Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 450X
Blade 450X Blade 450X Helicopters Information and Help
Like Tree26Likes
Old 06-07-2018, 02:28 AM   #4741 (permalink)
Originally Posted by Rogue22 View Post
Nice looking heli. The red canopy really stands out. I have CC Phoenix 60s on my 450s. Possibly overkill but certainly no power issues yet. I am sure you are happy with the new ESC.
Sent from my iPhone using Tapatalk Pro
Amazing what a little time...patience and a Sharpie marker can do...this one used to be the stock yellow
I've also been working to add an XT60 "kill switch" to most of My models so I can connect battery - install canopy - carry to the flight line...and then plug in the XT60 "kill switch" to initialize then fly
Name:	XT6- KillSw 001.jpg
ID:	747648   Click image for larger version
Name:	XT6- KillSw 002.jpg
nCPX(3)*mCPX(25)*130X(10)*130X-L(6)*180CFX(3)*300X/CFX(3)
450X(7)*470LP*GauiX3*nanoQX*180QX*DX9*HF180060*AMA 988253
Old 06-08-2018, 11:44 PM   #4742 (permalink)
Heading to another event in several hours...
The "Big Thaw" they call it...sponsored by the Bismarck Aero Modelers
Taking several 450X's and My Trex 470LP
Old 06-09-2018, 10:56 PM   #4743 (permalink)
You are amazing. All the tips and solutions you post to help others is amazing.
This a great solution to what has been bugging me.
AMA 70865
mikem65d is offline        Reply With Quote Quick reply to this message
Old 06-10-2018, 12:40 AM   #4744 (permalink)
The Sharpie idea is one I've used for years...
The XT60 "kill switch" I discovered when I asked another pilot why he preferred the iKON2 HD over the regular iKON2 and his answer was the primary lead "kill switch" provided with the iKON2 HD...
I then saw another pilot who solved the problem using an XT60 as I've described...
$100 cheaper and probably lighter too
Old 06-10-2018, 01:34 AM   #4745 (permalink)
The "Big Thaw" was a smashing success with 37 registered pilots...largest ever for BAM
The club puts on a great event...and Steak/Baked Potato made on site with all the fixins
Speaking of smashed...My 330X caught the ground tail first...not good
Old 06-19-2018, 10:55 AM   #4746 (permalink)
Well Jon... On the 330X, why did you let the heli do that??
Yes, we have all been there! I am really trying to up my flights per week. I made one silly mistake a few weeks ago. As my first test of "auto" ability, I got my 4S 450X up high, flipped the switch, and instead of setting up for an auto with 25% throttle programmed, I went to TH... When my brain figured it out, almost immediately, the Slow Spool up bit me! For now, it looks like only a broken landing gear, but being short on time, have been flying my 6S 450X instead. What a huge difference in power!
Ok, JonJet, a question about your XT-60 "Kill Switch". Does the XT-60 connection complete the battery connection feeding the ESC? I also have a few Brain2 HDs and like the remote switch, that plugs into the FBL. It is a very small gauge cable, so weighs almost nothing. With your solution, I might need to significantly extend my battery/ESC lead which may add several ounces of weight in copper wire. Am I thinking correctly on this? I like the idea though, because it appears to be very simple. Also, never a bad thing when you save $100!
Thank you for any comments.
Steve
SAB Goblin 570s Sport and Freedom Edition, 700s Sport and Freedom Edition, Krakens, Fireball, and Whiplash-G2 gasser; JETI DS-24 TX
Rogue22 is offline        Reply With Quote Quick reply to this message
Old 06-19-2018, 11:08 AM   #4747 (permalink)
Well Jon...… On the 330X, why did you let the heli do that??
Steve
It doesn't add much at all...and Yes it breaks/makes the ESC black wire connection
Consider that the ESC black wire already reaches to the battery...all you need to add is the wire distance to the Kill Switch location
Cut the black wire at the ESC's connector (or unsolder the red wire) and run it to the rear in a handy location
Solder a new wire from the other pin of the Kill Switch to the pos connection of the ESC's battery connector (add a new one if you used the existing for the Kill Switch)
Under most conditions you will only add a few inches of wire...and with 4S or 6S power from a 3S-designed model...who's gonna notice a few extra inches of wire and a connector !!
I wasn't really too upset about the 330X...it's the cheapest 450 I own and the least powerful/adjustable
Haven't removed it from the case since the ground sucked on the tail
Old 06-19-2018, 11:56 PM   #4748 (permalink)
Installed an XT60 Kill Switch on a 300CFX tonight...
Added an XT60 connector and about 2 extra inches of wire to complete it
ESC black right from the package (minus 2 inches) to the Kill Switch - added black wire from Kill Switch to XT60 for the battery
ESC red right from the package turned 90 degrees to position for battery connector
Name:	Kill Switch 001.jpg
ID:	748737   Click image for larger version
Name:	Kill Switch 002.jpg
Old 06-20-2018, 12:49 AM   #4749 (permalink)
And just so the thread gets back on track...
450X #5 got it's RC Booya Canopy Mount System tonight...
And Jeff was kind enough to include some extra decals to show it off
Name:	450X-05 RCBooya 001.jpg
ID:	748739   Click image for larger version
Name:	450X-05 RCBooya 002.jpg
ID:	748740   Click image for larger version
Name:	450X-05 RCBooya 003.jpg
Old 06-24-2018, 04:34 PM   #4750 (permalink)
Had a great time yesterday at "Old Man Paulie's" 60th birthday celebration at the cabin site north of McGrath MN...
Turns out I'm older by several months
No flying this morning...gusty winds got everyone packing up for the trip home
Host property owner Maynard was delighted to have us...and sees himself getting into the hobby within several weeks although he'll be and FPV pilot
Have a tail wag that is most likely some type of tail issue to try to fix on My #4 450X...but everything else flew great
Old 06-25-2018, 11:27 AM   #4751 (permalink)
Default 450x conversion
This is my latest creation of an old favourite.
I used a fusion 270 esc with an ec3 extension and a 360 cfx 3s motor with 10t pinion.
Maiden went very well its buttery smooth to fly
BrokeDad likes this.
Blade Nano Cpx Blade Fusion 270 Dx6i
pidster is offline        Reply With Quote Quick reply to this message
Old 06-25-2018, 11:17 PM   #4752 (permalink)
I used a fusion 270 esc and a 360 cfx 3s motor with 10t pinion.
Great looking 450X...simple yet functional in it's own way
In case you have more than one...or a 300-size or 470 size...
The SAB 380 carry bag (with inserts removed) makes a great double-heli carry case
I have 5 450X's and a 470LP in 3 bags...carry 6 heli's with one hand !!
Old 06-27-2018, 02:18 AM   #4753 (permalink)
After a number of messages to iKON Support...I requested to send the iKON unit from 450X #5 to them to have it updated after it locked into BootLoader 1.5 during the update process
Every other iKON updated on the first attempt with no issues whatsoever so it's not My PC's or processes
Hopefully they will repair and return it without much hassle
Old 06-29-2018, 11:33 AM   #4754 (permalink)
Default hover
Got a quick hover flight, now @ 217 flights on my 5 years old 450X.
hoverfun is offline        Reply With Quote Quick reply to this message
Old 06-29-2018, 11:42 AM   #4755 (permalink)
A flight is a flight...no matter it's intensity
Congrats on the numbers and ownership time
I'll check My iKON's at the end of the season for flight totals since this is the first season for all but one
Old 07-10-2018, 07:16 AM   #4756 (permalink)
formerly koi-fish
Replaced stock screws on my second lynx 450x with stainless steel ones. I'm in the process of doing this on all of my helis, mainly on non mechanical areas such as the frame.
Bought a jigsaw and small drill press from Amazon so that I can cut reasonable facsimiles of things such as carbon fiber landing gear and bottom frame plates. They wont be as pretty, but will be functional.
Waiting on my third 450x to arrive! Bought another HF out recently, full bnf plus some spares
/ 180cfx, 300x, X3,X4-II, Protos 380, Chase 360, x5, Logo 480, Gob 380, Gob 500, Gob 570, Warp 360, 450x, forza 450/450ex, T-Rex 600 Dom, Logo 600, DX18, 07 Harley Road King, 1973 Ford f100, Traxxas Summit/X-Maxx
"Everyone wanted his soul, all he gave them was a smile" - Steve Marriott
Diogenes is offline        Reply With Quote Quick reply to this message
Old 07-10-2018, 10:13 AM   #4757 (permalink)
Third? What The Hay, Dude !
For the first time in over a year...
All (7) of My 450X's are now in flying condition (Thanks to You for the 7th)
The 470LP is ready too...I might even take the new Gaui X3
Red Lake Falls MN on July 13-15
Barnstormers Over Buffalo ND on July 21
VRCF Fun Fly in Kragnes MN on Aug 4
Park Rapids MN Fun Fly on Aug 18
RRRC Fun Fly in East Grand Forks MN on Aug 25
Red Lake Falls MN Fun Fly on Sep 8
Old 07-10-2018, 10:15 AM   #4758 (permalink)
My B400 (8 total) collection is starting to look small in comparison to your 450X one. But you have a ways to go to catch up to JonJet. I have only one 450X
Team USED
Shape S8,G700,G500,Shuttle 550,Trex 500 E/EFL Pro,Oxy 3(2),B400(5),450X,360CFX,Fusion 270(2),230S (V1/V2),200S,120S,Nano (CPS/S2),K110/120/130
BrokeDad is offline        Reply With Quote Quick reply to this message
Old 07-13-2018, 10:19 PM   #4759 (permalink)
Day 1 of the Red Lake Falls MN Friend Fly...
A handful of flights on 450X #1 (4S and uIKON)
Watched a Synergy E7 eject it's batteries and explode in two directions at the same time...
Good friends and great times
Old 07-14-2018, 11:14 PM   #4760 (permalink)
Day 2 of the Red Lake Falls Friend Fly...
More pilots...lots of flights...also a bit of carnage
My 450X #1 will need a whole new tail after I lost orientation and gravity sucked it to the ground
But on a high note...(and maybe a moment of temporary insanity)
I purchased a VooDoo FPV Quad from a good friend...no goggles yet so I fly it LOS on 3S and 4S...same as 450X #1
