Thunder Tiger 30/50 Raptor 30, Raptor 50 Helicopters |
#101 (permalink) |
![]() Join Date: Sep 2010
![]() I purchased a OS 50SX Hyper from a fellow here on HF. I put new bearings in it and a new ring. So, I guess I'll move into the 50 arena soon. I also got the DS610s in the mail yesterday and it looks like it is gonna rain all weekend so I'll have myself something to do.
The front bearing for the engine is sealed on both sides, the one I took out was open on the side pointing towards the engine. Should I have tried to take the inside seal out of the new bearing or leave it.
Titan x50 FBL, R50 Titan SE FBL, R50 V2, R30 V2 , Trex500, T-Rex 450x2, mCPx X2,
#102 (permalink) |
![]() most sealed bearings are already lubed and intended for the life of the bearing so don't remove it.
Morgan Fuels / JetCat / KingTech Turbines |
#103 (permalink) |
![]() Thanks KC, I still have a ways to go before I implement the 50. I got to get a muffler, the 50 upgrade kit, and a set of 600mm carbon fiber blades. I have a shop mount set up for engine so all I need to test the engine is the muffler so I can crank it up and set the mixes before I put it on the helicopter.
#104 (permalink) |
![]() Well I m not a 30.. But I am two 50's.. So I guess that makes me a 100.. Lolzz
Anywaz. I am going FBL on both those helis this coming week.. Have everything purchased just waiting now.. ![]() I am excited.. And tr kc has already given that advice, but just saying Rc bearings sealed bearings last much much longer than os ones and are well lubed. They are sealed to last longer.. ![]() I don't know if you have tried Rc-bearings website before!! More than worth it! Excited to see your raptor grow up! ![]()
Goblin Gasser TRM VX310TT Align MJ Design DTS 700N 91 HZ-R 3D Blackout Extreme Gasser #4 MCPX BL 2 iX12 Gaba |
#105 (permalink) |
![]() What FBL Head and receiver do you plan to use Gaba?
#106 (permalink) |
![]() On my vibe I am keeping it good., lol
Itll have rjx head with micro beastx . On my century .50 (kinetic) I will be converting its head to FBL , and putting it on tarot zyx. After this I will also convert the present head of the vibe to a flybarless. There is a very easy method to convert heads with bell mixers to FBL. All it costs is 30 bucks.. Lol. And it's tested.. So I am crossing my fingers! Receiver in both ar6200.. ![]()
#107 (permalink) |
![]() Cool, Gaba, I found me a MP5 practically new with gasket and bolts for $40 shipped. Should be here by weds next week. Does your helis have mCCPM or eCCPM?
#108 (permalink) |
![]() Century is mccpm and vibe is Eccpm..
#109 (permalink) |
![]() Today I put the three DS610's on and I ordered a DS650. Gonna put the 650 on the tail and the 620 on the throttle. It's yukky outside. If it clears a tiny bit I'm gonna test the 610's out.
I guess I need to go back through the setup...
#110 (permalink) |
![]() I guess since I put new bearings and a ring in the OS 50 I need to give it a run in period?
I fired it up on my bench today and it purrs like a kitty, even without a muffler. I run it idle for about 30 secs and then let it die. So far it appears that it is going to run without issues and it is not leaking any where. I'm still thinking about new gasket set though. EAR PROTECTION REQUIRED
#111 (permalink) |
![]() If its not leaking you'll be good
And yes break it in. New ring means break in .. Bearings don't need that. ![]()
#112 (permalink) |
![]() Took it out today a ran a tank through it. The tail seems to be creeping to the left. I turned the gain up to 80% and it still creeps. I may have it to high but it dont wag. Also I noticed the head is wobbling a little I've never crashed so I don't think it's the main shaft bent .. Outside of that it flies awesome ..
#113 (permalink) |
![]() turn the tail lock gain down (parameter D, take it from the default Medium, to Low)
#114 (permalink) |
![]() Thanks KC, I'll do it ASAP.
#115 (permalink) |
![]() A creepy tail it usually high frequency vibration.
Might be able to cure it using a different tape, another layer of tape, or a metal plate between two layers of tape.
KBDD-Team Captain, Team JR DFA, Western Robotics Field Representative 6HV-U, Warp, 7HV,Knight Pro,Knight 3D, Atom, Atom Stretch, Odin II, 6HV, 3D Plus, Knight 50, Chronos, Velos, Tarot, OMP M2 (and anything else I can get my hands on...). |
#116 (permalink) |
![]() Getting ready for the first flybarless test flight
#117 (permalink) |
![]() Lookin good Stretch, let me know how it does. I looked at that 3axis and decided to go ahead and plunge for the 7200. I don't regret it..
#118 (permalink) |
Member
![]() Sorry to chime in so late here. The bearing should be "shielded", not sealed. Having the inner shield removed doesn't hurt anything but isn't at all necessary.
#119 (permalink) |
![]() sealed bearings are perfectly acceptable for use for the front.
