Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 450X
Blade 450X Blade 450X Helicopters Information and Help
Like Tree3Likes
Old 08-18-2013, 10:47 PM   #881 (permalink)
4 packs, vid and a couple pics forthcoming. I loooove the fact I can charge and be flying again in less than an hour. Used to be six hours for one pack to charge, now I can charge 4 within about 2-2.5 hours. Yeeesssssss!!!!!!
I have a yaw when going form + to - pitch during flips. Maybe gain, maybe belt tension, maybe ccpm interaction.
~~~Lynx Heli Team~~~
Ed Olson is offline        Reply With Quote Quick reply to this message
Old 08-19-2013, 12:24 AM   #882 (permalink)
2-2.5 hours even feels like a lot these days. With a good charger and a parallel board and you can easily parallel charge six 3S packs in about thirty minutes at 2C. Most batteries these days are rated for at least 2C charges, many up to 5C. Of course I generally don't go over 2C unless I'm in a real hurry.
The iCharger 3010B (1000W) is excellent and not too expensive. I use it at home with a 500W power supply. On the other hand it can also easily parallel charge 3S packs all day at the field running off a 12V marine battery. Off a battery I try to keep it under 10A but that's still enough to parallel charge two 2200 mah 3S lipos at 2C (8.8A) with room to spare. With this setup, given a few minutes between flights, you could easily fly back to back all day long with 5 or 6 packs.
Gaui X5F 6S (VBar), Lynx 450X-L 6S (Ikon), Lynx 300X-L 4S (Ikon), Blade 180CFX 3S (Ikon)
Lumenier QAV400 4S (Vector), Lumenier QAV250 3S (Naze32/CleanFlight), CYE Stingray 500 4S (TG Multi)
AMA Member, HCAM Member
Nelsonisms is offline        Reply With Quote Quick reply to this message
Old 08-19-2013, 03:43 PM   #883 (permalink)
Maybe thumbs..
Kidding, sort of. It's amazing how easy it is to give a little bit of rudder without realizing it when you're pushing +/- collective.
Team MikadoUSA
hemp is offline        Reply With Quote Quick reply to this message
Old 08-20-2013, 01:10 AM   #884 (permalink)
Default Re: Post pics of your Blade 450X
agreed, but it doesn't happen on the sim.
-Ed
Old 08-20-2013, 01:24 PM   #885 (permalink)
Cool
Is it still a Blade?
ID:	444941   Click image for larger version
ID:	444942   Click image for larger version
ID:	444943   Click image for larger version
full 2s/3s mcpx , 450x 4s BLHeli, Rex500/550 stretch BLHeli TARANIS
Diablol is offline        Reply With Quote Quick reply to this message
Old 08-20-2013, 02:25 PM   #886 (permalink)
Sleek and simple. I can dig it.
Still a Blade though.
Old 08-20-2013, 03:11 PM   #887 (permalink)
Nice!
I also like simple canopies (OT picture):
Oxy 2X-VertWarp 360Blade 450XBlade 450X NightflyerGoblin 500 ♦ 2 X mCPX v2 ♦ night fly mQXLadyMQXnano QXnano QX FPVInductrixDX8 G1
Coco66 is offline        Reply With Quote Quick reply to this message
Old 08-20-2013, 04:48 PM   #888 (permalink)
The Airetic
I totally dig it. Subtle. How is the visibility with just white and black? Which blades are those? The 360 warp blades?
I think after my next crash, I am going to try a stretch. I was unable to find a mid size belt, so I'll run the same one you do.
Free Agent....With standalone opinions.
KiloXray is offline        Reply With Quote Quick reply to this message
Old 08-20-2013, 06:26 PM   #889 (permalink)
My converted 450 3D to a 450X.
I call it a 450CX
450X | 450 3DX | 300X | 130X | Mcpx BL | Mcpx | SR | 350QX | Mqx | Nano Cpx | Nano Qx | 120 SR | And one DX8 to rule them all.
Blackanthem is offline        Reply With Quote Quick reply to this message
Old 08-20-2013, 08:37 PM   #890 (permalink)
I call it a 450CX
It's not fair.. I like both canopies for the 450x, and neither canopy for the 300x. I guess when I smash my grey/green 450x canopy into the ground it'll give me something positive to think about..... I get to buy the yellow canopy.
Nice looking chopper.
-J
BigJay is offline        Reply With Quote Quick reply to this message
Old 08-20-2013, 11:25 PM   #891 (permalink)
...edit..moved to appropriate thread.
Old 08-21-2013, 05:47 AM   #892 (permalink)
I call it a 450CX
LOVE this canopy. I ever/when I bust up my custom Fusuno this is my next one.
My EK is nice on cloudy days but my Fusuno is a glow bird on sunny days.
RichKnapp is offline        Reply With Quote Quick reply to this message
Old 08-21-2013, 07:18 AM   #893 (permalink)
Visibility is the best I ever had. White is unbeatable in most cases. Yes this are Warp blades. They are lighter and better FBL balanced than the Tarot one.
Old 08-21-2013, 09:02 AM   #894 (permalink)
The Airetic
Nice, I just might steal your whole look! Hope you dont mind. I have an original canopy that I might rattle can white just to test it out.
Ive never seen the Warp blades with the white ends and the W in them though. I can only find the solid black/CF ones.
Old 08-21-2013, 09:47 AM   #895 (permalink)
If you want to add strength to the stock canopy and go flat white a good option would be to use white plasti-dip and possibly the plasti-dip glossifier. It'll add a couple of grams (not as much as a fiberglass canopy) but it will be way more crash resilient. Spray it inside and out for best results. The best part is it can be peeled off if you don't like it or want to change the color later. To expose the canopy "window", let it dry and then use an x-acto to score around the edges of the "window" and peel off the plasti-dip....no need to use masking tape! They do sell it in a few colors too, but you can spray paint over it to add color. I was able to pick some up at Home Depot. I did the mCPX BL canopy this way and it is pretty much bullet proof.
Thanks to Chris B. (JustPlaneChris) from the RC Today Show for turning me on to this. Works like a charm.
Old 08-21-2013, 12:45 PM   #896 (permalink)
I dont mind lol. You are not the first I am always happy to see some cool styles.
You will not find those blades either they are painted as well. It are my initials "M" "K" .
Old 08-21-2013, 02:50 PM   #897 (permalink)
The Airetic
This is a great idea, one which I may use some time in the future. For now, I live in Honduras, and finding stuff like that at local 3rd world hard wear stores is pretty much impossible. Im actually on leave in the states at the moment, but I don't think that I can take that on an airplane, checked or carry on.
Ill just have to use plain white rattle can paint. maybe I can find some Kryoln, if I get lucky.
Old 08-22-2013, 09:28 AM   #898 (permalink)
I'm really liking the yellow canopy. My eyes tend to see yellow best in most lighting conditions.
Present: Blade 180CFX.
Coming Soon: Blade 360CFX
Past: GMP Cricket, GMP Shuttle, Kyosho Concept DX, Kyosho Concept SE, GMP Rebel, Blade 500X, Blade 450X, Blade 130X, Blade MCPX-BL, Blade Nano CPX.
r/cdawg is offline        Reply With Quote Quick reply to this message
Old 08-22-2013, 02:37 PM   #899 (permalink)
New Fusuno Tricolor and KBDD blades
AMA#1014992MCPX,CX2,CP-Pro, Blade450 3d,450X with Scorpion 8 and Align Airwolf fuse.Trex700E with AR7200bX,Gens Ace 5300,Scorpion backup
air grinder is offline        Reply With Quote Quick reply to this message
Old 08-22-2013, 02:54 PM   #900 (permalink)
blades look sweet with that canopy
Stubbz is offline        Reply With Quote Quick reply to this message
