Thunder Tiger 30/50 Raptor 30, Raptor 50 Helicopters |
#1 (permalink) |
![]() Ok, I decided to take the plunge and see how it turns out. I purchased a TracX Flybarless head and a Spektrum AR7200BX receiver. I put the head on tonight and it looks awesome. The receiver wont be in till Monday and it will probably take me the rest of the week to figure out how to program it. Hats off to KC36330 for all the help he gave me. Here is the head and what it looks like so far.
Titan x50 FBL, R50 Titan SE FBL, R50 V2, R30 V2 , Trex500, T-Rex 450x2, mCPx X2,
#2 (permalink) |
![]() Looks good!!! The 7200BX is a breeze to setup (as are any BeastX).
Morgan Fuels / JetCat / KingTech Turbines |
#3 (permalink) |
![]() Join Date: Sep 2010
![]() Yea!! I turned on the receiver and radio to see how it was going to do and I can already tell a difference in how it is going to respond.
I guess I need to find a button for the head too.. ![]()
#4 (permalink) |
![]() You guys are a bad influence.
I am now thinking about doing this, too!
KBDD-Team Captain, Team JR DFA, Western Robotics Field Representative 6HV-U, Warp, 7HV,Knight Pro,Knight 3D, Atom, Atom Stretch, Odin II, 6HV, 3D Plus, Knight 50, Chronos, Velos, Tarot, OMP M2 (and anything else I can get my hands on...). |
#5 (permalink) |
![]() Do it, do it, do it.....
#6 (permalink) |
Member
![]() 911,
Does your swash ball need to be cleaned up? I like the red, white and blue scheme on you bird. ![]()
#7 (permalink) | |
![]() Quote:
Just put another 3 flights on my FBL Raptor today between the rain, it's one sweet flier now.
#8 (permalink) |
![]() Bob, Yup it needs a good squirt of carburetor cleaner or some other de-greaser. I think I put some white lithium grease on it a while back, but I'll clean it up. I have those Mavrrik blades on both my Raptors
KC, thanks for the balllink tip, I did like you said and it worked like a charm. I got a Align RCE-G66 governor I'm going to put on it (probably today) and a DX7s so if anyone has any tips on the channel setup I'd be most grateful. I used four bubble levels to get my blades and swash at 0 pitch all around. I don't have a swash leveler big enough to fit on the shaft. I'm going to check and see how much pitch I get today. If Fedex ran on Saturdays I would have the AR7200 today. Shipping says it is on the truck for delivery. If anyone has any more tips on any thing don't hesitate to post it.
#9 (permalink) |
![]() I noticed that on some of the FBL mods for mCCPM some people are moving the Aileron links in a hole, question is do I need to move mine in also, I know it will give more torque, less servo stress, and less response (I'm a easy flyer not 3D)
#10 (permalink) |
![]() tr911,
The position of the balls on the servo arms (for both aileron and elevator) will be determined by the FBL unit and the linkage/geometry of the helicopter and the head. Every time I have converted a machine to FBL (with the caveat that I have not yet done a Raptor), whether using V-Bar or BeastX, I have had to move the balls in on the servo arms in order to satisfy the control loop requirements for the FBL unit. I think most of us have experienced this. You should like the AR7200BX, by the way. I have been flying one for a couple of weeks now and it works beautifully.
#11 (permalink) |
![]() Clem, does that mean if it looks like it is going to bind I need to move them in a hole?
#12 (permalink) |
![]() FedEx home does run on Saturday and that's how most companies ship to residential destinations these days (it's cheaper). on the ball link location, you most likely will have to move them in closer but the BeastX will tell you during setup if your current setup will work or not when you get to the 6 degree cyclic setting. (you either get the blue light or not and that tells you if you're good or need adjusting)
my Raptor has 32 degree of collective travel with the FBL head. i don't have a swash leveler at all, i just use a pitch gauge, zero it on the gyro deck, then with the collective at 50% sit the pitch gauge on top of the blade grip (or you can attach it depending on what type you have) then spin the head, adjust till you keep zero regardless of where the head is in the 360 degree of rotation, at that point the swash is level and zero pitch is set.
#13 (permalink) | ||
Member
![]() Quote:
Generally when converting a FB heli to FBL, the servo linkages need to be moved inward on the servo arms/wheels for more servo resolution. This is what Clem referred to as satisfying the "control loop". As an example, when I converted the T-Rex 600N I had two years ago, the balls on the servo wheels needed to be move inward, from 14mm to 12mm. The same applied to the Velocity 50 I had last year. With the Titan X50 I'm building, the balls are 10mm out on the servo wheels, and they still need to be moved inward about 1mm for an optimal setup. What you should do is not change anything at all, and do a trial run of the setup of the 7200BX. When you get to setup menu point "J", your results there will tell you if you need to change things around mechanically.
#14 (permalink) |
![]() Thanks KC and Bob.... I will wait till I get the receiver.
#15 (permalink) |
![]() Wow, I just remembered something. I sent a AR7000 with remote to Horizon Hobby and they sent me a new AR7010 w/ remote back. So, guess what... I don't have to buy a remote receiver cause I can use the one I have... Wooo Hoooo!! I think I have to have an adapter cable though.. I'll have to check and see.
After looking it over I don't think I will need a adapter cable It looks like it will plug directly up to the AR7200bx
#16 (permalink) |
Member
![]() I've never seen one of these in person, but that was my understanding about the satellite receivers - that they can be plugged into the 7200BX without an adapter.
#17 (permalink) |
![]() "I've never seen one of these in person, but that was my understanding about the satellite receivers - that they can be plugged into the 7200BX without an adapter."
That is correct! The AR7200BX does not require the satellite adapter. There is a connector mounted between the servo connector that is the same as that found on any other Spektrum receiver that uses a satellite. The standard satellite cable/connector works fine.
#18 (permalink) |
![]() as mentioned the remote receiver connector is a direct fit, it's between the servo connectors and is recessed, make sure you get it fully seated, i mounted mine on the Raptor just in front of the collective arm, works great there.
#19 (permalink) |
![]() No receiver till monday...
#20 (permalink) |
![]() I'm thinking bout moving my tailservo to the back. Is any one using one of these?
It was given to me from a Buddy. I've read a little about it. I'm using a DS620 servo so I know that will work. KC, you had to move yours to get the double link on your pitch didn't you?
