They have a few different sizes of them.
Old 02-27-2012, 09:53 PM   #31 (permalink)
I do the same, except none of the other dealers also carry 7HV parts and this axial stuff
Old 03-17-2012, 11:43 AM   #32 (permalink)
Dan - how did you cut the carbon gyro tray down?
I just received my spare tray, and want to make mine similar to yours. I am planning to use carbon rods for the standoffs, as I had some left over. I made mine 25mm long. Through-bolt them to the stock tray.
= Rb43 =
Old 03-17-2012, 11:42 PM   #33 (permalink)
I used a scroll saw with a fence but you could use a dremel if need be. Just be careful while cutting.
Old 03-17-2012, 11:50 PM   #34 (permalink)
Well, I wrapped it in masking tape, marked the cut, and clamped it to the table. I chopped it off with a hacksaw. Turned out fine. I have carbon tubes cut to 25mm for standoffs. I may spring for the posts though, so I can use the flast heads on top and bottom both, however.
Thanks!
= Rb43 =
Old 09-08-2012, 05:30 PM   #35 (permalink)
I'd just like to say that all of these DIY's look pretty slick!!
rebeltrousers is offline        Reply With Quote Quick reply to this message
Old 09-08-2012, 07:26 PM   #36 (permalink)
Works well too.
= Rb43 =
Old 09-08-2012, 07:36 PM   #37 (permalink)
Yup, finally did mine. Easier for repair/maintenance too.
GimpyGolden is offline        Reply With Quote Quick reply to this message
Old 09-08-2012, 08:19 PM   #38 (permalink)
Anxious to see your version of this mod Rob. I'm sure it will be 'trick'.
https://www.helifreak.com/album.php?...ictureid=74454
Jay
jmackey is offline        Reply With Quote Quick reply to this message
Old 09-10-2012, 12:48 PM   #39 (permalink)
I don't have a recent pic, but it looks virtually identical to yours. Axial brand body posts, flat head socket cap screws (I wound up with Ti, but not intentionally). No straps. Just 3M Scotch 4010 Clear mounting tape.
I really like this product - Scotch 4010. It works well at attenuating vibrations enough to mount the gyros and holds well enough for receivers and ESC's. Even better, it comes off easily when it has to.
= Rb43 =
Old 09-10-2012, 07:08 PM   #40 (permalink)
I had the same was as dan Kennedyhad he made one for me and was using it with vbar and stuff lookz so hidden. Now running it with the brain unit. Luke took picturesof my tray at ircha and said they would look into making somethinglike it for the 7hv
Sent from my ASUS Transformer Pad TF700T using Tapatalk 2
Team Empire Hobby Team HobbyWing
Gaui X7F, Gaui X7 FZ, Gaui NX7
Bubba Gump is offline        Reply With Quote Quick reply to this message
