Thunder Tiger 30/50 Raptor 30, Raptor 50 Helicopters |
#241 (permalink) |
![]() OK it looks like if i put the head where it needs to be, i need to cut of 9mm off of a main shaft and re-drill a hole....mm sized i guess, i don’t know if i can do it with the tools i got, but i think i will try one...ANYONE Here a machinist !!!!
if someone can do it let me know how much...well no flying her till its resolved......thanks guys ![]() |
#242 (permalink) |
![]() Join Date: Sep 2010
![]() I dont know how you would do it but you could make your four swash links longer
Titan x50 FBL, R50 Titan SE FBL, R50 V2, R30 V2 , Trex500, T-Rex 450x2, mCPx X2,
#243 (permalink) |
![]() I can't recall if it is a hardened shaft, think it is. If a hacksaw will not cut through it, you can use a grinder with a zip disk. As for the hole, a drill press will be a big bonus here. Make a small flat surface with the zip disk, grinder or file where the hole is to be drilled. Center punch the location of the hole in the flat spot and drill away, using a cutting lube would help a lot here as well.
#244 (permalink) |
![]() OK guys i cut 9mm off of a RAPTOR 30 V2 main shaft and drilled a new 3mm hole, and i got the servo 90 degree, Raptor elevator arm at basic center, i also got the swash drivers close to level.....(maybe 8.5mm cut off would have been better.) but its close.....so what’s the next step....
Should i change endpoints ATV on ailerons’ and elevators…..??????? ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#245 (permalink) |
![]() That looks much better, what kind of pitch are you getting now? Are you getting at least +10/-10 degrees? If you are then I think you are ready to setup the 3g and gitter done.
#246 (permalink) |
![]() Also, I would imagine that your 3G system has some specific starting setup information. On a BeastX product you basically set up the linkage rods and 0 pitch and the rest is done in the programming of the BeastX. Even the Radio you set up a new heli model and make sure everything is zeroed out, no sub trims, 0 on every thing.
#247 (permalink) |
![]() update......just waiting for a 3G dongle and cable, to re-default my 3g, Before i test......its still on a shelf, i bought the 3G used and i dont know what the other guy had it set to.....i could be set for a 250 trex.....i dont know???????
#248 (permalink) |
![]() Yeah, I hate waiting also, If you have the manual you can read it over about 100 times to make sure you get the idea ... lol You never said what kind of pitch you are getting.
#249 (permalink) |
![]() yeah i gotta get a dongle......so shes on a shelf for now........and the rain is killing me.....only on the weekend
#250 (permalink) |
![]() hi new raptor owner here,asking the experts,we had some new kits come to uk so i bought one.http://www.skylinemodels.co.uk/Rapto...7000-Gyro.html
now i want to go flybarles whats the best head to get will be using beast x and fuel for this type of engine,this is just going to be my training heli
500espbx 550ebx 600lenbx logo 400se v/b 7c futaba |
#251 (permalink) |
Member
![]() Just looked at this pic. The washout/radius arms are at a pretty steep angle at mid-stick. Before you fly it, make sure that the links don't pop off at full aileron or elevator deflection. Input some collective at the same time (to simulate doing a full rate stationary flip or roll) and make sure the links don't pop off.
#252 (permalink) | |
![]() Quote:
#253 (permalink) |
![]() For anyone who is interested, HobbyKing has got stock in on the RJX 50 size FBL Head. I suspect it wont last long.
http://www.hobbyking.com/hobbyking/s...dProduct=10809
#254 (permalink) |
![]() Roy, one other thing I thought of, make sure your blades are nice and tight so you don't get a boom strike.
#255 (permalink) |
![]() how tight....if they are to tight , wont they shake till they line up.......if the weather woulld let me go out and fly....ill be testing sone...........thanks for all the help
#256 (permalink) | ||
![]() my raptor 30 v2 with VWINRC FBL ,and align 3g, and main shaft mod, it seems very itchy.......not as stable as all talked about......heres a vid......Of Course..
#257 (permalink) |
![]() I'm not familiar with the 3g so I can't help any. There should be a way to soften up the dr/expo though. Looks good to me, FBL is gonna be more responsive than FB. On the Ar7200bx it has presets you can select to set the stability.
#258 (permalink) |
![]() It could be that you don't have enough servo resolution resulting in low gains!
I have the balls on the elevator and aileron servo's at 8mm from center and with the G-T5 I have my gain at 100, the TotalG my gain was exactly where it was supposed to be as was the VBar! Your ball links look to be 13.5mm from center, moving them in even one hole should increase your gain by 10% and increase stability and feel more locked in in flight! My first FBL rappie used a 3DX head which was designed to fit the TRex600 like the one your using and the swash follower arms where a real PITA, the first ones I made up where modified JR ones but they broke every time I crashed and are hard to get hold of, I also tried TRex 500 ones and they where the right length but needed some light modding and shiming. Whatever you do don't go giving big cyclic inputs as it is now because it will end in tears and that canopy looks too sweet to waste!
CustomHeliParts/KDE TRex 700N ThunderTiger X50 FBL Ely.Q Vision 90 Ely.Q Vision 50 |
#259 (permalink) | |
![]() Quote:
