Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 450X
Blade 450X Blade 450X Helicopters Information and Help
Like Tree25Likes
Old 08-20-2018, 11:09 PM   #4781 (permalink)
Attempting to assemble My 8th 450X...using the 330X electronics in a MicroHeli CF frame after the 330X's tail got sucked into the ground by a freak moment of excessive gravity...
I discovered an issue with a stock 450X rotor hub that would not allow the servo-to-grips rods to remain vertical...
The hole in the rotor hub is incorrect...and does not allow the follower arms to remain at 90 degrees to the rotor hub when connected
Have a new rotor hub on order to confirm My suspicions
Name:	450X rotor hub 001.jpg
ID:	753829   Click image for larger version
Name:	450X rotor hub 002.jpg
nCPX(3)*mCPX(25)*130X(10)*130X-L(6)*180CFX(3)*300X/CFX(3)
450X(7)*470LP*GauiX3*nanoQX*180QX*DX9*HF180060*AMA 988253
JonJet is online now        Reply With Quote Quick reply to this message
Old 08-23-2018, 11:45 PM   #4782 (permalink)
Sure enough...
The new rotor hub (left in pictures) with follower arms attached allows 90 degree connection to the hub collar...
The bad hub (right in pictures) is approx. 20 degrees off of 90
Name:	New 450X hub 001.jpg
ID:	754083   Click image for larger version
Name:	New 450X hub 002.jpg
Old 08-25-2018, 11:37 PM   #4783 (permalink)
Took 450X's 1 & 2 to the Park Rapids MN Fun Fly...had a great time
Going back again tomorrow (Sunday) for Day 2
Old 08-26-2018, 11:02 AM   #4784 (permalink)
Looks like Park Rapids MN Day 2 will get rained out...
Too bad...a great club and flying field...lots of good times yesterday
Old 08-26-2018, 11:13 AM   #4785 (permalink)
JJ .. You've finally exceeded my B400 fleet with your 450X one . Too bad about the event. Today looks like the one good flying day here for a few. Yesterday was storms and winds all day up to 2 AM this morning. Hot and humid but I've been out anyway. Farmers field is flooded so sticking to 450 and under again today. Will fly my single 450X for sure.
Team USED
Shape S8,G700,G500,Shuttle 550,Trex 500 E/EFL Pro,Oxy 3(2),B400(5),450X,360CFX,Fusion 270(2),230S (V1/V2),200S,120S,Nano (CPS/S2),K110/120/130
BrokeDad is online now        Reply With Quote Quick reply to this message
Old 08-26-2018, 02:29 PM   #4786 (permalink)
Would that be with counting #8?
It's almost ready...iKON2 and feathering shaft should arrive tomorrow
Then setup and checks before maiden
Does this mean I will beat HH to the punch and have perhaps the first 6S 330X?
MicroHeli CF Frame
Stainless Steel Screws & Silver C-washers at every frame location
Lynx 6S 1970kV Motor
Lynx OWB / 12T Slant pinion
Blade 330X ESC
iKON2 Mini FBL
Spektrum H3050 Cyclic Servo x 3
Spektrum H3060 Tail Servo
Stock Tail Assembly & Landing Gear
Blade 450X 325mm Main Blades
MicroHeli Boom Support Clamp
Name:	330X 6S 001.jpg
Old 08-27-2018, 09:14 AM   #4787 (permalink)
Contacted HH Support today regarding the incorrectly drilled head block (BLH4322)...
They are sending out a new head block...and the tech offered a pair of CF main blades along with it...
As always...when the callback came they greeted Me by first name
Old 08-28-2018, 01:41 AM   #4788 (permalink)
And tonite 450X #8 became a reality
https://www.helifreak.com/showthread...20#post7617220
Old 09-05-2018, 11:53 PM   #4789 (permalink)
Packing up nearly the entire large heli fleet for the trip to Red Lake Falls MN Annual Fun Fly at RiverBottom R/C Park...
Will be there Thurs Fri Sat Sept 6-8 for one of the last planned events of the season
Old 09-07-2018, 04:48 AM   #4790 (permalink)
Day 1 (Thursday) at RiverBottom RC Field...
450X #1's maiden flight went off without a hitch...smooth and solid as expected
Lots of activity with other pilots...including the complete destruction of a new Goblin 570 just as we got the tail gain/headspeed set properly (dumb thumb on the elevator into a ghost hole that claimed a Synergy E7 last time we were here)
Saw demo of the Magic Mirror Heli Tachometer...amazing tool I will just need to get for Myself
Expecting some more pilots to arrive on Friday and the actual event is Saturday so it's looking like a great weekend of flying to come
LubeMan1 likes this.
Old 09-07-2018, 06:57 PM   #4791 (permalink)
Day 2 of the event...and a special guest pilot arrived
The immortal Rob Cherry made lots of flights with Synergy's E5 / E7...absolutely amazing to watch from such a close distance
And during a moment of what can only be called temporary insanity (encouraged by the owner) he darted a delta wing into the ground at full tilt...from higher than his normal auto-rotation height
I also got a quick but complete schooling on CastleLink and Set RPM mode...
Works great on the 450X's that have Lynx motors...not so much on the others
Will need to get a few specs verified and try those again...
But the ones with 4S and 6S motors seem very strong now
All in all a great day...and still have tomorrow
Old 09-08-2018, 10:19 PM   #4792 (permalink)
Day 3 and the final day at RiverBottom R/C Field...and unfortunately the carnage continued for as few...
Simple pilot errors thrashed 3 large heli's into the weeds...an E5...a N5...and a N700...nowhere near the ghost hole that reared it's head yesterday
And there was an immaculate save of one 700 after the front tail drive gears let go in midair...the pilot auto-rotated-uncontrollable-piro'd it to the ground safely
2 borrowed gears later it was back in the air
As always the celebration meal was fantastic...with FryDaddy Scott serving up all kinds of goodies from the deep fryer...pulled pork sandwiches and all kinds of salads and fixin's
I think there were a total of 12 pilots...the most I've ever seen...with two of them coming up from St Louis MO just for today
Old 09-09-2018, 06:13 PM   #4793 (permalink)
Replaced the Scorpion 3S motor in 450X #6 with My favorite...
Now the Lynx 6S 1970kV motor can have all the power it needs
And the CastleLink Governor's Set RPM Mode settings worked great
Old 09-13-2018, 01:14 AM   #4794 (permalink)
450X #8 (330X rebuild) got a Castle Creations Talon60 today...
Allowing CastleLink Set RPM Mode to take over the governor duty
Lynx 2214 4S 4100kV motor will supply all the power...
10T pinion should do nicely at 2800/2900/3000 Head Speeds
Old 09-15-2018, 12:17 AM   #4795 (permalink)
Will be attending the Fergus Falls MN Fun Fly today...
Hopefully do the Set RPM testing on all of My 450X's...
Talon60 settings compared to the Magic Mirror Heli Tachometer should be interesting
Old 09-15-2018, 05:49 PM   #4796 (permalink)
Set RPM checks on 7 of 8 450X's today...
Got a couple pinions to change but I'm getting used to the CastleLink settings...
Just need to up the pinion tooth count on the 6S models and all will be good
The last new motor arrived in today's mail and got installed into 450X #5...so everything is on Lynx motors now
Old 09-25-2018, 02:20 AM   #4797 (permalink)
I had to pass on the Alexandria event last Saturday...the forecast was for windy conditions
VRCF will host a Fall Fun Fly even on Oct 13 &14 at the local field
A couple servo upgrades should be done by then...looking forward to one of the last outdoor events of the season
Old 09-29-2018, 09:26 PM   #4798 (permalink)
Got all My 450X's set up with Set RPM Mode in CastleLink...
#1 - 2900 - 3000 - 3200 4S (10T)
#2 - 3000 - 3200 - 3400 6S (14T)
#3 - 3000 - 3100 - 3200 6S (12T)
#4 - 2900 - 3000 - 3200 6S (12T)
#5 - 3000 - 3200 - 3400 4S (10T)
#6 - 2900 - 3000 - 3200 6S (12T)
#7 - 2800 - 2900 - 3000 3S (11T)
#8 - 2900 - 2950 - 3000 4S (10T)
May need to change a setting or two but this should be a good start point
Old 12-14-2018, 10:52 AM   #4799 (permalink)
This little bugger has come along way in life... What started in 2011 as a RTF blade 4503d flybar model has been transformed and modified over the years. For it's final upgrade I will be switching to 6s (FINALLY) I've had a Castle 50amp for some time installed and have just left it 3s. Just ordered a EOX 2222-1970kv Lynx motor and two 1200mah 6s batteries for it. Hopefully the packs are not too small but I think that seems to be the going size for 325mm bladed machines? I will post updates when the parts arrive. Will probably be selling off this 2221-8 Scorpion 3s motor...
-M
CURRENT SETUP :
*LINKS*
* G700c BRAIN2 * T-rex 500 *308DUO *450x #429
Relisys190 is offline        Reply With Quote Quick reply to this message
Old 12-14-2018, 04:42 PM   #4800 (permalink)
formerly koi-fish
Going to build me another to have something to do. Even though I have the lynx hardware to really build one out, I think I'm gonna stick with stock frame/boom/LG/mechanics this time. Since I dont want to spend any cash, I'm gonna build with what I have in trems of electronics (ds95i Cyclics, align 425 tail, 50a cc with gryphon bec, ikon, spektrum rx, elite 3s motor).
It'll be #4 . Id have more, but I have three forzas, and am building my 4th x3 (tri blade fore and aft)....
/ 180cfx, 300x, X3,X4-II, Protos 380, Chase 360, x5, Logo 480, Gob 380, Gob 500, Gob 570, Warp 360, 450x, forza 450/450ex, T-Rex 600 Dom, Logo 600, DX18, 07 Harley Road King, 1973 Ford f100, Traxxas Summit/X-Maxx
"Everyone wanted his soul, all he gave them was a smile" - Steve Marriott
Diogenes is online now        Reply With Quote Quick reply to this message
