Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 450X
Blade 450X Blade 450X Helicopters Information and Help
Like Tree25Likes
Old 11-04-2012, 09:58 AM   #241 (permalink)
Default All the leaves are brown and the sky is gray
Flew 6 packs on the 450X today in 0C temp, -5C windchill with 18 kph wind from the North... gusting to perhaps 25 kph. What can you do when you are an addict and you need your heli fix real bad. Also flew 6 packs yesterday in windier conditions. This is the first weekend I was able to fly after 2 weeks as it was either raining or very windy thanks to hurricane Sandy.
KBDD Team Pilot
Compass Chronos | 7HVU | 550U | Atom 5.5 | Atom 500 | Gaui X3 #1 | X3 #2
cyclo is offline        Reply With Quote Quick reply to this message
Old 11-14-2012, 11:44 PM   #242 (permalink)
Got it in the mail and hovered it for a few minutes to verify it was all working! Very happy!
WH1_T-type is offline        Reply With Quote Quick reply to this message
Old 11-16-2012, 02:36 AM   #243 (permalink)
Originally Posted by Coco66 View Post
One question: anybody knows how to achieve that fast tail right-left-right-left (sort of "lightning" effect) while climbing up?
If I knew what that was... Can you find a video clip of someone doing it?
hemp is offline        Reply With Quote Quick reply to this message
Old 11-17-2012, 04:57 AM   #244 (permalink)
Flown 6 packs with my shiny new DX8: amazing! Just took a while to get to the right tail gain (but I changed it to the Gyro switch and programmed three different gains - two points difference each, so at least I avoided two thirds of the landings) which is now at 40%.
Yesterday it took two solid hours of learning and programming and binding to all the birds, but I alreday love it... depending on the weather, this afternoon or tonight I'll install the telemetry stuff.
Temperature was still good (7C) so I did not maiden my new Raydiowarm yet.
@hemp: I'll try my best to find a video... but basically, while climbing vertically "nose first" to finally get up there and stall turn, I say guys quickly moving the tail back and forth to achieve a sort of "lightning/thunderbolt" (or "spermatozoon" ) effect
Oxy 2X-VertWarp 360Blade 450XBlade 450X NightflyerGoblin 500 ♦ 2 X mCPX v2 ♦ night fly mQXLadyMQXnano QXnano QX FPVInductrixDX8 G1
Coco66 is offline        Reply With Quote Quick reply to this message
Old 11-17-2012, 08:04 AM   #245 (permalink)
7am, 35 degrees (close to 0 Celsius), cloudless sky, no wind, blade 450x sporting new savox servos, hot cup of coffee, big empty field next to the middle school....
A very good morning for flying! 1 pack with the 450x, 3 packs with the mcpx, and no crashes. I have set a record for myself.
steveap1 is offline        Reply With Quote Quick reply to this message
Old 11-17-2012, 08:17 AM   #246 (permalink)
I looked at mine, and the stack of parts to fix it. Still haven't had time to fix it :/
Align 450 PRO DFC 4S KDE 450XF // Blade 450X 450MX, 3GX, Savox // Align 450 Sport V2 Airwolf
Align 600EFL PRO, DFC, 3GX, KDE
Align CHP DL 800, XERA 4530LE, ICE160HV, AR7200BX, SB-2271MG, SB-2272SG, KDE, Lynx, 115s
Thunder Power 65C LiPo & JR 12X
350Z_Al is offline        Reply With Quote Quick reply to this message
Old 11-17-2012, 09:17 AM   #247 (permalink)
Since it was so nice in the morning, went flying again in the early afternoon. Again 6 packs (I have 8 but I feel 6 is my "full focusing limit").
All nice, including first time 920 degrees stall turns and... first loops ever!!
I had never really tried on the mCPX nor the Nano, and just watched couple of Sim videos before leaving for the field... and all went well! Something really clicked lately in my relationship with the 450 X.
Is it possible to do a full aileron roll while flying FF? How is that called?
Old 11-17-2012, 09:25 AM   #248 (permalink)
It is. You coordinate collective with the aileron. By varying the speed of both you can either do a very tight roll by using a lot of aileron and making quick corrections with collective to keep it in a straight path. If you want to open it up and make it more like a barrel roll, slow down the aileron and give more collective to make is kind of like a sideways loop. I'm not sure the my description makes sense.
Team Synergy Field Rep, Rail Blades
Rodney Kirstine is offline        Reply With Quote Quick reply to this message
Old 11-17-2012, 09:28 AM   #249 (permalink)
Congrats to Coco66!!
Yep, rolls are using the same collective stick movements as flips.. Just transition to negative pitch as the heli goes inverted, and back to positive pitch when it continues around upright again.
Current fleet is getting smaller.
Blackout Mini-H, WarpQuad 230, Blade 200qx, Nano QX, UM F-27q Stryker, UM P51 Mustang, F4F Wildcat, DX6 radio.
Previous fleet: mcpx, 300x, 350qx,450x, qav400, DX7s
InFocus is offline        Reply With Quote Quick reply to this message
Old 11-17-2012, 09:40 AM   #250 (permalink)
Thanks guys.
So I assume I have to be in IU, get a good initial speed since I will be going through 0 or even slightly negative pitch during the roll and... voila'? Not so different from an "on the spot" roll, then. Just a bit more dangerous if you make it too wide, prolly...
I'll try tomorrow, if weather keeps like that...
Thanks!
(Does it have a name? Is it not sort of planker's Tonneau?)
Old 11-17-2012, 09:52 AM   #251 (permalink)
Thanks guys.
Thanks!
You definitely need to be in idle up! Don't ask my how I know..
Ok, I'll tell you lol... We were filming in an indoor warehouse for a tv show, and I was nervous because of the canera and forgot to switch to Idle up. Sure enough I flipped it into an inverted hover, and instead of hovering I did a slow inverted auto and landed it upside down on the concrete. There was so little head speed by the time it landed that it actually did no damage!
Old 11-17-2012, 10:13 AM   #252 (permalink)
Happened to me this morning... luckily it was with the mcpx and not the 450X. I went inverted and as I added negative pitch the mcpx sank until it hit the grass. This also happens from time to time on the sim (forgetting to set TX to IU). I am now thinking of completely removing normal and just using idle up all the way.
KBDD Team Pilot
Old 11-17-2012, 02:00 PM   #253 (permalink)
I believe we call it an Aileron roll. It's not really a fancy maneuver, so it doesn't need a fancy name.
Old 11-17-2012, 02:03 PM   #254 (permalink)
I take off and land (and fly) in IU. However, I still keep normal mode available as an option in case I need to reduce headspeed for some reason (I've used it when hard vibes developed in-flight.)
Old 11-18-2012, 06:45 PM   #255 (permalink)
There have been 2 occasions where I forgot to go to IU. The good news is, I didn't crash. There is enough momentum in the blades that the heli will continue to function, and you can get it flipped back over. Once I was only about 15 feet up, and it almost touched the ground before it was upright enough to punch out..
The same move on the mCPX is an instant fall from the sky because the blades stop so quick when power is removed.
Old 11-18-2012, 09:35 PM   #256 (permalink)
I was flying indoors in a warehouse, the initial flip was maybe 6 feet from the ground, by the time I realized what happened I was maybe a foot from the ground.
Anyways, today I stripped the heli down and started rebuilding. Had everything I needed to fix it except for the blade grip bearings and a main shaft bearing that was a bit notchy.
Old 11-22-2012, 08:04 AM   #257 (permalink)
Could not resist thinking that all "you" guys in the US can fly today... so I took a longer lunch break and flew 4 packs...
Old 11-22-2012, 10:31 AM   #258 (permalink)
Sweet! We've had really crappy weather here all week. It's been raining and windy. Right now, it's clear and calm outside and I'm really hoping it stays that way throughout the day!
Old 11-22-2012, 02:46 PM   #259 (permalink)
Time to practice those inverted landings!
Old 11-22-2012, 09:49 PM   #260 (permalink)
It was a perfect inverted landing!
Flipped the heli over onto the skids, took off in IU and kept flying!
