Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 450X
Blade 450X Blade 450X Helicopters Information and Help
Like Tree3Likes
Old 07-31-2012, 12:41 PM   #201 (permalink)
[quote=Coco66;4153075]
Originally Posted by dellowwarren View Post
Here is my 450X, saw the sun setting and thought i needed to get a pic, dam does it just not look sexy/QUOTE]
Sun? In the UK? You must be joking...
Just kidding
You know I could also not believe the sun even came out but we had awesome flying weather for a few days and now we back to the "normal" weather
Blade 450x
MCPX
Belt CP V2
DX6i, Phoenix
dellowwarren is offline        Reply With Quote Quick reply to this message
Old 08-01-2012, 08:20 PM   #202 (permalink)
Picked it up today heading out for test --
Mikado Logo 700/Synergy 516\Vbar Vcontrol Touch/Neo/RCHN #612 IRCHA#5289
Iskareot is offline        Reply With Quote Quick reply to this message
Old 08-05-2012, 03:17 PM   #203 (permalink)
Thumbs up Great Flying Weekend!
A Great flying weekend in Germany for sure and it allowed me to become more comfortable with my BLADE 450's! The Revolution Main Blades Really do Improve all aspects of flight IMO but so did the KBDD Tail Blades and the Aluminum AR Bracket on the 450 X...gotta get one for the 3D.
Name:	BLADE Bro's 03.jpg
ID:	338153   Click image for larger version
Name:	BLADE Bro's 02.jpg
ID:	338154   Click image for larger version
Name:	BLADE Bro's 01.jpg
ACTIVE FLEET: GAUI X4 II, OXY 2/3/4 >< Align >< BLADE >< Walkera
...living the Hobby 4+ minutes at a time
R3L72 is offline        Reply With Quote Quick reply to this message
Old 08-05-2012, 03:52 PM   #204 (permalink)
What advantages do the aluminum AR bracket give?
gdawgs56 is offline        Reply With Quote Quick reply to this message
Old 08-05-2012, 04:26 PM   #205 (permalink)
Post
I noticed awhile back that when I would moved the swash plate or moved the blades for whatever reason, there would be a tiny bit of flex at the AR bracket; flying with the plastic one worked fine...or so I thought.
I then ordered the Aluminum AR bracket just to see if it'd make a difference and it truly did for me. One, no flex around the swash and two, cyclic response improved IMO. The 450 X seemed to 'hold' better in flight this weekend and the wobble I'd get on a downward pitch pump is now gone. It could just be me, but the Heli drifts a lot less now too.
Old 08-05-2012, 06:54 PM   #206 (permalink)
OH, thanks for the info!!
Old 08-05-2012, 11:32 PM   #207 (permalink)
Default 450x
Sorry for the pic. This is my 450x with Trex 450 fins and carbon tail blades.
this ones are better I think
They fitted with no mods.
conejo is offline        Reply With Quote Quick reply to this message
Old 08-06-2012, 12:49 AM   #208 (permalink)
Conejo, beware on the first flight with those carbon blades if there from Blade. I put them on mine and she wouldn't come off the ground. All it would do is tip to the right
Helis: Goblin 630c \ Velocity 50 \ 450X
Radio: DX-9
Sim: Phoenix
RCHN Citizen 48
lrs5 is offline        Reply With Quote Quick reply to this message
Old 08-06-2012, 01:47 AM   #209 (permalink)
Thank you, they are from Align (Trex 450 SEV2), I tested them today and the tail is more solid now, but anyway I will be careful. I had some carbon tail blades from Blade in my B400 and Thank God I was in hover when one blade was ejected right into the ground. It just broke.
Old 08-06-2012, 03:33 AM   #210 (permalink)
Here are some shots of my 450x aerial rig:
I have the ImmersionRC 600mw 5.8ghz video transmitter (not installed yet) and the FatShark Dominator (w/5.8ghz module) goggles on the way for FPV flight. I can't wait!!
SiMuL is offline        Reply With Quote Quick reply to this message
Old 08-06-2012, 04:48 AM   #211 (permalink)
Here's mine, yesterday up in the Alps.
H3000 cyclic servos, HSG-5084MG tail servo, alu tail servo mounts, Revolution blades. Rest is stock (ESC at 6V).
ID:	338415   Click image for larger version
ID:	338416   Click image for larger version
ID:	338417   Click image for larger version
Oxy 2X-VertWarp 360Blade 450XBlade 450X NightflyerGoblin 500 ♦ 2 X mCPX v2 ♦ night fly mQXLadyMQXnano QXnano QX FPVInductrixDX8 G1
Coco66 is offline        Reply With Quote Quick reply to this message
Old 08-06-2012, 08:40 AM   #212 (permalink)
Question
Excellent Photo's and flying location!
Question: If you are using the stock ESC, what process did you follow to change to 6.0V? I would like to run a different tail servo because I want to switch to Spartan Quark Gyro.
Old 08-06-2012, 08:45 AM   #213 (permalink)
DELETED
Old 08-06-2012, 08:48 AM   #214 (permalink)
Location was fantastic, once the cows stopped passing by!
ESC: just switched to a tail servo which can handle the 6V (stock one does not).
Stock cyclic servos can work at 6V so it's enough you move the little switch on the ESC (you can find pictures around here) after installing the new tail servo, then go through the full BeastX setup.
Old 08-06-2012, 08:50 AM   #215 (permalink)
Great solution, this I must try!
Micro: XK K110, Mini: Gaui X2 Formula
Medium: 330X 6S, G380
Big: G500, Align 700E
DX8, Phoenix
Old 08-06-2012, 10:20 AM   #216 (permalink)
Nice!
Team Synergy Field Rep, Rail Blades
Rodney Kirstine is offline        Reply With Quote Quick reply to this message
Old 08-06-2012, 10:21 AM   #217 (permalink)
Wow, that's some wild stuff! I would probably puke trying to fly FPV.
Old 08-08-2012, 03:37 AM   #218 (permalink)
What a cool landing pad! Did you make it yourself?
DX8, Phoenix
Old 08-08-2012, 12:14 PM   #219 (permalink)
Yes!
Go here at post #102 for details:
https://www.helifreak.com/showthread.php?p=4107354
Also check post #101 for details of where I "copied" the folding ideas...
Old 08-09-2012, 06:22 AM   #220 (permalink)
Great, thx!
For now I just use a large piece of lynoleum (floor), which I roll up when done
DX8, Phoenix
