Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger 30/50
Thunder Tiger 30/50 Raptor 30, Raptor 50 Helicopters
Old 02-23-2012, 12:08 AM   #61 (permalink)
Originally Posted by tr911 View Post
I also have another issue that is not in the book. The receiver just kills the throttle channel for apparently no reason and the status ligh starts blinking. Hmmm.. got to figure that one out.
That's a failsafe condition. loss of power.
also if the wobble goes away with a higher headspeed, you've likely got a set of blades out of balance.
Morgan Fuels / JetCat / KingTech Turbines
KC36330 is offline        Reply With Quote Quick reply to this message
Old 02-23-2012, 12:15 AM   #62 (permalink)
Well, failsafe condition from what, everything checks out and it happens randomly. The blades are spot on with the tracking and I thought I balanced the blades when I got them but I'll check again. Have to wait till tomorrow its bed time.
Titan x50 FBL, R50 Titan SE FBL, R50 V2, R30 V2 , Trex500, T-Rex 450x2, mCPx X2,
tr911 is offline        Reply With Quote Quick reply to this message
Old 02-23-2012, 12:18 AM   #63 (permalink)
the bilking lights indicates the receiver has cycled power (or browned out), the throttle drop is the position you bound the throttle to during bind, it holds that position till the receiver reboots.
Old 02-23-2012, 08:10 AM   #64 (permalink)
Hmmm, so the only thing I can figure that would do that is not enough juice in the battery or a short between the battery and the receiver. Looks like I might get some flight time in this weekend. I have two new planes to try and maiden also..
Thanks KC..
Old 02-23-2012, 09:24 AM   #65 (permalink)
the FBL system requires a good bit more power from the battery, it could be you have a battery with high internal resistance and under high loads the voltage is dropping low enough to brown out the receiver. switches build up corrosion and cause the same, you can bypass your switch (battery directly to receiver) and see if you still get the reset.
could be you need a new switch, battery or both.
Old 02-23-2012, 11:10 AM   #66 (permalink)
Unfortunately I can't by pass the switch cause it is built into my Ubec. It is an Align RCE-B6X and I have voltage options. I'm running a two cell 7.4v 1800mah battery right now. I may have to up it to a 2 cell with may be 2600mah
Old 02-23-2012, 05:42 PM   #67 (permalink)
I found out why my receiver was browing out. I had a bad solder joint, fix it now everything is good on the electrical end. I did a short maiden flight and I'm uploading it now. You guys take a look see and see if you can help me out. Woo Hoo palms are sweating...
Old 02-23-2012, 05:47 PM   #68 (permalink)
that's the second cold solder joint i've heard about
Old 02-23-2012, 05:58 PM   #69 (permalink)
tr911,
I am looking forward to your video!
I flew my Raptor 50 on lunch today. I took all the expo out to speed up the cyclic as much as possible.
After flying FBL machines, I am afraid I will need to follow your example and upgrade mine-I am going to need the head, a BeastX, and a new regulator, but it should be worth it.
KBDD-Team Captain, Team JR DFA, Western Robotics Field Representative
6HV-U, Warp, 7HV,Knight Pro,Knight 3D, Atom, Atom Stretch, Odin II, 6HV, 3D Plus, Knight 50, Chronos, Velos, Tarot, OMP M2 (and anything else I can get my hands on...).
Ah Clem is online now        Reply With Quote Quick reply to this message
Old 02-23-2012, 06:09 PM   #70 (permalink)
Awe come on Clem.. $140 for the head, $215 for the AR7200BX, and $30 for a Ubec, that aint but $385. My wife spends that on shoes...
Old 02-23-2012, 08:12 PM   #71 (permalink)
Ok, here it is. It's a 3 minute video and it took over 2 hours to upload.. go figure. It is not edited and it is as is. I've did a little trimming on the engine and I still need to do the pitch curves. Let me know if you see something I need to do..
Old 02-23-2012, 08:33 PM   #72 (permalink)
a quiet short hover.......... shouldn't of jumped to the left on lift off like that.
Old 02-23-2012, 08:41 PM   #73 (permalink)
I forgot to mention there was 25 mph wind.
From My Thunderbolt
Old 02-23-2012, 08:43 PM   #74 (permalink)
the muff smoke and the flag at the end of the drive shows only light winds but regardless the BeastX holds my 50 in 30+ winds, i'd double check the swash for level.
Old 02-23-2012, 09:41 PM   #75 (permalink)
I did play with the swash parameter i probably just moved it to far to the left. I also balanced the blades and one of them was a little heavy took about a inch of packing tape to even them up. It felt like 25 mph wind.. It is definitely an improvement from the flybar version. It really responds good. I really like it and I think it was a great investment for the helicopter.
Old 02-23-2012, 09:45 PM   #76 (permalink)
It made my Raptor a beautiful flier, I'm so glad I made it FBL.
Old 02-23-2012, 10:37 PM   #77 (permalink)
KC, did you turn any of the gain pots up?
Old 02-23-2012, 10:43 PM   #78 (permalink)
turned up the tail stop just a little.
Old 02-25-2012, 10:46 AM   #79 (permalink)
It's suppose to get up to 57 degrees and no wind. I might be able to get this puppy out in the air and do some tweaking. Sure hope so.
Old 02-25-2012, 11:35 AM   #80 (permalink)
Winds are 15-20 with higher gusts and it's low 40s here so only got two flights in before my fingers didn't want to feel the sticks anymore. BeastX preformed flawlessly. Even with the high wind and gusts I locked it in an inverted hover and took my hands off the sticks for a good 20 seconds before having to make a correction.
