Blade 450X Blade 450X Helicopters Information and Help |
#401 (permalink) |
![]() Take an aluminum or even steel pipe and beat it against something hard, then do it with a carbon pipe......then you will be a believer.
#402 (permalink) |
![]() i wish i had of bought the carbon fiber ones instead of aluminum now
![]() how do you go with your heli during flight? you have a lot of dark components on there - especially in the tail - does it make it harder to see?
Mikado Logo 500 Super Combo, Blade 450x castle edge lite 50, eflite 450H, vbar neoOxy2 FE micro brain 2, mks ds480 talon 25 rest stock Hobbyking Yak12 plane, QQ Extra 300, DX8 (G1), PL8 |
#404 (permalink) | |
![]() Quote:
Oxy 2 ♦ X-Vert ♦ Warp 360 ♦ Blade 450X ♦ Blade 450X Nightflyer ♦ Goblin 500 ♦ 2 X mCPX v2 ♦ night fly mQX ♦ LadyMQX ♦ nano QX ♦ nano QX FPV ♦ Inductrix ♦ DX8 G1 |
#406 (permalink) |
Aaron T. <---------Team MicroHeli----------> Fly Fast, Fly Low, Fly Micro! I love NITRO ![]() Too many to list......... |
#407 (permalink) |
TEAM HORIZON HOBBY Find me on youtube :: http://www.youtube.com/user/highadvantage |
#408 (permalink) |
Blade 230s Blade 150s Mcpx Brushless V1 Mcpx BL2 |
#409 (permalink) |
![]() Put in a Ice 50 lite esc, eflite 450 motor, and 5065 cyclic with 5084 tail servos..short hover to test things out, will fly more tomorrow...
![]() ![]() ![]() was a 450 3d incase your wondering why it has the zyx haha
Crash And Learn |
#410 (permalink) |
![]() looks nice with all the aluminum parts! did you find the tail was heavy after installing? i really wish the main gears were a different color i find it cheapens the look
#411 (permalink) |
![]() I think you could dye them... same as skids, tail blades and fins.
#412 (permalink) |
![]() Or use the black gears from the blade 400. They are the same but black.
#413 (permalink) |
![]() Don't have a lot of stick time with it but
The hover went well...I think the new esc and bigger motor help counter the slightly heavier tail...
Crash And Learn |
#414 (permalink) | |
![]() Quote:
#415 (permalink) |
![]() I had to use the spacers on both sides of the blades as well with the Align 3G blades. I would be interested in learning of blades that do not require spacers with the stock grips.
Protos 700X Evo, Kraken/700 Havok/Kraken 580/Buddy 380 KSE, Logo 550SX V2; YGE "T" ESCs, Neo VLinks;VBC Touch, AGM Deep Cycle Batteries Simulators (on MacBook Pro): Heli-X, neXt, AccuRC, RF9, Phoenix, AeroFly RC7 Ultimate Citizen 259 |
#417 (permalink) |
![]() Once the blades are on the grips, no longer an issue. However, it is much easier to swap blades that do not require spacers. Changing blades that require aligning the blades and spacers is a more time consuming process. If one tries changing the blades at the field, one risks loosing the spacers. One looks really silly when on all fours trying to find small parts on the grass.
#418 (permalink) | |
![]() https://www.helifreak.com/showthread.php?t=410365
Team MikadoUSA REVOLECTRIX Ambassador |
#419 (permalink) | |
![]() Quote:
#420 (permalink) | |
![]() Quote:
I suspect the only blades you will find readily that will fit the grips will be the 450 3D woodies. I've not tried the them, so I can say this is but a guess. They're probably not a realistic option; they are not rated for the 450X stock running at full tilt, probably not balanced ideally for FBL, if at all.
