Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mCP X Brushless Mods
mCP X Brushless Mods Blade Micro CPx Brushless Mods and Conversions
Like Tree1Likes
Old 03-04-2012, 11:05 AM   #61 (permalink)
I guess: Yes and no. It is not a matter of Firmware, but if You add a resitor at the motor port it should run with V2 boards at least.
I'm not quite sure about the effects that might occur in the governer mode, because the throttle curve will not be linear anymore. V1 Board are very unlinear, because of the much higher Frequency at the PWM output.
4712 is offline        Reply With Quote Quick reply to this message
Old 03-04-2012, 11:06 AM   #62 (permalink)
Originally Posted by Dylwad View Post
Hey Steffan,
If we were to replace the FET's on the 12A with ones specified for 1S use do you have any recommendations?
Dylan
Should be lots of options. Give me some time to do a search!
-S
sskaug is offline        Reply With Quote Quick reply to this message
Old 03-04-2012, 12:52 PM   #63 (permalink)
-S
Awesome, Thank you!
Dylan
Dylwad is offline        Reply With Quote Quick reply to this message
Old 03-04-2012, 08:50 PM   #64 (permalink)
Heres some BLheli code in action
Setup:
HP06V2 9 tooth, HP03T "old" RRC 65mm prop, Walkera 10A main and tail with 2.2 code, Hyperion 550 AUW 60.5 grams
Governed to 6300 RPM, 4:30 flights to 3.7 volts. Ambient today was 86F! main ESC was around 120F, main motor 110, battery 110, tail motor 95, tail ESC was ambient.
[ame]http://www.youtube.com/watch?v=7RtwFNFdTzw&feature=channel[/ame]
Old 03-04-2012, 08:54 PM   #65 (permalink)
TA915 9 tooth, 120SR tail motor RRC 65mm prop, dual tail FET mod. Hyperion 550, XP-12A with BLheli code, low PWM. AUW 65.4 grams
First half is governed to 6800RPM or so, second half is full throttle. 4 minutes or less to 3.7 volts ESC 130+F main motor 115 tail motor 100, battery 120.
[ame]http://www.youtube.com/watch?v=RWwylstL1f8&feature=channel[/ame]
Old 03-04-2012, 08:58 PM   #66 (permalink)
Matt Bockman prototype motor (same size as the C05M) 8 tooth, AEO tail motor (out of a geared setup) RRC 65mm prop. XP-7A/DP3A with BLheli code. Main at 100% throttle. Oversky 300Mah 35C with MCPx connector AUW 47.4 grams near 4 minute flights...
[ame]http://www.youtube.com/watch?v=fcqTLRyMB0I&feature=channel[/ame]
Old 03-04-2012, 09:00 PM   #67 (permalink)
This shows the arming sequence for the BLheli ESC's.
TX in Idle up with TH on,plug in heli, let it initialize, flick TH off and both ESC's arm, flick it on and back off and they will spool up. If you turn TH on again the tail stays armed, but the main needs you to arm it again by flicking TH on and off again.
[ame]http://www.youtube.com/watch?v=OTUNqcc52S8&feature=channel[/ame]
Old 03-04-2012, 09:01 PM   #68 (permalink)
And none of those heli's are mine
Interesting that the HP06V2 has a higher headspeed at full throttle and 0 pitch than the 915, but the 915 has gobs of torque and bogs less, but the HP06V2 really shines with the governor, RPM is pretty much constant for 4 minutes!
More to come, I need to do:
HP06V2 with BLHeli on Silabs ESC's
HP05S (so far its best at 100% throttle)
HP08 both 1S and 2S (2S brushless tail might be interesting!)
Spin 16.3K ( I think the 14K is too low KV for good governor performance)
Turnigy 1015 inrunner on the tail
HP02T
HP03T new on the lower power setups
AEO tail motor
Need more hours in a day!
Dylan
Old 03-04-2012, 09:21 PM   #69 (permalink)
http://www.youtube.com/watch?v=fcqTL...eature=channel
Wow Dylan that was some awesome flying! A man after my own heart too chasing that cat I live to torment my cat with my helis!
Nytflyer is offline        Reply With Quote Quick reply to this message
Old 03-05-2012, 12:48 AM   #70 (permalink)
Wow, you are really chasing it! And then I'm not thinking of the cat... Great videos and great work!
-S
Old 03-05-2012, 01:32 AM   #71 (permalink)
Thanks! Actually the MQx is the *perfect* tool for tormenting the neighborhood cats! still fun with the mcpx too, I just dont get as close.
Old 03-05-2012, 02:07 AM   #72 (permalink)
Will the XP-12A bec work with the new firmware?
Lynx Heli Innovations | HD Helicopters
ZyBeR is offline        Reply With Quote Quick reply to this message
Old 03-05-2012, 02:46 AM   #73 (permalink)
Nothing about the BEC gets changed with the firmware, its just a dumb chip on the board to drop voltage
Old 03-05-2012, 05:03 AM   #74 (permalink)
Nothing to add. Just tagging along.
Goatkeeper is offline        Reply With Quote Quick reply to this message
Old 03-05-2012, 07:00 AM   #75 (permalink)
Have you tested a 2s setup with the bec powering the 3in1?
What voltage is the bec set to?
Old 03-05-2012, 07:59 AM   #76 (permalink)
The BEC is 5V, but only 1.5A. Not enough juice to power the board, servos, and tail motor. It's the reason Liftbag uses the Murata DC/DC converter on his 2S with XP12A.
MSH PRTOS
Rave Ballistic 635
Spunjah413 is offline        Reply With Quote Quick reply to this message
Old 03-05-2012, 08:01 AM   #77 (permalink)
dylan,
are you using two walkera esc on the HP06V2?
Hello My Name Is Joe
Blade 130X - Lynx EOX / Blade 300x - AR7200BX, 2213-3585 / Trex 500ESP DFC - AR7200BX, 500MX / Trex 550e DFC - AR7200BX, 600MX / TSA 600e Pro - AR7200BX, 700MX / TBS Discovery FPV - APM, Sunnysky 980kv/ DX8
jabu32 is offline        Reply With Quote Quick reply to this message
Old 03-05-2012, 01:09 PM   #78 (permalink)
So do we need to edit the Hex fil for what programmed HS we want?
MSH PRTOS
Rave Ballistic 635
Old 03-05-2012, 01:11 PM   #79 (permalink)
Nope, programmable with your tx.
You set the desired rpm with the throttle stick. It's explained better in the instructions, but basically you move the throttle stick to the desired rpm for governing.
SuperBee364 is offline        Reply With Quote Quick reply to this message
Old 03-05-2012, 01:20 PM   #80 (permalink)
Ahh must have missed that. Got the code flashed a few minutes ago. Will update flying the TA915.
Thanks for all the hard work brotha!
MSH PRTOS
Rave Ballistic 635
